Old 03-28-2016, 03:40 PM   #15
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Originally Posted by mrk1 View Post
I run a VTA can and just replaced the valve with a hose fitting of the correct threads, boom done.
I did it just for simplicity, one less thing to fail.
We did the same thing with both our race cars.
crazyfrenchbiker is offline   Reply With Quote
Old 03-28-2016, 04:11 PM   #16
armstrom
Drives: none
Most factory turbo cars get around this by having the PCV vent before the compressor inlet so the valve never sees boost, only atmospheric pressure or vacuum. Many people still install catch cans to avoid sucking oil into the turbo and ultimately coating the intercooler with oil. It's possible to install a catch can that does not vent to atmosphere though. That's what I did on my MR2.
-Matt
armstrom is offline   Reply With Quote
The Following User Says Thank You to armstrom For This Useful Post:
sroby (07-28-2020)
Old 03-28-2016, 04:54 PM   #17
mrk1
Drives: Sterling BRZ Ltd
The problem is not the material of the valve, plastic, metal, solid gold. The problem is the circuit was never intended to see positive pressure. Its not rocket science but it needs to be rearranged for boost.
Drilled out stock piece, no plastic
Plunger is metal, sticks to a magnet just fine
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
M1K3 (03-29-2016)
Old 03-29-2016, 12:20 PM   #18
mrk1
If people are paying for a "metal upgrade" what can I sell this High Flow Fully Ported valve for?
The Build Thread
Old 06-25-2016, 08:53 PM   #19
Rinzler_ft86
Rinzler_ft86's Avatar
Drives: 2013 brz limited edition
Where is this pcv located?
Sent from my SM-N920P using Tapatalk
Rinzler_ft86 is offline   Reply With Quote
Old 09-07-2016, 06:21 PM   #20
DHitHim
Drives: 2015 CWP Limited BRZ
Originally Posted by The Racers Line View Post
You don't replace the stock one because it is plastic, you replace it because it was never meant to see boost, so it opens up(under even 1psi from my testing) and lets boost into the crank case (bad)
A 19mm deep socket and a medium extension will get the old one out (it will be tight, but comes out) Screw the new STI one in by hand and then tighten down with the socket/ratchet.
Do I retain the stock one of I have a boomba valve. I'm running with a radium dual catch can set up
The passenger side hose on the intake manifold cover, follow it down and on the block is the factory PCV.
DHitHim is offline   Reply With Quote
Old 09-07-2016, 06:22 PM   #21
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Yup you are good with the boomba valve.
The Racers Line is offline   Reply With Quote
The Following User Says Thank You to The Racers Line For This Useful Post:
DHitHim (09-08-2016)
Old 09-08-2016, 04:58 PM   #22
DHitHim
So leave the stock valve in place and run the Boomba inline with it?
Also thanks!
Old 09-08-2016, 05:23 PM   #23
The Racers Line
Also thanks!
Yes
Old 12-08-2017, 08:04 PM   #24
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by zkv476 View Post
Yea idk who said the stock PCV is plastic; it is very much metal. I put in the one from the FA20F WRX.
Any reason they say to use the STI one? Is it better? Didn't even realize those were compatible.
Shouldn't be much difference. WRX/STI, both were made to see boost, so they both work for the application.
I bought the STI PCV valve for the EJ PN 11810AA040 and the spout was much smaller than the hose. PN 11910AA141 for the FA in the WRX has a proportionally fatter spout based on pics. Can anyone confirm the part numbers?
Old 02-05-2019, 10:36 PM   #25
switchlanez
Got a few private messages about this. Confirming part number 11810AA141 fit when I installed it.
The Following User Says Thank You to switchlanez For This Useful Post:
botbs (04-06-2022)
Old 07-28-2020, 04:10 AM   #26
86zn6
Drives: White GTS then Black GTS
should this the right part#? 11810AA131
https://www.blingstrom.com/diy-proje...0the%20vehicle.
86zn6 is offline   Reply With Quote
Old 04-06-2022, 11:52 PM   #27
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
So we should get the FA - 11810AA141 and not the EJ 11810AA040, am I correct?
Thanks!
botbs is offline   Reply With Quote
Old 04-07-2022, 08:30 AM   #28
KillerBMotorsport
KillerBMotorsport's Avatar
You guys should just consider just modifying the PCV system so it's the same as on a WRX/STi. VTA is going to create unwanted crankcase pressure vs vacuum. I definitely recommend managing the blow-by with a can or AOS to scrub clean before going back into the engine. Many more benefits to running a closed loop system.
Nice thing about the FA is the internal baffling is pretty good. The venting capacity could be better (and changing some parts can help that), but it spews WAY less than an EJ engine!
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
bhmax (04-08-2022), botbs (04-07-2022)
FS: Fumoto Valve jvenetto Engine, Exhaust, Bolt-Ons 6 10-01-2015 08:16 AM
PCV valve leaking? jamesm Forced Induction 24 12-25-2014 07:38 PM
Heart valve replacement surgery mike the snake Off-Topic Lounge [WARNING: NO POLITICS] 94 09-17-2014 02:45 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 02:47 AM
