#29 |
Because compromise ®
Drives: Red Herring
I can't emphasize this enough.
#30 | |
Drives: '13 FRS - STX
Hypothetically every car would be different, where the gas tank is located, steering rack, ecu, battery, air conditioning, they're all placed in order to package everything well with enough space and to balance the car. Generally as it's a road going vehicle, designers assume 2x, 4x, 6x passengers, but when you're setting up for racecar, unless you've got a navigator in the passenger seat, you'll be designing for driver only (and designing around no driver is foolish unless you've got an autopilot), an extra 100-250 lbs on the left (or right) is inevitable in production cars. Most world cars are built the same though, your car probably comes out pretty close to the Vorshlag corner balance on page 1, steering wheel, rack, pedal box, brake booster, (battery on this car), a few things flip over, but all the major stuff remains the same, it's rarely a perfect mirror image. I put foot in mouth in this thread.
| The Following User Says Thank You to strat61caster For This Useful Post: | Captain Snooze (04-29-2016) |
#31 | |
Drives: Subaru BRZ Limited
Haha, I meant to see if you could come to some sort of trial business arrangement! |
#32 |
Drives: 2017 BRZ
#33 | |
#34 |
Drives: Red Herring
You tell them as much (or as little) as you can. Each damper set is made to order. So spring rates and damper curves are customised to the customer's requirements. For a person such as myself I would be relying on their expertise to give me a damper. I will discuss regressive damper curves with them just for a better understanding of damper design. I am in no position to request a particular curve.
What I thought was a little controversial was being told they do not offer 4-way dampers. Even their dampers for the V8 Supercar series are only 2-way adjustable. (There are only 3 sanctioned damper manufactures for the series: Sachs, Ohlins And Supashock.) They also don't use remote canisters.
#35 |
Drives: '23 BRZ Limited
If you aren't sure what to ask for, how is this crazy custom setup going to help vs one of the proven OTS options?
#36 | |
#37 | |
I'm curious.
#38 | |
Drives: Red Herring
Just because I can't tune BRZEdit doesn't mean I don't appreciate the small increase in power. I don't have to understand the workings to see a benefit. Having said that there is no guarantee at my level I would see a benefit. That remains to be seen.
#39 | |
This isn't meant as an attack, but if you can't figure out to put on the stock suspension or access other data to find stock Weight Distribution, can you really talk about hysteresis, where the "knee" is in the valving, etc. In reality, amateurs like us that may be quicker than most guys at a track day, typically still don't have the skills/feel, testing, etc, to spec dampers. It becomes kind of a "street cred" thing on what you spent. |
#40 | |
#41 |
Drives: Red Herring
This was only mentioned in passing but they said yes, they can do that. I intend to quiz them some more about that when I chat to them next.
#42 |
You have my attention
| Question About Negative Camber: More Negative Camber == More Grip at Corner? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 03-10-2019 03:08 PM |
| Question - Black OEM Shift Knob Weight | h8meh8ers | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-22-2015 01:41 PM |
| Turn Signal / Corner Light DRL Question | J_McElwee | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-18-2015 12:25 PM |
| Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 12:38 PM |
| A serious wheel question that goes beyond weight and appearance... | boredom.is.me | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 06-28-2012 11:41 AM |
