Old 05-10-2016, 08:09 PM   #3851
vgi
Drives: frs
Originally Posted by fumanchu1 View Post
People really need to stop the pissing contest between KW and JR. Both kits have their downfalls and both are great when properly installed and tuned.
yep
vgi is offline   Reply With Quote
Old 05-11-2016, 10:00 PM   #3852
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Originally Posted by Freeman View Post
I hammered mine flat and haven't had an issue with them. Maybe have some custom ones made with thicker steel?
I was thinking the same. I have an old bracket for a wastegate actuator which fits pretty good. Hammering them flat sounds like a good idea too. Thanks!
D-VO is offline   Reply With Quote
Old 05-14-2016, 04:35 PM   #3853
FirestormFRS
Just go buy some hose?
No obvious reason to have it back at the battery maybe to keep oil off the belts when filling or in case of leaks???? No idea.
FirestormFRS is offline   Reply With Quote
Old 05-15-2016, 09:22 PM   #3854
D-VO
Originally Posted by Sgtfluffy16 View Post
okay guys need to ask another question my kit is fully on other then my oiling system for the rotex. I installed the cooler and the line to it. Here is my problem. The kit never came with the bracket to mount the resivior back at the battery like the instructions say. also i didn't get 4 hoses to do the plumbing. I got 1 hose measuring 130 inches. If i follow the instructions i will get 2 lines done out of that hose.
So here is the question why do some of you, like @D-VO have the resivior mounted on the Supercharger mount plate and other have theirs mounted at the back near the battery? If i did the resivior up front on the plate i would just have to find some bolts to mount to the plate and i think the 1 hose should reach to make all 4 lines from there.
Suggestions? Comments?
I originally had it mounted back by the battery, but after my first Rotrex oil change I found it easier to have the reservoir up front to make the whole process easier.
Old 05-19-2016, 01:37 PM   #3855
Beechnut87
Drives: White 2015 Series Blue BRZ SC
Kraftwerks C38 Supercharger Finally Installed!
I finally got my Kraftwerks C38 supercharger installed and tuned on 5/18/2016 at PRE (Precise Race Engineering) in Portland Oregon. Guys did an awesome job and it was a little bit of a surprise when i first got in and realized the throttle response was no longer as touchy as before, but holy wow this car is ALIVE now. I have never had a car with a SC only TC so listening to the whine of the SC is new and i love it. Guys threw down 292 at just over 12psi.
Beechnut87 is offline   Reply With Quote
Old 05-19-2016, 03:04 PM   #3856
Beechnut87
I had PRE do my install as well as the tune, I'll get some pics later for you though to check!
Old 05-19-2016, 04:20 PM   #3857
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by Jcl View Post
Derale 25792 thermostat
Kraftwerks oil sandwich plate (626-12-1000)
Oil cooler of your choice
ok, so with this being said, anyone have any good suggestions for a oil cooler of choice? I know there are a lot of oil cooler threads outside this one, but it's nice to have information all in one thread instead of hopping around from thread to thread and then re-reading a thread that you thought haven't read. lol.
Anyone have preferences on where to mount? Behind fog light on passenger side, and front in front of intercooler? or front behind intercooler? Just want to bounce some ideas back and forth. If I go through with this I'll be sure to make a DIY for all Kraftwerks owners and post it in here.
pgranberg11 is offline   Reply With Quote
Old 05-19-2016, 04:22 PM   #3858
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
nice results, this on 93? or ethanol?
Old 05-20-2016, 12:15 AM   #3859
Beechnut87
Kraftwerks Supercharger Owners Thread
Premium pump gas, I was really shocked, I was not expecting THAT much. Also more pics,not sure what rubber mount you have I had all of it installed by PRE in Portland.
Old 05-20-2016, 01:03 AM   #3860
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Awesome results! I got mine e tuned by moto east on ethanol. I still have to dyno mine but good to know that I'm around that point of 290-310ish whp lol
Old 05-20-2016, 04:19 PM   #3861
vgi
Drives: frs
any mods (fuel pump, injectors, header, exhaust,..)?
lightweight pulleys would help a bit with that throttle response
Old 05-20-2016, 04:21 PM   #3862
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Is PRE still using BRZedit?
Freeman is offline   Reply With Quote
Old 05-21-2016, 12:29 AM   #3863
D-VO
Also did your oil resivior fit with the new and "improved" rubber isolator mounts? I couldn't even put the bottom clamp on because it hit the center radiator support... I had to mount it without the rubber isolators
Same thing happened to me. Let CJ know over at KW. I explained to him what is happening but it seemed he thought I'm the only one having this issue.
Old 05-21-2016, 12:48 AM   #3864
Beechnut87
I have a build thread page with everything i have done, but i have a Borla UEL header, Perrin Overpipe, Invidia Hi Flow Cat, and Invidia N1 Exhaust for what i can immediately think of. Ill have to keep the pulleys in mind
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
