Old 04-15-2016, 12:54 PM   #1
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
Need help finding source of power without key in the ignition
As the title says, I'm looking for a source of +12V when you unlock the doors and the key is not in the ignition.
So you can better understand what I'm doing, I'm making custom lighting using a micro controller but I don't want the controller to be on 24/7. I want it to power on only when the doors have been unlocked with the key fob. I was going to use power from the dome light, but there's a pwm fade-in when the dome light first turns on, so that won't work.
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Old 04-15-2016, 12:58 PM   #2
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
The best I can think of is to take a multimeter and test the empty contacts in the interior fuse box (on driver's side, above the clutch pedal).
Not sure if our cars have anything that gets powered on when the doors are unlocked + ignition off that is also off when the door is locked.
The dome light works off the key sensors, but thats the only thing I can think of. Maybe figure out where the PWM module is and tap the power right before it?
Old 04-15-2016, 04:54 PM   #3
itsAlex
itsAlex's Avatar
I just might do that, do you know where I should start looking to find such a module?
Old 04-15-2016, 04:57 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
there are some blank spots in the fuse box. I used one of those to wire my Sped D headlights boomerang to be one when the key is in the on position but off when the key isnt in the ignition. It works great
Old 04-15-2016, 05:01 PM   #5
itsAlex
itsAlex's Avatar
Unfortunately that won't work for my needs, I need a power source that's on when the doors unlock but no keys are in the ignition. I cant pull power from the dome light due to it's PWM function.
Old 04-15-2016, 05:07 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
tap the door locks to activate a relay on a timer so it waits like 30 seconds or w/e to turn off again and pull power direct from the battery???
Old 04-15-2016, 05:21 PM   #7
itsAlex
itsAlex's Avatar
That would work too, but I don't feel like going through all that work unless its absolutely necessary aha. There has to be a way to get power for what I want!
The Following User Says Thank You to itsAlex For This Useful Post:
go_a_way1 (04-15-2016)
Old 04-16-2016, 01:42 AM   #8
darko
Drives: RAVEN FRS
Does the power need to be on constantly? You could tap into the side marker power wire, when you unlock the car, those go off
darko is offline   Reply With Quote
Old 04-16-2016, 12:44 PM   #9
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
There is an always hot empty fuse on the interior fuse box. I forget which 1, but it's on the right side (if ur sitting in driver seat)
lbroskee is offline   Reply With Quote
Old 04-16-2016, 01:37 PM   #10
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
This doesnt answer your question exactly but it is another possible solution.
Here is an Arduino with a built in Battery charger:
https://www.sparkfun.com/products/13614
It needs USB 5V input to charge a 4.2V LiPo, but if you hooked that to a switched power source, it would charge the battery so that it would probably remain powered for months without a drain on the battery.
Just an option
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
Pacific (04-17-2016)
Old 04-16-2016, 02:33 PM   #11
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Edit: Nevermind, didn't fully read\comprehend your post, but I'll leave this here anyway.
Buy the Option Connector Harness from svxDC: http://ae64.com/Rear-camera-16-pin.htm
It plugs into an unused socket behind the radio. It has a lead for 12+ accessory, 12+ constant, and ground.
B-R-Z is offline   Reply With Quote
Old 04-16-2016, 03:36 PM   #12
White64Goat
Have you checked the power outlet in the glove box yet?
Power Source behind Radio? 636 Electronics | Audio | NAV | Infotainment 2 12-13-2014 10:20 PM
Ignite the Power Inside of Your Engine with the Ignition Special at FR Sport! FRSport.com Announcements, Contests, Giveaways 0 07-25-2014 01:46 PM
Where to find ignition wire? One that gets power at key position 2 HRTROB Electronics | Audio | NAV | Infotainment 1 04-13-2014 01:44 AM
Recommend 12v Power - Ignition On Doc Scion FR-S / Toyota 86 GT86 General Forum 2 11-24-2012 03:34 AM
Power source in headliner? BoostedWrbBrz Electronics | Audio | NAV | Infotainment 2 11-10-2012 05:36 PM
