Old 03-31-2016, 05:22 AM   #29
Dihudaxia
Drives: 86
Originally Posted by kkman View Post
I double checked and installed again today.
I took swaybar and endlinks off, then drove around,found the noise is still there.
Also I borrowed an abnormal sound diagnostic equipment from local mercedes benz service center. Put the headphone on while I was driving. Now we are 95% percent sure that the noise come from the damper. So, I guess my damper is almost dead. Must be Components inside the damper worn.
in your case, what happened then ? got a new one from ohlins? or just throw it away???
Cannot claim, as they say its wear issue.
So buy new coilover.
Did u try my suggestion to run full stiff?
Dihudaxia is offline   Reply With Quote
The Following User Says Thank You to Dihudaxia For This Useful Post:
kkman (04-01-2016)
Old 04-01-2016, 03:51 PM   #30
kkman
not yet been busy ,will try tomorrow or just buy a new kit,thanks bro.
kkman is offline   Reply With Quote
Rear BC BR coilover making noise PB-GT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 05-14-2016 03:58 AM
kw v3 rear making clunking noise eera Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-17-2015 05:10 PM
making the exhaust noise tolerable at WOT and being catless. BRZPDX Engine, Exhaust, Transmission 24 01-27-2014 01:20 PM
New rims and tires making a noise Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-21-2013 04:01 PM
Ballast Making Noise remorse87 Cosmetic Modification (Interior/Exterior/Lighting) 7 10-24-2012 11:35 PM
