Old 04-10-2016, 05:35 PM   #1
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Front right clunk, tie rod scrape marks. EDIT: FIXED! :D
See 2nd page for fix.
Long story short, it was the bolt I least Suspected.
ORIGINAL MESSAGE:
Okay first off. Here is my set up.
Tein Flex Z - lowered maybe 1.5" - stock sway bar endlinks
Enkei rpf1 17x9 35 w 245/40/17
Recently with the last week there as been a loud AF popping noise going over decent bumps in the road, speed bumps, and into the driveway.
I went through all the motions, lifted the car, torqued every suspension bolt to spec, did some greasing etc etc.
Popping still there. I did notice that on my tie rod there is some scrape marks and I am beginning to think it is smacking the over pipe on the passenger side.
I literally have no clue if that is the source or what, but it is a loud loud noise.
Any ideas? Really need help on this one.
Photo of scrape
BDotG is offline   Reply With Quote
Old 04-10-2016, 06:08 PM   #2
other than that white shit on your stab bushing, what am I looking at?
Old 04-10-2016, 07:40 PM   #3
BDotG
BDotG's Avatar
The front tie rod, steering rack or whatever. That big scrape on it is from it hitting the over pipe or something.
Old 04-10-2016, 07:45 PM   #4
If that's your stock overpipe, yeah, I suspect a torn or loose engine mount.
Old 04-10-2016, 10:18 PM   #5
BDotG
BDotG's Avatar
Yikes. Wouldn't I feel that more though as opposed to just when I go over bumps?
Old 04-10-2016, 10:27 PM   #6
Kostamojen
Check your exhaust bolt hangar too.
But are you sure that mark isn't from the manufacturing of the aluminum steering rack housing?
Old 04-10-2016, 10:38 PM   #7
I admit it's a stretch. (accidental pun) Are you sure those marks are fresh?
@Kostamojen also has a point that it may just be where the parting lines were cut away.
Old 04-10-2016, 10:45 PM   #8
BDotG
BDotG's Avatar
Defs seems looks like scraping and not something that was from manufacturing. Will be taking the car to a shop to have them look.
Weirdest part is the noise doesn't sound like two objects banging together but more of like a robots elbow getting dislocated if that makes sense haha.
Old 04-10-2016, 10:49 PM   #9
Too bad we aren't in the same Vancouver. I'd help you check it out.
Old 04-11-2016, 08:32 AM   #10
Ashikabi
Ashikabi's Avatar
Take off your strut/coiliver whatever and see if you can move the knuckle up to a location that the tie rod collides with something. Maybe measure from the fender to the lugs so you know where it sits on the ground and start there? Check sway bar endlinks for binding too
Old 04-11-2016, 08:56 AM   #11
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Take a permanent marker and cover up the scrape, then see if it gets worn away again.
shiumai is offline   Reply With Quote
Old 04-11-2016, 09:26 AM   #12
Lonergt
Drives: '13 FR-S ultramarine
Not sure about the scrape, but mine clunks as well. I think it's just the sway bar bushings.
Lonergt is offline   Reply With Quote
Old 04-11-2016, 11:13 AM   #13
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
My Flex Z's make a LOT of noise as well.. ill check to see if i have this scrape mark
VIP BRZ is offline   Reply With Quote
Old 04-11-2016, 11:18 AM   #14
BDotG
BDotG's Avatar
Here is a sample of the noise. Whole way to work it didnt make it and then I hit one patch of road turning into the office and it did.
stock front drivers side suspension clunk. dkstylezz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-24-2015 01:19 PM
End link jarring/clunk (front) tr3o Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-09-2014 12:32 AM
Front bumper scrape raxman Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 11-30-2013 08:30 PM
Scrape much? Andrew360 BRZ First-Gen (2012+) — General Topics 54 12-05-2012 06:50 PM
Nooo, first scrape :( ubersoph Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-12-2012 11:07 AM
