#351 |
Drives: 2013 Subaru BRZ Limited (Black)
#352 |
Drives: 10 Series FR-S #207
This is like Christmas, feels like I've been waiting that long! lol
#353 | |
You literally said "higher numbers are leaner"
#354 | |
Drives: JAWS
The OFT tunes are set to run around 12 Open Loop, hence why he'd actually be running lean. BUT, I believe he confused closed loop and open loop. |
#355 | |
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
If so , can you send it to me? otherwise i have a go myself. |
#356 |
Drives: 2014 Subaru BRZ LTD 6MT
Feel bad about asking this here but this thread has lots of activity. My Gruppe S header is sitting on my coffee table, begging to be bolted on. Problem is Ft86speed factory took 5 days to ship my OFT and now it won't get Here till Monday/Tuesday. If I go ahead with the install tomorrow, will it mess with the stock tune and thus the OFT will save a sort of ill-running stock tune when I plug her in upon recepit? Or should it all be fine and I just go ahead and install header and flash when my OFT arrives?
Thanks for any answers and sorry for asking here.... |
#357 | |
Nothing "messes" with the stock tune so don't be afraid you can go ahead and install it. You'll just get a CEL after install which will be easily cleared when the OFT arrives. To prep for your OFT however download the openflash manager: http://www.openflashtablet.com/downloads/ and also those other two things below
#358 | |
Drives: Toyota GT86
Flash and go
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#359 | |
Drives: FT86
Guys just be careful @ST-A is using tactrix so his A00G rom is a real A00G rom @elBarto is using an OFT A00G rom which is rearly an A01G rom calid hacked to look like an A00G. now with those two rom is ok as defs are compatible from memory but just be careful , its not always the case :-) |
#360 |
Drives: Firestorm '13
I think something happened when i transitioned from e85 to the new ofh tunes. I took the car for a spirited drive to burn the rest of the e85 and it may have killed my o2 sensor. My STFT are 0 while my afr is between 12.5-13.5 while idle or cruising. When the car is cold it is normal but as the car warms up it goes rich and stft go zero no matter what throttle input.
'13 Firestorm
#361 | |
Drives: 2014 BRZ sterling silver
#362 |
Just did a 3rd and 4th grear pull. feels good and data looks close maybe just a little tweeking. Tell me what you think. http://datazap.me/u/oldgunfan/new-of...a=1-2-3-5-9-14
#363 | |
It looks fine on the safety front, you're IAM is steady at 1 and you have 0 knock correction throughout the entire log. AFR is getting close to 11 under load but I think it's fine because the rest of the time it goes above 12
#364 |
Drives: 2016 Scion FR-S
I wonder if this tune would be produce less lower in temps above 80F compared to the older tune...I live in Vegas and it is almost 100F+ time in the summer.
| Just how noticeable is OFT+OFH and stage 2 tune? | BBYZILA | Software Tuning | 58 | 03-20-2018 11:56 AM |
| OFT 2.0 Stage 1 93 Tune | MurderRider | Software Tuning | 57 | 03-21-2016 12:30 AM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
| FA20club.com Turnaround Times On Modified Tune Files | FR-S Matt | Software Tuning | 103 | 11-13-2013 01:48 PM |
| So whate does stage 3 tune do? I already have 2 | Frsexxxy | Engine, Exhaust, Transmission | 17 | 05-14-2013 06:30 AM |
