Old 04-08-2016, 06:07 PM   #1
adjusts
adjusts's Avatar
Drives: 86
Ebay TRD Spoiler?
so i just purchased an ebay TRD style spoiler for my raven black FRS. I got it from here.
http://www.ebay.com/itm/201249062728...%3AMEBIDX%3AIT
However, upon receiving my package, i noticed the spoiler does not i have double sided tape attached, it is simply just a spoiler and they gave me a packet of what seems to be some fluid. How would I go about attaching this? Any help appreciated, thanks.
[IMG][/IMG]
[IMG][/IMG]
adjusts is offline   Reply With Quote
Old 04-08-2016, 06:24 PM   #2
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Do you already have a factory wing on it ?
irax is offline   Reply With Quote
Old 04-08-2016, 06:29 PM   #3
adjusts
adjusts's Avatar
Drives: 86
yeah i do, but i plan on removing my oem wing to put this one on. any idea how i would go about doing it? It didnt come with double sided tape like it said it would.
shown below is the current wing on the car.
[IMG][/IMG]
Old 04-08-2016, 06:42 PM   #4
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
[IMG][/IMG]
NO WAY YOU GOT CHRISTIAN'S CAR!
Anyways to help you out a little, you can pick up some 3m double sided tape an most auto parts stores.. The OEM spoiler will most likely have had holes drilled into it so I would take off the oem one first to make sure that the new one you purchased will cover those holes.
If it does, great! this will be an easy project.
Clean off the rear trunk with some 50% alcohol and 50% water mixture in a spray bottle before you place the spoiler down.
place some 3m double sided tape on the parts of the spoiler that will make contact with the trunk.
Should be pretty self explanatory from here..
Instagram: trevor.parque
Old 04-08-2016, 06:47 PM   #5
kphan
Drives: 2014 Subaru BRRRZ
I used 3M tape to stick it on. Make sure to clean both the trunk and spoiler with isopropyl alcohol and take your time in lining it up. That liquid is a sealant I believe. I used it to seal off the contact point of the trunk and spoiler with the provided tool to get into the tight areas. Hope that helps!
kphan is offline   Reply With Quote
The Following User Says Thank You to kphan For This Useful Post:
MisterSheep (04-08-2016)
Old 04-08-2016, 06:56 PM   #6
adjusts
adjusts's Avatar
Drives: 86
is the liquid sealant required? I'd prefer not stripping paint if i ever find myself wanting to remove the spoiler. does the 3M tape have to be applied on all surfaces that make contact with the trunk? Or just certain areas?
The Following User Says Thank You to adjusts For This Useful Post:
Old 04-08-2016, 07:09 PM   #7
kphan
I used the sealant because I had issues with my previous car with water and dirt getting in there and lifted some of the tape. I put 3M tape around the perimeter where it made contact and I can tell you its super solid. I close my trunk with it sometimes.
Old 04-08-2016, 07:38 PM   #8
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
That is body silicone. I didn't bother with it. No issues whatsoever. Just got some 3m double sided tape and some adhesion promoter sponges and went to town.
BDotG is offline   Reply With Quote
Old 04-09-2016, 12:13 AM   #9
adjusts
adjusts's Avatar
Drives: 86
how would you go about applying the sealant? I have 3M tape in hand already.
Old 04-09-2016, 06:03 PM   #10
kphan
Just apply it using your finger to push into the gap then the tool to push it in and remove the excess. The sharper pointed edge was what I used to make sure the sealant went deep enough. Then I wiped it down with a damp towel and soap to make sure I got it all off as I went. It'll be pretty messy if you don't. You'll be able to see where you did and didn't seal it correctly.
Old 04-09-2016, 08:24 PM   #11
adjusts
adjusts's Avatar
Drives: 86
spoiler
If i wanted to remove the spoiler in the future, would it rip any of the body paint off? Excuse me for all the questions, haha.
BRZ Limited Spoiler. Is their any spoiler that uses the stock spoiler holes? FR-Sizzle Cosmetic Modification (Interior/Exterior/Lighting) 10 09-21-2015 03:29 PM
Spoiler from Ebay oppiee CANADA 3 08-19-2014 06:37 PM
Thoughts on eBay frontlip/spoiler/side skirts Evo2Brz Cosmetic Modification (Interior/Exterior/Lighting) 3 03-29-2014 04:36 PM
Cheapo eBay spoiler bfrank1972 Cosmetic Modification (Interior/Exterior/Lighting) 32 11-10-2013 03:23 PM
GT 86 Spoiler on Ebay mickey177 Cosmetic Modification (Interior/Exterior/Lighting) 20 07-08-2012 06:08 AM
