Old 04-25-2016, 11:16 AM   #435
Wepeel
Drives: '13 BRZ Ltd
Tested these tunes out, and for my car they seem a little too aggressive. I was getting up to -3.9 FLKC consistently at high load high rpm in 2nd gear autocross. On the previous tune I only ever really saw corrections in the -0.65 range occasionally. Only mods are OFH and Berk catted FP. I'll be switching back to the standard 93 tune.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Timmy_Jones (04-25-2016)
Old 04-25-2016, 02:06 PM   #436
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Noxcyn View Post
Hey guys, Im new to the whole logging thing. Correct me if im wrong. Knock happens or should be worried about if the Knock correction drops below -1 or the IAM goes above 1?
Will I need to correct anything or is this fine?
I have attached a few logs, i have noticed Knock Correction goes from 0 to -0.4 to -0.8 randomly.
I am running 91Oct (from ESSO) with the new Stage 2 tune with my OFH and Invidia Q300 Catback
http://www.datazap.me/u/noxcyn/log-1...log=0&data=2-8
http://www.datazap.me/u/noxcyn/log-1...log=1&data=2-8
http://www.datazap.me/u/noxcyn/log-1...log=2&data=2-8
You only have knock 3 times in 2 logs then finally 1 time in the last log, also your IAMs are fine they should be at 1 that means you have quality fuel
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Noxcyn (04-26-2016)
Old 04-26-2016, 01:48 AM   #437
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
I just received my 1320 UEL Header and as soon as install was done I went to Stage 2 UEL tune.
If you guys don't mind a quick look, I'm sorry if I'm a newbie but I don't know yet what to do with this data so I just want to make sure my car is okay.
http://datazap.me/u/roneezy360/1320-...1?log=0&data=1
Roneezy is offline   Reply With Quote
Old 04-26-2016, 02:09 AM   #438
Noxcyn
Noxcyn's Avatar
Drives: '15 Scion FR-S - Ashphalt (MT)
So do I need to fix that or is that acceptable? Thanks btw much appreciated 😀
Noxcyn is offline   Reply With Quote
Old 04-26-2016, 02:27 AM   #439
FRSBRZGT86FAN
It's fine, if thats the highest octane fuel you can get.
Noxcyn (04-26-2016)
Old 04-26-2016, 02:29 AM   #440
FRSBRZGT86FAN
http://datazap.me/u/roneezy360/1320-...s?log=0&data=1
Something is wrong with your IAM reading 0, what octane fuel did you put in?
Also you have quite a bit of knock correction but they are very small corrections
Finally what's the point of data-logging the stage 2? You should datalog and run the OFH tune to see if that's safe.
@steve99 is this a glitch?
Roneezy (04-26-2016)
Old 04-26-2016, 02:36 AM   #441
steve99
Drives: FT86
looks like a glitch if IAM was actually zero the KC Learned would be zero as well as the KC learned as displayed in log = [Value in Knock correction Max A table (rpm/load) * IAM] + FLKC (which can be + or -)
ie if IAM=0 then Knock correction advance should be zero which it is not
you can also look at the total Ignition timing = Base B + (Knock correction Max A * IAM) + FLKC
The Following 2 Users Say Thank You to steve99 For This Useful Post:
FRSBRZGT86FAN (04-26-2016), Roneezy (04-26-2016)
Old 04-26-2016, 04:34 AM   #442
Roneezy
Roneezy's Avatar
Here in San Diego I run 91, and I data logged stage 2 because I thought that was the proper tune after getting my UEL header installed. I did 91 oct stage 2 UEL 6AT tune.
I'm really new to all this, thank you for the help.
I am also pulling CEL code p2096... I installed a 1320 header/op today and couldn't remove the o2 spacer so we just left it on. Idk if that's the problem but theres this super annoying fluttering noise when my foot is on the gas so I'll be removing the header tomorrow and installing tomei UEL.
Just mentioned that ^ because maybe that'll help diagnose this problem?
Old 04-26-2016, 04:48 AM   #443
FRSBRZGT86FAN
Fluttering noise usually means an exhaust leak and P2096 tends to coincide with it.
Old 04-26-2016, 04:51 AM   #444
Roneezy
Roneezy's Avatar
Would it be okay to do a 2 hour drive tomorrow? I'm trying to pick up the Gruppe-S UEL header(unbranded tomei) so I can swap out this dang header... I just want to be sure I'm not harming anything with a 2 hour drive tomorrow.
The performance shop I got it installed from said the welds and stuff done on it looked like ebay lol. I thought 1320 was good but I guess I was wrong..
Old 04-26-2016, 10:51 AM   #445
Dru670
Drives: 2016 Scion FR-S
I have a 1320 uel and it is difficult to remove the 02 spacer but I managed to. I'm completely satisfied with it no issues at all no cel too.
Dru670 is offline   Reply With Quote
The Following User Says Thank You to Dru670 For This Useful Post:
StayPuft209 (04-27-2016)
Old 04-26-2016, 02:08 PM   #446
Roneezy
Roneezy's Avatar
Tried everything and couldn't remove the 02 spacer... it's literally stuck on there lol
Old 04-26-2016, 02:12 PM   #447
FRSBRZGT86FAN
Will be alright, just get the gruppe, much better header
Old 04-26-2016, 02:15 PM   #448
Roneezy
Roneezy's Avatar
Yeah... waited 3 months on this 1320 header/op just for this to happen... I'm gonna have to drive 2 hours to pick up the gruppe now. Hopefully no damage will be made to my car driving there.
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 12:56 PM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 01:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 02:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 07:30 AM
