#10403 | ||
#FiftyShadesOfBlue
Drives: 2015 FR-S
![]() I'm just not a fan of camber at all. Id rather sacrifice that extra bit of handling to have the car look how I want since I'm not doing autox/track driving. It was nice to see the quick consensus for LCAs though and I did read about the whiteline being terrible to adjust
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
| The Following User Says Thank You to Tectoniic For This Useful Post: | Tcoat (05-05-2016) |
#10405 | |
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (05-05-2016), MisterSheep (05-05-2016), soulreapersteve (05-05-2016), Tectoniic (05-05-2016) |
#10406 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#10407 |
Wayward Member
Drives: Hot Lava 86
Quick, lowest displacement with the most cylinders. Mass produced engines only.
#10408 |
Killed Scion
uhhhh I know lotus came out with a 3L v8...
#10409 | |
There was a good chance for a roll in the hay after a couple of those ...... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | soulreapersteve (05-05-2016) |
#10410 |
Wayward Member
Drives: Hot Lava 86
Close, 3.5L, still a good size, definitely small enough. But not common enough.
| The Following User Says Thank You to Nevermore For This Useful Post: | MisterSheep (05-05-2016) |
#10411 | |
Killed Scion
3.4L v8 out of a Ford Taurus.. Smaller maybe more common. BMW's 3L v8 out of a E34 530i
#10412 | |
Wayward Member
Drives: Hot Lava 86
The ford would probably be easiest to get, but the BMW is probably nicer.
#10413 |
Killed Scion
The bmw one is probably nicer and might be easier to get.
#10414 |
Wayward Member
Drives: Hot Lava 86
#10415 |
Killed Scion
#10416 | |
Wayward Member
Drives: Hot Lava 86
In all seriousness if I went this route it would probably no longer be for an RX-7. If I was going to buy a BMW motor, I might as well stuff it into a BMW, which would definitely be a long way down the line because I know it wouldn't be cheap at all. The current choice car would be a 2002, which would probably move nicely under that kind of power. I'd want a shop to clean it up as best as possible, to coax at least a little reliability out of it. I'd explore ITBs/superchargers if I decided the little thing needed more power, but really 215 is plenty, and I love that it's a 3L V8.
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
