#99 |
Drives: 2013 SWP BRZ
If you do the foulers, make sure to anti seize them. I did that trick in my STi and made the mistake of not putting anti seize and when I was removing my downpipe on my 30r kit I ended up snapping it off in there and there was no way of getting it out. Had to weld the hole closed.
#100 |
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
So would the addition of the UEL header throw a CEL? I'm going to be putting on a catback soon and would love to grab a header too, but getting a tune is about as expensive as the header. I do want to keep as many cats as possible as well so not sure if this would help.
#101 | |
Drives: Toyota 86 GT
#102 | |
#104 | |
Drives: WRD BRZ Limited
| The Following User Says Thank You to BryanGT For This Useful Post: | Jaylyons1 (03-27-2013) |
#105 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I actually posted that before learning that the ECU only checks for cat readyness via the secondary O2 sensor. Nothing to worry about using an O2 sensor spacer to avoid a CEL on the stock tune. No fueling issues based on lots of feedback from others running catless already.
#106 |
Drives: FRS 2013
He must of not read that far back. I just wanted to chime in and say im going on one week, 350 miles, on the uel without a code, no defoulers. Fingers Crossed
#107 |
Drives: DGM BRZ Limited "Freyja" +2 Miatas
And for some reason, my CEL turned off today. Gotta actually go check now and see if it's a different CEL. Fawk.
#108 |
Drives: 2013 BRZ, 2004 WRX
#109 |
Drives: FR-S 10 series
In for Borla UEL headers, Perrin overpipe/ catted frontpipe and borla catback
![]() edit: Never mind...found in youtube!! [ame]http://youtu.be/EZQdI9tVmBY[/ame] minus perrin...im sold. Doesnt seem overly loud
| The Following User Says Thank You to Pablitomarrero For This Useful Post: | Mr. (04-10-2013) |
#110 |
Drives: 2013 FRS 10 Series
#111 | |
**edit** Based on me rereading this a couple of times I'm guessing you went with one angled bigdaddies spacer and put in the second (furthest from the engine) |
#112 | |
I also got a refund for the Borla header and bought a JDL UEL header which is much better quality. |
| Dynos.. Mustang, DynoJet and Dynapack | phenom86 | Engine, Exhaust, Transmission | 44 | 01-19-2018 05:32 PM |
| Borla R&D: Comparison UEL v EL Header 2013 Scion FR-S/Subaru BRZ | RiskyTrousers | Engine, Exhaust, Transmission | 155 | 08-16-2013 09:05 PM |
| New! Borla cat-back for FR-S/BRZ | Mach V Dan | Engine, Exhaust, Bolt-Ons | 9 | 02-06-2013 08:57 AM |
| Berk mid pipe and track exhaust installs, dynos, and video | Matt Andrews | Engine, Exhaust, Transmission | 15 | 12-11-2012 08:15 PM |
| Borla Exhaust in the works | DAZE752 | Engine, Exhaust, Transmission | 14 | 06-13-2012 02:27 AM |
