Old 04-12-2016, 05:29 PM   #2857
stockysnail
Just the tip
stockysnail's Avatar
Hey sorry I was out of the country last week...did you call in and talk to Myles?
- Andrew
No I didn't call him to discuss camber recommendations. Since I only have the Whiteline camber bolts, which give minimal camber increase, I ordered the Moore Sport adjustable top hats which should give -3 more in the front. They were recommended by another guy I know in my area that is big into autox. They have a KW/Tarmac specific model too which was nice.
http://www.mooresport.com/indexe.php...ble-top-mounts
Old 04-12-2016, 06:30 PM   #2858
Gotcha. Yes the MSI stuff is quality...they make great parts.
You can get -2.5 ish up front without plates but for -3 yeah get them.
-3 front, -2 rear is a good aggressive set-up. 0 toe front, very slight toe-in for the rear.
- Andrew
stockysnail (04-13-2016)
Old 04-13-2016, 01:46 PM   #2859
stockysnail
Just the tip
- Andrew
Andrew I'm guessing that I would be removing the spacer that I have in addition to the OEM top hat when installing the MSI top hat? Or would I keep the spacer with the new MSI top hat? I have the Tarmac 2s.
Thanks
Old 04-13-2016, 02:00 PM   #2860
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
- Andrew
I'm running the Mooresport top hats with OEM crash bolt and RCE T2. Got -3 camber in front with the top hats in the center slot/1 slot from center so I think there's room to go up to -5 or so.
infinity21 is offline   Reply With Quote
The Following User Says Thank You to infinity21 For This Useful Post:
Racecomp Engineering (04-13-2016)
Old 04-13-2016, 02:23 PM   #2861
Thanks
I'm not sure which spacer you're referencing? Got a pic?
- andrew
Old 04-13-2016, 02:23 PM   #2862
Right on, and yes I'd get more of your camber from the lower mount rather than the maxing out the plates.
- Andrew
Old 04-13-2016, 06:02 PM   #2863
stockysnail
Just the tip
- andrew
I'm referring to the Subaru Impreza metal washer/spacer Myles told me I needed in order to use the Tarmac 2 with the oem top hats in the front. OEM Conical Washers (Subaru P.N # 20326AA000)
I cancelled my order for the Mooresport top hats as they ended up being back ordered and my alignment is only days away. I'll just go with whatever max they can get using my whiteline bolts with oem top hats. From what I'm reading I should be able to get about 2.5 or so with the Tarmac 2 with Whiteline bolts. I'm not doing any competitive racing so it's not that big of a deal for me to have max camber. I just race for fun.
Old 04-14-2016, 01:11 AM   #2864
Ah yeah that spacer. Yeah that would depend on the camber plate (some include their own).
Yeah you'll be able to get a very good amount of camber anyway.
- Andrew
Old 04-14-2016, 03:32 PM   #2865
Tor
Tor's Avatar
Drives: Toyota GT86
Does the Whiteline KCA434 lower inner front bushing provide adjustability for the caster, or is it a set +0.5 deg more?
Tor is offline   Reply With Quote
Old 04-14-2016, 06:29 PM   #2866
DeaconRoc
Drives: GT86
Just had them fitted to mine - it's non adjustable.
DeaconRoc is offline   Reply With Quote
The Following User Says Thank You to DeaconRoc For This Useful Post:
Tor (04-14-2016)
Old 04-15-2016, 10:53 AM   #2867
Tor
Tor's Avatar
Drives: Toyota GT86
What's then the best way to zero out caster variances left/right? And what is an acceptable difference?
Old 04-16-2016, 05:13 PM   #2868
EvoPrecision8
Drives: 2015 BRZ Sport Tech
- Andrew
I came here to find this. Could you provide the technical reasoning behind this statement? Thanks
EvoPrecision8 is offline   Reply With Quote
Old 04-18-2016, 05:43 PM   #2869
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
The only real way I know of is to use caster adjustable top-hats or adjustable lower control arms.
I don't know what the spec offhand is but I think mine was about a degree off side to side stock and I didn't notice any real issues.
JozhGoober is offline   Reply With Quote
The Following User Says Thank You to JozhGoober For This Useful Post:
Tor (04-19-2016)
Old 04-19-2016, 02:49 AM   #2870
Ro_Ja
Drives: TOYOTA
So I'm playing around with Hyperco's spring rate calculator and I found a lot of information here and here, but what I can't seem to find are dimension A and dimension B for the rear. According to the research I've done, 98/100 is the approximate ratio for a McPherson strut, so I'm able to get a rough estimate for the front, but the rear is unknown to me. Does anyone know the two dimensions for the rear, so I can get a clearer picture of what rates I might prefer?
Also, what sort of suspension frequency would I be looking at for an aggressive street/light track vehicle? I'm currently hovering around 2.1 Hz front and 2 Hz rear per general information I've gathered. Does this sound correct?
Ro_Ja is offline   Reply With Quote
The Following User Says Thank You to Ro_Ja For This Useful Post:
andrew20195 (11-24-2016)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
