Old 05-08-2016, 03:51 AM   #1
Twells229
Drives: 2015 Firestorm Fr-s
Running rough on e85
I seem to have the opposite problem as everyone else who switches to e85 for the first time. I switched tonight, followed the exact instructions. I left my 91 uel tune until fuel trims went way high. Then I re flashed to e85 uel tune. Seems simple enough but after giving the ecu time to learn the new trims and getting the long term fuel trim to level out around -3%, the car is running really rough. It feels like it did when I had the uel without a tune. Felt great on 91 uel tune with oft, but now rough on e85. Also, I never had crickets until I switched to e85. Good lord those things chirp loud.
Sorry for the long post!
TL;DR: switched to e85 with oft, got crickets and runs rough.
Twells229 is offline   Reply With Quote
Old 05-08-2016, 06:45 AM   #2
Cal3000
Drives: Panda FR-S
Before you switched to the E85 tune, how much 91 did you have in your tank?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 05-08-2016, 06:54 AM   #3
saj
saj's Avatar
Drives: ̶1̶0̶ ̶S̶
Total'd.
But seriously, a pump may be advertised as "E85" but the ethanol level will be much lower. Be aware of what you're actually putting in your car.
saj is offline   Reply With Quote
The Following User Says Thank You to saj For This Useful Post:
86kahl (05-08-2016)
Old 05-08-2016, 01:11 PM   #4
Twells229
Originally Posted by saj View Post
Total'd.
That's what I'm thinking since trims are trending negative. I'll give it some more time to adjust and if it stays rough then I'll just go back to 91.
Also, the gas needle was on the red so I assumed I was about to run out but I put in exactly 11.5 gallons of e85 so there must have been two more of 91 in there.
Old 05-08-2016, 01:32 PM   #5
steve99
Drives: FT86
If your LTFT are only around -3% then the ethanol content is fine.
If it was low ethanol content your LTFT would be -10 or less
If ethanol content was high like 90% then your trims will be positive +5% or more.
Are the fuel trims around 3% over the entire rpm range ?
Take some logs
look for IAM =1
LTFT less than say 7% or so +/-
look at Commanded AFR and AFR(measured)
some cars run pretty rich on E85 on oft tunes.
Old 05-09-2016, 01:55 PM   #6
JSanders
FR-S Newb
JSanders's Avatar
The OFT is supposed to be able to run anywhere from E60-E90, which is the tolerance range that is regulated for E85 fuels. If you drive normally without pushing it for maybe 5-6miles after fill ups it should learn itself. I ran it for a couple months and could tell small differences between fill ups.
As for the crickets.... It's long since been determined that the ethanol in fuel caused the crickets... What did you think running 85% ethanol was gonna do... Haha. Learn to love the crickets, they are like your pets now.
"Driving is the synchronization of vision, analysis, and movement. It is an art form." -Unknown
JSanders is offline   Reply With Quote
The Following User Says Thank You to JSanders For This Useful Post:
Tcoat (05-09-2016)
Old 05-09-2016, 03:25 PM   #7
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I used to think ethanol caused the crickets, but when I'm on E85 I don't get them. It's only when I'm running E10 that the crickets tend to appear. I honestly think it may have more to do with lubricants in the fuel than anything else.
smg1138 is offline   Reply With Quote
Old 05-09-2016, 03:26 PM   #8
I am convinced it is the ethanol but only in the smaller percentages.
Old 05-09-2016, 03:28 PM   #9
JSanders
FR-S Newb
JSanders's Avatar
I had bad crickets on E85... I switched back to 93 last fill up cause I'm selling the car . Maybe it's because I already had crickets before so it just made it worse. Who knows haha
Sent from my XT1254 using Tapatalk
Tcoat (05-09-2016)
crickets, e85, idle dip, rough idle
Rough day for my 86 KiddCoast Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 33 03-23-2015 04:30 AM
ROUGH AROUND 2K RPM COLGATE Issues | Warranty | Recalls / TSB 25 02-28-2015 04:50 PM
'14 BRZ Ltd. - Rough Idle leicaboss BRZ First-Gen (2012+) — General Topics 20 05-22-2014 07:40 PM
Rough Downshift (bog?) from 3rd to 2nd... enwave Issues | Warranty | Recalls / TSB 8 08-29-2013 01:01 PM
sema rough nixeighty6 BRZ Photos, Videos, Wallpapers, Gallery Forum 0 11-01-2012 05:30 AM
