#1205 |
Road-hole
Drives: 2013 Whiteout FR-S
Is running lean at low load normal?
How normal is it to run lean compared to commanded AFR at lower loads?
at higher loads, commanded AFR and measured are pretty close but at lower loads, they are WAAYYY off... Jaden |
#1206 | |
Drives: FT86
are you in open loop or closed loop fueling mode when its running lean ? have you just jumped on/off the throttle ? Last edited by steve99; 05-10-2016 at 08:47 PM. |
#1207 | |
Road-hole
open loop
Jaden Last edited by Jaden; 05-10-2016 at 08:12 PM. |
#1208 |
AFR @ 20 is fuel cut, happens when you let off throttle. It's normal.
#1209 | |
Drives: FR-S Whiteout
Personally in my logs I'd like to include some part throttle operation under different loads all the way up the rev range along with, obviously, some WOT pulls. I would take several in 3rd gear pulls, and usually end with a 3rd to 4th to 5th gear pull then normal commuting operation just so I have a clear picture of whats going on. Oh and also of some various sudden increase in throttle of different duration (to gauge how much tip-in knock correction im getting, if I'm getting any). Stuff like that. Just to be thorough.
Intent > Content
cowardice is the mother of cruelty. |
#1210 | |
Drives: 2015 Firestorm Scion FRS
My testing methodology after flashing a new tune is go on a few non-intensive cruises or drives to work so the ecu can learn first and datalog a few to make sure there's no knocking or irregularities under normal driving conditions. IAM, FLKC and knock correction always stayed at 1,0,0 respectively on all tunes I tried. Then when I have time on weekends, then I log some 1st to 3rd gears pulls at a empty office/industrial area. Then to wrap it up, log some spirited driving/thrashing. ![]() TLDR: Based on all the data and tunes I tested, the knocking occurs in the high rpm range with IAM slowly dropping to a worse case of 0.8ish. FLKC dropping as low 2.8ish degrees but 'knock corection' (same as FBKC?) remains at 0 for 99% of the time. Right now I'm tweaking the best tune (OFH with Waynos maps) to see if I can reduce the knock? |
#1211 |
@G-awesome IF you did not see and - KC or FLKC under other operating condition then it's unlikely that an exhaust vibration is causing the corrections. From the logs you posted i assumed you were only logging single 3rd gear pulls. Though it's good to be thorough and check the hardware for rattles and what-nots. Are you still on the same tank of 94 octane gas?
It's interesting that the 3rd log in the initial post had more aggressive ignition advance compare to the Stg 1 log, yet the stg1 log registered much more knock correction. Also, on the 3rd log past 5200rpm you are at 11.37 afr even though the LTFT is 0%and commanded afr is 12.24. This tell me your maf scale is off by a good margin. You should get your maf scale squared away first. 3rd log: http://www.datazap.me/u/gawesome/201...7-249&mark=176 Stg 1: http://www.datazap.me/u/gawesome/201...4-199&mark=142
Intent > Content
#1212 | |
#1213 |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
I'm trying to figure out an issue with my Sprintex 210 that myself, nor my builder, or tuner can seem to figure out.
Let me give you some backstory - had a '15 FR-S with the 210 Intercooled. 69MM pulley. Went and had it tuned, no problem. Took 16 degrees of timing and made 260whpish (93 gas). Car was totaled by someone, so I saved the blower, bought a new intercooler/pump, and put it back on my '16 BRZ. Had my tuner re-create the same rom that I had before, just for the '16 ECU. Now, for whatever reason, my car just won't take any timing without knocking. The setup is exactly the same, just a different motor. I understand there's variances in motors, but for me to lose basically 4 degrees of timing, the car won't make past like 200whp on pump gas now, without knocking. I'm at a loss. I don't know where to try and diagnose this or try and figure it out. We've tried like 10 different tunes, all with less timing and different advances and such. When we take out timing in the tune, the car reacts even further by cutting the IAM. I'm just curious if you all have any insight on how to go about trouble shooting this issue. Here's the most recent log he had me create - this is the same tune from the '15, ported to the '16 rom. http://datazap.me/u/rifle/1?log=0&da...zoom=7364-8017 And here's one from where we took timing out.. http://datazap.me/u/rifle/wtf?log=0&...zoom=3353-3707
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ |
#1214 | |
Drives: Toyota 86 GTS
If you don't think there's anything wrong with the car or the tune, then it's a problem with the platform and/or MY16 rom logic then your tuner should be getting support from ecutek as that's what your tuner pays for.
#1215 | |
But for it to be pulling 3 degrees of timing under WOT... I'm just confused. No idea.
295WHP/220TQ |
#1216 |
Drives: UK GT86
@Rifle has this been dyno tuned? At a glance I noticed that the O2 sensor hasn't been scaled so the reading flatlines above 12. Not an issue if you know what's going on though.
There's a variance in fuel used between a few of those runs in the 1st log, the 1st few pulls register less voltage on the MAF and are therefore using less fuel. The rest of the pulls are injecting similar amounts but it would be interesting if these are changing the AFR much. Any idea of the charge temps? I see you're using the stock IAT so it's hard to tell what's happening in the manifold.
.: Stealth 86 :.
#1217 | |
2nd log is essentially the same tune as the first, with timing taken out of the table. I don't have a wideband, I probably should, but according to my tuner when we had this car on a dyno, the fueling was right, even when we pulled timing. No idea of the charge temps hitting the actual block. I know the sensor reads like 22C, but it also compressed by the supercharger and run through an intercooler before hitting the block. My only conclusions are that the 69mm pulley for the 210 (which is 12psi) is really made to run e85. The old car could handle it, but this one can't. I think I'll try stepping down 1.5psi to the 72.5mm pulley, which is what they recommend for 93 anyway.
295WHP/220TQ |
#1218 |
Not a troll
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
