Old 04-20-2016, 10:43 AM   #15
Originally Posted by kch View Post
No gearing, per se. Each rear motor has a reduction gear of sorts, and that's it. No shifting, no final drive, no gearshifts.
So many people just do not understand that electric vehicles do not use gears or any form of traditional transmission. They don't need to since in theory the electric motors speed is only restricted by the amount of power available. Internal combustion engines are restricted to how fast they can turn over by their very nature so you need a method to take that relatively slow speed and increase it to usable levels. Electric motors just go faster and faster. You can even just stop and reverse the motor whenever you like with no risk of damage. Of course this is a really bad idea if traveling at speed though. I alway get the strangest looks when doing forklift training and I point to the pedal on the floor that has forward and reverse all in one unit. A good forklift driver can go all day and never touch the brakes but just control his whole speed by switching to reverse while moving.
Old 04-20-2016, 11:51 AM   #16
Stratoside
Stratoside's Avatar
Drives: Firestorm red MT FR-S 2013
Originally Posted by SmileyMe View Post
Honestly this would be my like super long term dream. To do an electric engine swap in like 5 years when the batteries are better and I can afford to play around.
you don't just swap gasoline engine with electric motor, doesn't work like that
you are going to be swapping pretty much every single moving parts of the car if you want to convert it to electric vehicle, if possible at all
even if you do that, where would you put the batteries?
how are you going to charge it? have to take out the gas fuel tank and stuff
are you going to be adding regenerative braking? what's going to control that?
probably have to get new ABS
new computer to control the motor too
have to take out the transmission and the exhaust as well
too much work and not worth the money
Stratoside is offline   Reply With Quote
Old 04-20-2016, 12:17 PM   #17
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
Actually, I think you'll see commercial conversion kits at some point. Once you remove the exhaust system, gas tank, etc; most cars will have some room to work with.
Not trying to say it will be easy or awesome, but someone will think it's fun/worth it to convert their car.
Edit: I mean universal/sized kits, not kits for BRZs.
GeorgeJFrick is offline   Reply With Quote
Old 04-20-2016, 12:27 PM   #18
Nope don't see it. As was pointed out there is very little the same between the two systems. Electric (electric only not hybrids)cars are not just a motor that drives the wheels like IC.
Old 04-20-2016, 12:40 PM   #19
nisti
nisti's Avatar
Drives: BRZ & XV
For what it's worth, I just received a survey from SOA for my 2016 BRZ.
One of the questions asked if I had considered other trim levels besides the one I bought.
And in parenthesis said this:
(Premium, Limited, Premium Hybrid Turbo)
Not sure if that was a mistake, or a nip-slip.
nisti is offline   Reply With Quote
Old 04-20-2016, 12:40 PM   #20
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Its not just the exhaust, gas tank and engine you're removing though. You're removing the entire powertrain. Engine, transmission, drive shaft, LSD, rear axle, etc.
Such kits will probably also never be street legal or cost way too much for a company to make a street legal kit since batteries can be a huge fire hazard.
Old 04-20-2016, 12:47 PM   #21
GeorgeJFrick
http://e-volks.com/index.html?
Old 04-20-2016, 01:11 PM   #22
Notice the size and vintage of those cars. Yes, you could convert as a novelty sort of thing but those kits are little more that golf cart systems adapted to very, very limited use cars. They are not practical application vehicles.
Old 04-20-2016, 05:13 PM   #23
extrashaky
Drives: 2014 BRZ Limited
Wow. Neato. They took a car that is almost perfectly balanced front and rear, added 100 lbs and shifted almost all the drive train weight from the front to the center and rear. This thing would handle like shit. More than a few people would put it in a ditch the first time they took it out on a winding road when the front wheels cut loose in a turn.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (04-20-2016)
Old 04-20-2016, 05:27 PM   #24
Meh I didn't even bother going down that road since slapping an electric motor into a standard drive train car is not really making a viable electric car in any way shape or form anyway. It is simply changing the power source resulting in short unsustainable drives. Be OK for a couple of laps around a track and then done until charged again anyway.
Old 04-20-2016, 10:43 PM   #25
extrashaky
The Jalopnik article says it's a plug in hybrid with an initial range of 50 miles before needing the snowmobile engine mounted up front to recharge a battery pack sitting in the transmission tunnel. It should be every bit as viable as any other hybrid.
They say their goal was to show auto manufacturers that a sexy performance hybrid was possible. They're a little late on that. There are already several hybrid sports cars on the market. They are fixated on a question that has already been answered.
But while their end result may be sexy, but the only performance they have considered is straight line acceleration. Yawn. To get it they basically ruined the handling.
All around I call this a fail. They should have just stuck to calling this what it really was: a vanity project for their tech program that will end up getting parted out.
Tcoat (04-20-2016)
Old 04-20-2016, 10:50 PM   #26
LOL When I read it I must have scrolled past the part that said about the charging engine! I have been talking straight electric cars throughout this thread and now feel a little silly! Ya, totally viable as a hybrid (how did I miss all the hybrid references? GEEEEEZ)
Old 04-23-2016, 05:10 PM   #27
EZBRZY
Drives: Black BRZ Limited 6MT
My favorite part of the 2nd video - "outperforms today's car's, hands down".... as it passes a ~2002 chevy camaro
EZBRZY is offline   Reply With Quote
Old 04-25-2016, 12:03 AM   #28
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
There's already a hybrid 2000GT in Japan last year.
[ame="https://www.youtube.com/watch?v=CzCTVc4hz8I"]Rocky Auto RHV -TOYOTA 2000GT-HV SUPER REPLICA- 試乗 - YouTube[/ame]
krayzie is offline   Reply With Quote
hybrid keeps up with brz? youcantseeme24 Engine, Exhaust, Transmission 46 06-02-2014 04:20 AM
Who needs a hybrid!? ntr0py Scion FR-S / Toyota 86 GT86 General Forum 43 08-30-2013 01:37 AM
GT 86 Hybrid. Would you? russv Scion FR-S / Toyota 86 GT86 General Forum 74 03-13-2013 04:31 PM
FT-86=Hybrid?!? Please say it ain't so... BoostJunkie Scion FR-S / Toyota 86 GT86 General Forum 60 08-31-2010 10:38 PM
Is it the LFA HYBRID?? Dark Other Vehicles & General Automotive Discussions 6 04-27-2010 10:37 PM
