| DIY (Do-It-Yourself) Guides For all DIYs. |
#43 |
Marine Electrician
Drives: Toyota TRD86, 2014
Hi sorry for necro thread..
![]() But I just done with installing the TRD Oil Temp gouge, and connected the wiring as the OP did (but I still go the stereo, so i mounted the gauge itself on a different location) And when I connected the power, the gauge boot up, "reving" the needle, all lights are on and look epic, then the needle go down to 50, and the white lights shut down, then the red light in the arrow shut down, and then it's dead... I tried when car was on idle, disconnected the plug, that are connected to the gauge itself, and then reconnected it, and it did the same procedure then died again... So wth can I do to fix this ? Update: It was just a bad connection for the acc (ignition!) and a bad conmnection for dim, but found the issue, so all good now!
My Toyota TRD86 can be found here:
http://www.ft86club.com/forums/showthread.php?t=63303 Last edited by Teclis; 04-01-2016 at 11:20 AM. |
#44 |
Drives: White MT GT86 with TRD extras
Glad you got it sorted.
![]() Also glad your are liking your TRD 86. Had a look at your build. You can find mine here @Teclis. http://www.ft86club.com/forums/showthread.php?t=99536 |
| The Following User Says Thank You to Tech For This Useful Post: | Teclis (04-04-2016) |
#45 |
Drives: Toyota GT86
This thread helped me out with my install of these gauges so I thought I'd add my two cents. I wanted to keep my head unit so I did a custom install onto the dash panel. The panel I used was the Blitz Racing Meter Panel (only available in RHD) but there are plenty of companies that make LHD versions.
I also didn't use the sandwich plate to mount the sensors, as I wanted an oil cooler without double stacking sandwich plates and causing a leak. I mounted the temp sensor in the Oil Galley using an OEM Subaru WRX oil galley plug, which has a 1/8th PT threaded sensor hole in it already. I mounted the pressure sensor at the OEM low pressure sensor location, using a relocating pipe with a T fitting at the end. Works very well. Thanks to the OP for the wiring guidance, I wired it into the back of the head unit for power and functionality.
| The Following 4 Users Say Thank You to TRDness For This Useful Post: |
#46 |
Anyone have the mounting hole diameter size and the face dial size of the TRD gauges? Or maybe the install instructions? Thanks!
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#47 |
Nice install! @TRDness
| The Following User Says Thank You to Tech For This Useful Post: | TRDness (04-09-2016) |
#48 | |
Drives: Toyota GT86
http://www.trdparts.jp/manual_download.html
| The Following User Says Thank You to TRDness For This Useful Post: | stevesnj (04-09-2016) |
#49 |
Famous Potatoes
Drives: '15 ultramarine
I purchased a set. Where do they plug in (power)?
Thanks |
#51 |
Use the instructions
#52 |
Famous Potatoes
The instructions I have do not show where to plug in in any picture, and text is in Japanese.
#53 |
Famous Potatoes
I purchased just the Guages, not the plate that replaced the radio. It did not come wi the instruction sheet with the picture of the power behind the radio.
Thanks for your help. What a bunch of nice guys. |
#54 | |
May I suggest you go to page one of this thread where I explain in detail the colours of the wires you need to tap into and even show a picture of the wiring you need to access. Each gauge has a small white plug in the back of it which the loom plugs into. If you have just bought gauges without the wiring looms, then you are going to have problems! All the best...
DIY Threads I have started.
http://www.ft86club.com/forums/showt...18#post2624018 |
| The Following User Says Thank You to Tech For This Useful Post: | stevesnj (05-02-2016) |
#55 | |
Drives: 2014 gt86
Warning level reset?
#56 |
Wheels for Brains
You probably didn't wire the Hot/Always on power correctly. The gauges need one set of wires directly connected to an always live circuit to save the memory.
| Cyberstork gauges | ANREX | Cosmetic Modification (Interior/Exterior/Lighting) | 53 | 08-11-2016 07:07 PM |
| WTB: Gauges | AtlasMick | Engine, Exhaust, Bolt-Ons | 2 | 03-29-2013 01:04 AM |
| gauges where the radio is? | J-Money | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-05-2013 11:11 PM |
| GTS owners... difference between 'sports' abd 'vsc sports' button? | UnLeasHer | AUSTRALIA | 5 | 07-26-2012 04:22 AM |
| Gauges | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 07-24-2010 07:26 PM |
