#15 | |
Anyway, My basic suspension philosophy for this car right now is this: Stiff front swaybar, Softer/taller front springs... Soft rear swaybar, Stiffer/shorter rear springs... More quality dampening (shocks) less reliance on stiff springs (IE over-sprung) The rear suspension isn't capable of a lot of travel, unlike the fronts (Pretty common information bout the design of the Subaru rear subframe they use in this car plus the Imprezas/Foresters) and with the rear suspension unless you are running an expensive clutch pack rear diff, needs as much independence as possible to keep the wheels on the ground (as I learned running the stiffer rear bar). Some more background information... I used to have a '95 Impreza that was fully built suspension wise with EVERY single bushing in that car being replaced/upgraded (a couple of them took trial and error to reduce NVH) granted I had crummy coilovers for awhile that were over-sprung (Megan Racing, I had one of the first sets for the GC's) that car also had a front Helical diff and a rear viscous which made it VERY grippy and weighed about the same as the twins since I was running it N/A (EJ25 running about 180hp with mods). With that car, it was all about swaybars being almost even front/back and spring rates being almost even front/back. But that car had a Macpherson rear as well as front so it had a lot more travel in the rear than the BRZ does but wasn't multilink and had static camber. That car was OK to lift a rear tire because it didn't cause snap oversteer with the diffs I was running and I actually run rather mild swaybars for that car and focused more on using suspension settings to adjust the cars handling balance, but I did have to go through a couple swaybars to get that car right too. |
| The Following User Says Thank You to Kostamojen For This Useful Post: | Shankenstein (08-12-2016) |
#16 |
Drives: '13 BRZ Ltd
What is the spring rate in the front? Also, make sure you double and triple check the math on coil bind vs. damper/bumpstop travel. If you're using spacers to get the desired height with additional travel (perch threaded higher than without spacer) then you may start getting into coil bind territory depending on the setup. Especially since it's a somewhat customized setup.
#17 |
Did some freeway driving today with the current setup, wasn't that happy with the ride quality... I think the camber plates have compromised the ride enough to where the daily driving quality has gone from "acceptable" to "not comfortable".
As mentioned, I've had coilovers before and have experienced this, and I do personally think a lot of it has to do with the compromise of going from a suspension designed for street use which uses bushings in places to a coilover type suspension with full metal-on-metal bearings instead of bushings for camber plates (and even more so when you start swapping out suspension joints for bearings instead of bushings). So right now, I'm thinking of three possibilities on what to do next: 1) The all-out route: Go with 6" springs up front instead of 7" and up the spring rate from the ~225 now to ~275 or higher. Swap out the rear stock Bilstein springs for linear springs and go with Raceng rear tophats and go with ~350 6" springs. This would be an all-in approach and probably sacrifice any possibility at good ride quality... 2) The reverse-route: Try the 6" 275 springs up front but with the Group-N tophats instead of the camber plates and see if I can get the ride height OK with the shorter springs. This would be the least expensive option to try and get the car to where I want it with having linear coilover springs with good shocks and keep the Group-N/STI tophats to maintain a good ride quality as well... 3) The start-over route: Sell what I have now, go for Bilstein B8 shocks with either RCE Tarmac springs or another lowering spring that doesn't have even front/rear rates but still are nice and stiff, and use the Group-N/STI mounts. This would be risky with wheel clearance and expensive buying a whole new setup, and lose any height adjustability, but would probably be a good all-around setup... |
#18 |
Drives: BNR32
So your main goal is comfortable daily driving, as well as good performance for the odd AutoX event, is that correct?
Do you have any regulation limitation? Jerrick |
#19 | |
I only do local events and not entire seasons, so specific class rules aren't a big deal. Eventually I'm thinking CARB legal supercharger too which would be SM of course. As for "comfort" stiff is perfectly acceptable, but harsh is not. Harsh being vibrations and sharp hits from small bumps/imperfections in the road. Once upon a time I could daily drive a harsh car but maybe not so much now. |
#20 |
Drives: Subaru BRZ
What a mess.
Did you at least swap the mild steel washers for stainless? |
#21 | ||
Drives: TOYOTA
On the FRS, I currently have the the OTS B14s and HVT camber plates (stock rear rubber mounts, and all factory bushings). Unfortunately, I installed both at the same time, so I don't have the experience between stock upper mounts and the HVTs, but trying to compare it to my experience in my old car, the solid mounts do add a little bit of NVH, but it doesn't sound as bad as what you're experiencing in your FRS. I think my complaints about the B14s mainly stem from the soft progressive rates and the slightly underdamped(?) valving. Quote:
| The Following User Says Thank You to Ro_Ja For This Useful Post: | strat61caster (04-10-2016) |
#22 |
Drives: Fr-s
Are you sure that even with the increased travel top hats you aren't hitting the bumpstops with springs that soft?
#23 |
#24 | |
I'm thinking right now ill order some 6" ~275lbs front springs to try. Should I run helper springs though? |
#25 | |
Drives: '13 FRS - STX
fwiw I didn't experience any significant increase in NVH with my camber plates (Raceseng) aside from a minor rubbing of the spring perch at full lock over bumpy pavement (shit parking lot). The stock top hats are remarkably stiff compared to the other bushes on the car.
But why are you doing this? To go lower? I won't try and pontificate about the bumpstop as I don't have a great understanding of the reality of all the variables at play yet. But I will say this, it sounds like you can technically go lower on the fronts but don't because you want to have the springs pre-loaded. I say go max low in the front, yeah springs will be free but it's just a test, if that's too low you might be able to use the springs you have now and just add helpers. Note that if it's harsh because of the bump stop, changing spring rate will only have a minimal impact on comfort up front unless you alter the bump stop again. If you slam it and still want to go lower (and are ok with the harshness if the bump stop is in play) then you'll need to get a shorter spring and I would say helpers are a must. |
#26 | |
I do think the spring rates are a tad soft now, so thats why the 6" springs instead but with stiffer rates. The question is if they need helper springs and which helper springs to go with. FWIW, I'm very sensitive to changes in suspension. I've been able to notice specific differences with all sorts of parts, from individual bushings to fender braces and strut bars, and of course spring rates. Shocks I'm probably not too familiar with identifying rebound/dampening isolation but thats due to lack of experience with adjustable shocks... I have had single-adjustable shocks before and was able to dial those in (coilovers and those old AGX shocks for Imprezas). |
#27 |
I'm looking into the springs now, and here are a couple pics of some options:
![]() I'm thinking 280's for the front with the 6" spring, 336 is probably too much. That was what I was actually thinking for the rears if I go with the "all out" option, run those with Raceng rear 1" tophats. But if I go with helper springs, I have NO IDEA which ones I would pick! I'm starting to research methods for calculating helper springs, but I'm starting from zero on this so any input is appreciated:
#28 |
Drives: 14 brz
i think i have the 6 inch swift springs with helper springs/thrust plates sitting in a box in my garage. let me check the part numbers on them i cant remember if they are 6k or 7k springs. if you are interested i can make you a deal on them.
| CSG and RCE tag-team suspension Q&A thread! Ask us anything! | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4583 | 01-26-2026 10:41 AM |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| Krazy House customs and Sprintex's BRZ build | Krazy House Customs | Forced Induction | 14 | 04-20-2015 05:45 PM |
| Krazy House customs and Sprintex's BRZ build | Krazy House Customs | Member's Car Journals | 2 | 04-09-2015 01:53 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
