#15 | |
Drives: WRB BRZ Sport Tech
So weird, I literally just thought about it being made of a billet material perhaps T7076 aircraft aluminum. Great minds think a like....😎 Nice job though! |
#16 | |
Drives: BRZ, STI, GT350R, Supra, 987.2
Opted for a steel due to the life this part will see. The thousands upon thousands of clutch presses would fatigue aluminum where steel has an endurance limit which we are staying above . Though I'm sure with a reasonable pressure plate and not the 1000 lb pressure plate I simulated, an aluminum unit could do just fine.Since the OEM units are breaking, figured rather over build it and take the weight penalty. |
| The Following 3 Users Say Thank You to VerusEric For This Useful Post: |
#17 | |
Project Shadow
Drives: 2015 BRZ Limited 6MT
| The Following User Says Thank You to Drakiv For This Useful Post: | R2RO (04-30-2016) |
#18 |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Might be interested in this as a back up unit for my custom reinforced stock fork. It sucks that Design Craft Fab basically is ignoring everyone contacting him for a fork, that's why I had evasive Motorsports just reinforce a spare one I had laying around.
Heres some photos of it: ![]()
#19 |
Drives: 10 series FRS
Really? I just spoke to Gary at DesignCraft and he said the initial batch he had made did not work so he was working on a new batch of 20. I have one of his prototypes thats been on my car with an OS twin plate for about 10,000miles. not a single issue so far.
I have his direct contact. Ill ask again. But cool to see someone else taking the initiative to make something. |
#20 | |
Regardless, I pulled the trigger on 30, so if he does make them, you guys will have two choices. Overall the unit I designed is 33% thicker in wall thickness over OEM, solid in a lot of it, and made from 4140 which is some pretty strong steel. |
| The Following User Says Thank You to VerusEric For This Useful Post: | R2RO (04-30-2016) |
#21 |
Project Shadow
yeah choices are nice but I already made mine and I am buying one of yours! I can't wait.....
#22 |
Drives: Lightning red 2014 brz premium
Interesting, i have no need for one of these at the moment as im still on OEM clutch, but i do plan on upgrading my clutch for drifting purposes and this would be a great upgrade to install while im in there anyway. Thumbs up for some quality R&D on a part commonly overlooked
#23 | |
Drives: '23 BRZ Limited
Is the clutch fork really seeing that much more force/use than the rear suspension? |
#24 | |
What is 46,000 3.5G bump loads? That is a car with extremely sticky rubber (lets say 295-325 slicks), with extremely large aero (1000+ lbs of downforce), with extremely hard suspension (12+k spring rate), hitting a racing curb full on, forty-six thousand times. We estimated this to be 5-10 years of use for some of the most dedicated time attack guys. I could see a clutch being pressed 50,000 - 150,000 times in a year easily. So yes, I do see the clutch fork seeing a high stress load more often than the rear suspension. Could I have designed a unit that would take the load and last 1 million cycles out of aluminum? Yes. However, to me, it just makes sense to make it from a chormoly, ensure it is under the endurance limit, and not think twice about it. The LCA unit had a goal of being significantly lighter than OEM. This unit weights approximately 7 oz more, it just doesn't seem worth it to me to try aluminum and have them break in 5 years because I guessed incorrectly at how many times a clutch is pressed in a year. Hope that explains it. |
| The Following 9 Users Say Thank You to VerusEric For This Useful Post: | aegisdrgn (06-19-2016), Calum (04-30-2016), Cole (04-30-2016), Drakiv (04-30-2016), Hawk77FT (05-02-2016), Hyper4mance2k (06-03-2016), ichitaka05 (04-30-2016), pleong (05-02-2016), Sportsguy83 (06-02-2016) |
#25 |
Drives: Velocity Orange 86 GT
What grade of 4140 will you be using out of curiosity. Pre-Hard, Annealed etc. Just curious as thats the kind of stuff I do and I'm always interested in seeing that kind of info. Just like the Control arms I think I spent way more time thinking out tool paths and looking at the milling surface finishes than most people would.
I do love 4140 though. Beautiful to work with. After working with 1045 and 4140 for almost every job I do, any time I go back to a 1018 mild steel its rather depressing. Love the surface finishes you can get so easily. |
#26 | |
#27 | |
I wasn't trying to make some veiled dig at your product, it was an honest question regarding duty cycles and work hardening. |
#28 | |
It is in the development thread: http://www.ft86club.com/forums/showp...&postcount=114 It is in our blog post: http://www.velox-motorsports.com/#!F...f26832893a5212 It isn't on the sales pages because we don't feel it is something to be concerned about as it should easily last the life of the car for everyone that isn't go full race car, and even those guys should get 50,000 cycles out of them, which could be 5 years, or 10, or even 20. *The LCA deformed at ~46k cycles at 3.5G bump load with a material that was 25% weaker than what we went to production with as well. We don't know where the production units end up fatigue wise but having 25% higher yield strength put any residing worries at bay for us.* Let me know if you have any other questions. |
| The Following 4 Users Say Thank You to VerusEric For This Useful Post: |
| Verus Engineering Brake Cooling Kit | VerusEric | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 100 | 07-15-2023 11:18 PM |
| Modular Hood Louver Kit - Verus Engineering | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 276 | 07-08-2023 05:03 PM |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 10:15 AM |
| Verus Engineering Billet Transmission Beta Tester Run | VerusEric | Engine, Exhaust, Transmission | 62 | 04-26-2020 02:44 PM |
| ▀▄▀▄ Vivid Racing | Cusco 86/BRZ Clutch Release Fork and Pivot Set | vividracing | Transmission and Driveline | 0 | 07-12-2016 02:32 PM |
