Old 04-27-2016, 06:32 PM   #1
Bahyruhn
Drives: '13 FRS 6MT WHITEOUT
New here.
My names Byron. Just purchased a used 2013 FRS 6MT. Whiteout.
Had a question. Never owned a RWD car before so I need to know if this is normal. When I'm at a dead stop and shift into first gear, I hear a "thunk" at the rear of the car. I'm assuming it's the diff catching. Was wondering if it's normal. Thank you.
Bahyruhn is offline   Reply With Quote
Old 04-27-2016, 06:38 PM   #2
drankejackson
Drives: subaru wrx
I don't think that is normal !
drankejackson is offline   Reply With Quote
Old 04-27-2016, 06:42 PM   #3
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
Originally Posted by 1future View Post
Commence the "totaled" jokes.
It's normal. Plenty threads on it if you just search.
Calling dibs on stock exhaust. Everyone wants it.
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz
Romanov is offline   Reply With Quote
The Following User Says Thank You to Romanov For This Useful Post:
MisterSheep (04-27-2016)
Old 04-27-2016, 06:48 PM   #4
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
When's the part out??
Instagram: trevor.parque
Old 04-27-2016, 06:48 PM   #5
MisterSheep
Killed Scion
In all seriousness you're fine, just being a little overly cautious of all the little noises this car makes.
Old 04-27-2016, 07:13 PM   #6
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Yes, its normal! And its probably the U joints, not the differential.
billwot is offline   Reply With Quote
Old 04-27-2016, 08:05 PM   #7
stevesnj
stevesnj's Avatar
Make sure you're pressing fully down on the clutch pedal before going into first.
My 2016 Build thread
Old 04-27-2016, 09:03 PM   #8
MasonL1997
MasonL1997's Avatar
Drives: Man
Send a message via AIM to MasonL1997 Send a message via Yahoo to MasonL1997
It happens in mine too. Pretty sure its the driveshaft being connected. Not 100% sure, if someone could chime in and correct me thatd be great. To not get the noise, press the clutch in, wait a second or two, then shift into first. You shouldnt get the noise then.
MasonL1997 is offline   Reply With Quote
Old 04-27-2016, 09:16 PM   #9
extrashaky
Drives: 2014 BRZ Limited
It's 100% normal.
When you're sitting there with car in neutral and your foot off the clutch, the clutch is engaged with the flywheel, and the input shaft of the transmission is spinning. Power doesn't go all the way through, obviously, because the transmission is not in gear.
When you push in the clutch, you disengage the clutch from the flywheel, so power is no longer being applied to the transmission input shaft. If you hold the clutch there for a few moments without doing anything else, the input shaft will slow down and stop.
However, if you immediately put the car in first gear right after pushing the clutch, before the input shaft stops spinning, the momentum of the spinning shaft will try to spin the rest of the drive train. You get a little bump all the way back to the differential as the gear in the transmission stops the input shaft's momentum. That's the clunk you're hearing.
It's normal. It doesn't hurt anything. If it bothers you, just leave your foot on the clutch for a moment before putting it in gear, and you won't hear it.
This is probably not the weirdest thing about this car. You will also find other things that may alarm you but are perfectly normal.
The Following 3 Users Say Thank You to extrashaky For This Useful Post:
Clipdat (04-29-2016), kch (04-28-2016), Tan (04-29-2016)
Old 04-27-2016, 09:17 PM   #10
Sort of but the drive shaft is always "connected" to the tranny. There are a whole bunch of things between the engine and the wheels in a RWD. When you go in gear they all have to sort of realign. That is what you hear. Not sure how waiting a second makes any difference though since there is no pressure on all those bits until you let out the clutch (see edit). You will hear all sorts of weird noises in these cars since there is only paper thin soundproofing.
Edit: Ya Extra nailed it. I was presuming that you were already stationary for a bit when you were letting the clutch out so the shaft had already stopped.
MasonL1997 (04-29-2016)
Old 04-27-2016, 09:27 PM   #11
extrashaky
My favorite quote on the board regarding this:
Originally Posted by Jyn View Post
I like the clunk. Means shit is happening.
I LOL'd.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
finch1750 (04-29-2016), Tcoat (04-27-2016)
Old 04-28-2016, 12:03 AM   #12
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Send clear audio clip so we can properly access the situation.
ToySub1946 is offline   Reply With Quote
Old 04-28-2016, 12:06 AM   #13
Welcome, Bahyruhn and congratulations on your purchase ......
Yep, lots of things tighten up when you apply torque through the powertrain.
I wouldn't worry about a mild clunk unless it gets louder.
wireman957 (05-01-2016)
Old 04-28-2016, 04:28 AM   #14
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The key to getting rid of wierd noises you don't underatand is catless headers and a really nice exhaist
lol. but like others said its pretty normal
SlammedSilly (04-29-2016)
