| Software Tuning Discuss all software tuning topics. |
Drives: AT Hot lava FRS
Automatic TCU tuning, anyone?
It's been a while since this post http://www.ft86club.com/forums/showt...t=46603&page=2 has there been any development in tuning the TCU on the AT, I'm assuming there's not much interest or there isn't that big of market to justify R&D (I may be incorrect?), but it seems strange that no one has unlocked the TCU and messed around with the AT trans? I'm aware there are mechanical upgrades that can be done but I'm talking about non-invasive/software tuning. Can anyone shed some light on this, are there any companies out there that have tuned the TCU on the AT twins?
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#3 | |
#4 |
Drives: 10 Series #974 6m/t
I have a manual....looks like the Auto box can hold more power...would it be something like a valve body upgrade?
#5 |
Drives: Toyota 86 GTS
Why do people keep asking about this? What exactly do you intend to fix? All the issues I've seen or heard about are due to hardware or fluid level or fluid temp.
| The Following 4 Users Say Thank You to Wayno For This Useful Post: |
#6 | |
I have no clue why OP wants it accessed, but I would like access to update the TCM logic alot of people have had problems where the dealership refuses to fix the weird "downshift issue" that recently had a TSB in the form of a logic update. I have it now and the shifts are much smoother and the idle feels much more stable, it'd be nice if others could get that as well.
#7 | |
Drives: 2013 Asphalt FRS
1. Shift points 2. Shift firmness 3.Main line pressure 4. High rpm shift hang ups 5. Torque convertor lock up 6. Stall speed rpms This is what I would start with.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| The Following User Says Thank You to FRS Justin For This Useful Post: | Silent_Dan (04-06-2016) |
#8 | |
Fast enough
Drives: 2013 Subaru BRZ AT
However...that being said, EcuTek can do some of these things. Moto-East was able to increase the line pressure via their tune and also alter a few other things with high RPM shifting on my car. What I'm not sure of it that was by directly changing TCU programming, or fooling the TCU by altering the ECU output to the TCU. For example, a stock car with the pedal only down 20% of the way might be programmed to shift with less line pressure than if the pedal was 100% down. Once you've doubled the factory HP though, chances are you'd need increased line pressure at the 20% throttle mark. What their tuning MIGHT be doing is telling the TCU..."hey I am at 100% throttle all the time. Shift as hard as you can every shift!". |
#9 |
Shift points would be nice, would be able to correct for the new power band.
#10 | |
I do like your theory on the tuning I wish I had a schematic to figure it out. I was researching doing away with the tcu and going full manual mode but haven't finished all the research yet.. It looks doable
#11 | |
Fast enough
That doesn't make any sense to me at all. A locked converter is directly connecting the transmission with the engine. Just like being in gear in a manual without the clutch depressed. No movement = no RPM's..... Your stall speed is essentially when you no longer have enough torque to overcome the friction between the the impeller and the turbine. I can't see how "locking" the impeller to the turbine would allow you to increase your stall speed. |
#12 | |
I hope I explained it well enough, I know how it works but suck at trying to spell it out. Here is a old article on a gm switch pitch 400 Kenne Bell worked on http://www.bdub.net/tranny/TwoTimer-...11-77-text.pdf
#13 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Yes, there is something you can do.
I thought that telling the TCU I had more power would cause it to shift later, and firmer. Absolutely, positively, not true. The TCU is programmed to shift sooner under heavier loads. It short-shifted so bad my wife didn't like it. The original was a bit better than +10, but -10 was better yet. I still don't know how far I can take it, but I might have to tell the TCU that the engine never makes over 100HP till it exceeds 1.2 load, or 5000 RPMs. I've gone a lot farther than my -10 table. So far, I'm just making the A and B tables the same, but I think one of them is for sport mode or something. Here's some pics of my latest table, versus the original table.
If I say yes, will that make you think I understand?
![]() Last edited by KoolBRZ; 11-24-2016 at 02:58 PM. |
| The Following User Says Thank You to KoolBRZ For This Useful Post: | Paulo86 (03-29-2018) |
#14 |
Drives:
| FR-S automatic transmission tuning | meadowz06 | Software Tuning | 23 | 03-03-2021 10:39 AM |
| Using handbrake with automatic gt86 and other issues with the automatic version | Tommygt86 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 04-06-2015 05:42 AM |
| tuning frontpipe does NOT fit on a Car with Automatic Gearbox | mister.bond | Engine, Exhaust, Transmission | 1 | 08-15-2014 06:46 PM |
| Vortech Automatic Transmission Tuning Released...FINALLY! | Brian@Vortech | Forced Induction | 2 | 11-02-2013 10:29 AM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 06:55 PM |
