Old 05-09-2016, 04:06 PM   #1
ThornhillSubaruOwner
Drives: 2013 FRS
Valenti Taillights and Backup lights
Im planning to buy valenti tail lights and the back up lights.
http://www.fteightysix.com/products/...s86z-hc-2.html
Since I'm on a lease and I'm not 100% sure if I'm going to buy the car at the end of the lease, I want to know if you have to drill holes/cut wires to install these?
If you do, would that affect me at the end of my lease term? I'm going to reinstall the stock ones IF I return it, but would the holes/cut wires affect the lease?
ThornhillSubaruOwner is offline   Reply With Quote
Old 05-09-2016, 04:08 PM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
My Valenti tail lights (Gen 1 I believe) were plug and play. I just installed the third tail light/back up light. That, you have to tap into the brake light wire.
Clueless
YamahaR86 is offline   Reply With Quote
The Following 2 Users Say Thank You to YamahaR86 For This Useful Post:
MisterSheep (05-09-2016), ThornhillSubaruOwner (05-09-2016)
Old 05-09-2016, 04:25 PM   #3
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
The valenti lights are plug and play. There should be no problem if you ever wanted to return back to stock
Instagram: trevor.parque
Old 05-09-2016, 04:34 PM   #4
Drives: 2013 FRS
Would it be possible to reinstall the stocks after that?
Old 05-09-2016, 04:59 PM   #5
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Yeah it's fine. The 2 wires you have to tap into for the third brake light is for the running "v" light and the solid brake light itself. The kit should come with T Tap connectors.
You could tap into the tail light's running + brake light since it connects to the OEM car wire, but I tapped into my car's OEM wire instead.
Other than that, you just run the ground wire to the ground in the frame.
Clueless
The Following User Says Thank You to YamahaR86 For This Useful Post:
Old 05-09-2016, 05:08 PM   #6
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Also, the rubber grommet for the weather seal, what I did was depin the stock connector, took it off and put the new one on/looped it in for an OEM look even though you can't see it.
Clueless
FS: Valenti taillights in red Reflex NY / NJ / CT / PA 6 07-04-2016 04:33 PM
Valenti taillights swp subie brz Exterior Parts (Aero, Lighting, Etc.) 7 11-29-2014 10:00 PM
Valenti Taillights!!! husker741 Cosmetic Modification (Interior/Exterior/Lighting) 3 11-07-2013 11:56 AM
