#85 |
Huge E85 fan!
Drives: 2016 Scion FRS
HP sells cars, torque wins races.
I'm looking forward to strapping a turbo on this thing one day once it's paid off and the warranties are up. Then the fun begins. I think "enough" is under 11 lbs/HP, so that'd be about 250 HP for this car. It's enough because at 11lbs/HP female passengers squeal when I stomp the loud pedal. The torque needs to be up here too at 250+ lb-ft. This car is just a wee bit too sackless- but that just means we have something to work towards! Last edited by guybo; 05-16-2016 at 05:55 AM. |
#86 |
Drives: Steel FR-S 2015
Yellow means go in this car
#87 |
Drives: MY11 Maxima 350st, MY15 BRZ
When talking about whether the car has enough power I think its important to understand the application. What did you buy the car for and intend to do with it going forward?
Most of my commute involves 60, 50 and even 40kph zones. I came from a string of GM V8's that would only need the lightest brush of the accelerator to hit those speed limits, which became tiring. Like most others, I was seeking a fun daily driver. More specifically though, a daily driver that could allow me to still have fun at lower speeds so... in came the twins! Here was a car I could wind out in low gears and still be doing legal speeds, but also had amazing handling. After owning the car for a little while though (and after much reading up on our site) I started to ponder whether it had enough power. I started to really break down the car's performance into what was good and what I could improve. Even if I didn't increase the power level, what could I do to the car to help maximise what power it had? In came the 4.556 final drive ratio and the aluminium drive shaft. The effect of that? A more sensitive throttle response and a little less slack in the drive train. Possibly from the one piece drive shaft and its 50% weight shedding over stock. Something I did not foresee with the change, was improving access to higher gears, which really made the car more relaxing to drive. Keeping in mind I only drive in sports mode, this mod let me pick a higher gear (more often) across all the speed zones I travelled resulting in a more relaxed drive. I had power sooner and (unlike prior) rarely needed to drop a gear to speed up more enthusiastically. That was pretty transformative and seemed just enough to keep me happy for a good while. Then came the handling and though I originally researched new coilovers I also turned my eye to bracing, which seemed both cheaper and something I could easily fit myself with minimal fuss. Wham! A dramatic improvement to handling with the addition of a strut bar and some TRD door stabilisers. The ride actually settled down a notch or two. Possibly because the chassis was stiffer so the suspension could do its thing more efficiently. Now everything feels a little more immediate in both acceleration and handling in general. What I'm trying to put into words here is what if you could change and tweak your car in a way that makes it feel faster, but which does not involve massive increases of power? Another excellent mod is a header and tune to nail the torque dip leading to more linier acceleration. If you took all these tweaks, which does not exactly add slabs of power.. wouldn't you be more happy with that power the car had? If your throttle response, handling, feedback all got dialled to eleven, would you care that your car only had say 220 odd HP after fitting all these mods? I think this all comes back full circle to understanding the application. What do you need your car to do in the scope of your driving that would make you crave more power?
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
| The Following 5 Users Say Thank You to Mim For This Useful Post: | Hoahao (05-16-2016), kritch (05-29-2016), Mr.Impreza (05-16-2016), Tcoat (05-16-2016), themadscientist (05-16-2016) |
#88 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
speed limits are irrelevant as just about ANY car can exceed the legal speed limit in the streets given enough time. so, we're not talking about top end or driving faster than the speed limit in the streets. we should also not be talking about handling either, because what are you doing in your daily driving where you NEED better handling? maybe better comfort on long commutes or on potholed city streets - i can see getting adjustable coilovers where you can dial them down for a softer ride. but where would you need a strut bar or bracing in the street? so, if you ask yourself 'why did i do the mods i did?' to improve throttle response and acceleration, people who tack on more HP are doing it for the same reason; just accomplishing it by a different route. if you drive somewhere where you need to improve handling, someone else might enjoy more power doing exactly the same thing.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
| The Following User Says Thank You to shiumai For This Useful Post: | Mim (05-16-2016) |
#89 | |
Drives: Scion FR-S
With the number of people complaining they got smoked by Minivans, they clearly are not driving it the redline. We even got one dude that got smoked by a Toyota Tercel Anyway I plugged the sound tube on my car and got a N1 exhaust. And I love revving it out to 7400 RPM
Instagram: @racecar_4life
| The Following 2 Users Say Thank You to VTEC For This Useful Post: | DarkSunrise (05-16-2016), Mr.Impreza (05-16-2016) |
#90 | |
I do agree with you on the sound aspect though. Our cars sound meh stock, so not much incentive to wind it out. Toyota/Subaru should have spent a little more time making it sound better.
2022 BRZ Build 2013 FR-S Build |
#91 | |
However... When I test drove the stock version the lack of any true exhaust note almost turned me off. Then they started my car with the TRD on it in the showroom! And... I despise the sound of 4 cylinder Honda exhausts (see my subjective comment above) and do not care what engine they have or what was done to them. They all sound like tinny, whiny crap to my ear.
| The Following User Says Thank You to Tcoat For This Useful Post: | Mim (05-16-2016) |
#92 | |
I actually think that's what Toyota/Subaru was going for with the FA20 intake piping into the cabin. Unfortunately it didn't end up as good sounding as the K series IMO
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Tcoat (05-16-2016) |
#93 | |
The ONLY Honda I have ever drove in my life had horrible sound in or outside.
| The Following User Says Thank You to Tcoat For This Useful Post: | DarkSunrise (05-16-2016) |
#94 | |
I also meant to add, I'm not a fan of aftermarket exhausts on Hondas either. I actually find most exhausts on 4 cyl cars pretty annoying. Only exceptions are the Fiat 500 abarth (kind of) and 4-cyl UEL boxers (WRX/STI, 718 Cayman/Boxster, etc.)
#95 |
Yep. In all it's 60HP and 0 to 60 in an afternoon glory!
#96 |
BS no way that thing did 60 mph!
#97 |
Eventually. Those 12 inch wheels were spinning like a sonofabitch though.
#98 | |
Drives: '13 FRS - STX
![]() [ame="https://www.youtube.com/watch?v=ViAM7AHheJg"]Honda S800 9000rpm - YouTube[/ame] [ame="https://www.youtube.com/watch?v=AMSB5rIHWOY"]Honda S800 RSC (1968) @ Twin Ring Motegi , 11 July 2012 - YouTube[/ame] |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Blokatos (05-17-2016), freerunner (05-17-2016) |
| Horsepower | Chase1996 | Engine, Exhaust, Transmission | 32 | 03-08-2016 11:26 PM |
| Who says we need more horsepower? | LeeMaster | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 01-11-2013 12:05 PM |
| Bolt on 6 horsepower for about $50. | MillersOilsUS | Engine, Exhaust, Bolt-Ons | 29 | 01-10-2013 09:53 PM |
| 6 horsepower, 4 lb-ft from an oil change | MillersOilsUS | Mechanical Maintenance and Tools | 1 | 01-03-2013 12:21 PM |
| ft86.com has some serious horsepower! | MrBRZ | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 03-22-2012 08:45 PM |
