Old 05-10-2016, 10:12 AM   #3823
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
I'd like to get a bit more camber out of my setup, which I'll check if it's appropriate with a pyrometer and the other methods mentioned in here.
But, I'm not entirely sure HOW to get the additional camber. Can someone just give me a very brief explanation of how we can get 2.0 to 2.5 camber on these cars? I'm currently using the crash bolts to get 1.3, and I know I might be able to get 1.5 using the actual camber bolts. I'm curious what parts would be needed to get appropriate camber front and rear. Thanks!
Apex_BRZ is offline   Reply With Quote
Old 05-10-2016, 10:15 AM   #3824
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Camber plates up front, lower control arms in the rear.
ineedyourdiddly
Old 05-10-2016, 10:18 AM   #3825
Apex_BRZ
Perfect, I'll do a bit more research from here. Thanks.
Old 05-10-2016, 10:35 AM   #3826
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Crash bolts top and bottom in the front. Supposedly you can rotate the front shock mounts.
Old 05-10-2016, 10:58 AM   #3827
Apex_BRZ
I have the crash bolts in the bottom. I don't like this and would rather spend the money doing it the right way.
Old 05-10-2016, 11:01 AM   #3828
Pat
Pat's Avatar
Drives: 2023 BRZ
Get camber plates. Raceseng is the gold standard, but you pay for it. And some of what you're paying for might be the pretty look. Consider those, Vorshlag, RCE and maybe some others.
Old 05-10-2016, 01:24 PM   #3829
CSG Mike
CSG Mike's Avatar
RaceSeng in the front, SPL in the rear.
Old 05-10-2016, 02:37 PM   #3830
strat61caster
FYI, leave the camber bolts in, if you are pushing the car, odds are you'll need it.
Edit: 'it' being the extra ~.7+ degrees of negative you get with camber bolts.
ineedyourdiddly
Old 05-13-2016, 07:54 AM   #3831
peaches
Drives: '14 BRZ Limited
Can I use these on stock suspension?
peaches is offline   Reply With Quote
Old 05-13-2016, 01:17 PM   #3832
EAGLE5
Dismember
EAGLE5's Avatar
Yes. The LCAs should work with anything, and the camber plates can be ordered with mounts for anything.
Old 05-13-2016, 01:37 PM   #3833
peaches
OK, my biggest concern was the LCAs as I didn't know if the stock top mounts would support adding the camber.
Old 05-13-2016, 03:11 PM   #3834
CSG Mike
CSG Mike's Avatar
Absolutely!
Old 05-13-2016, 06:16 PM   #3835
EAGLE5
Dismember
EAGLE5's Avatar
I wonder if we'll ever be able to buy the Reiger 3-way suspension.
Old 05-13-2016, 09:07 PM   #3836
Northwest86
Drives: Velocity Orange 86 GT
Front camber plates, Camber washers and Rear Lower or Upper control arms.
Northwest86 is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
