Old 03-30-2016, 10:37 PM   #309
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Should I be worried or checking on anything for a set of used Ohlins that I bought from a member here? 15K miles, has never seen any inclement weather (including rain!). Claims that there was a few track days and has babied his car, which I definitely believe from the way he presented himself.
Any advice is appreciated!
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 03-30-2016, 10:51 PM   #310
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I too read this thread thoroughly, as well as all the rest. Everyone's reviews and setup info has been very helpful, it's much appreciated!
Make sure everything is torqued (mounting hardware and such), check for any obvious leaks (note that they're assembled with some assembly lube so my shafts got "wet" looking brand new), check the stroke of the damper is smooth and respond appropriately to the damping adjustment knob, and I'd check that they're set back to Ohlins' recommended setup regarding preload and such as springs settle and you may want a different height setting.
It's not tremendously expensive to get them rebuilt or revalved by Ohlins USA and we have MUCH better support here in the US than a lot of countries, from the sounds of it. I know a few other friends with Ohlins and they've had amazing support if they had issues, which were user error or general old age (5+ year old race dampers, lol)
Old 03-30-2016, 11:00 PM   #311
x1UP
One & Done (AOZORA)
x1UP's Avatar
Thanks for this. I'm having my performance shop inspect it when it gets there and that should be reassuring. I just want to make sure that before I take off my OEM suspension, putting these used Ohlins won't make me go crazy. I have high praise for Ohlins after reading this thread and i've been talking to Jake from Ohlins USA about it.
The member is sending everything (I mean everything) when he first bought it. Including instructions and what not.
Anything else that I should be looking at / be worried about?
Old 03-30-2016, 11:11 PM   #312
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Make sure the threads are clean before spinning any of the collars. Otherwise, no, not really. I haven't had mine for an extended period like some other folks here, but I've had and/or been around coilovers for most of my car life. They're no different from any other shocks when you get right down to it.
Old 04-02-2016, 05:00 PM   #313
DevArenaCN
DevArenaCN's Avatar
Drives: Scion FR-S
I was wondering if anyone experience the M12 nut come lose( the one on the top of the front coilover above the plate) Mine came lose the second time and I'm thinking if I need locktite for it.
DevArenaCN is offline   Reply With Quote
Old 04-02-2016, 05:34 PM   #314
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
If mine comes loose it'll be getting loctite.
The Following User Says Thank You to DocWalt For This Useful Post:
ajc209 (04-02-2016)
Old 04-02-2016, 05:39 PM   #315
ajc209
Drives: GT86 Cosworth
Ditto.
ajc209 is offline   Reply With Quote
Old 04-17-2016, 09:37 PM   #316
DevArenaCN
DevArenaCN's Avatar
Drives: Scion FR-S
After two HPDE it does not seem to come lose anymore. Not sure why but as long as it does not happen again I'm good. I'm going to use locktite when it comes lose again.
The Following User Says Thank You to DevArenaCN For This Useful Post:
DocWalt (04-17-2016)
Old 04-17-2016, 10:12 PM   #317
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I've got 5 autocross events and a few thousand miles of street driving. No issues so far Hoping for no issues at the HPDE next month.
Old 04-26-2016, 09:51 AM   #318
ballsdeep
ballsdeep's Avatar
Drives: Ocho-Seis
Did any one else run into issues with endlinks hitting Ohlins coilovers? I bent my new Whiteline end links already...
ballsdeep is offline   Reply With Quote
Old 04-26-2016, 10:24 AM   #319
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
You need to use the 10mm spacer that Ohlins includes with the coilovers or that exact problem happens. You can't see the spacer here, but you can also see how close it is to the coilover even with the spacer installed. Oh, and the washer goes on the link side of the swaybar, not the nut side.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
tato.valverde (04-26-2016), TofuJoe (01-10-2017)
Old 04-27-2016, 12:29 AM   #320
ballsdeep
ballsdeep's Avatar
Drives: Ocho-Seis
Thanks Doc!
Old 04-27-2016, 09:42 AM   #321
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Thanks Doc!
Thanks go to @mav1178 (see here: http://www.ft86club.com/forums/showp...&postcount=239) cause I would have done exactly the same thing.
Old 05-19-2016, 07:44 PM   #322
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
I managed to mate the 20mm adjustable Whiteline sway bar and endlinks with Ohlins only using the 2nd (firmer) hole. Used the spacer and couple of washers but still the clearance is minimal. Tomorrow will try replace the endlinks with Hotchkis ones which are much thinner. Already clear that I'll have to shorten the Hotchkis endlings by at least 3 cm to make it happen... Ohlins have very unique design, nothing like any other coilover for this car which makes putting together various tuning parts a head ache
Efferalgan is offline   Reply With Quote
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 06:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 01:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 05:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 04:27 PM
