Old 03-24-2016, 09:37 PM   #29
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Just tested the heater leads on the upstream sensor and I got no reading/resistance at all and I got around 6.5 on the downstream. I ordered a replacement Denso sensor.
B-R-Z is offline   Reply With Quote
Old 03-24-2016, 09:45 PM   #30
steve99
Drives: FT86
sounds fairly convincing that the front sensor is no good. It unusual for them to fail, the likely cause is excessive torque when removong or installing sensor in header. Run a M18 by 1.5mm pitch thread tap\chaser through your header 02 bungs to clean up threads the sensor should screw in by hand then torque to correct torque. Put a very small amout of high temp antiseize on header threads, ensure you get no grease or antiseize on sensor tips.
avishenoy1 (05-02-2016)
Old 03-24-2016, 09:52 PM   #31
B-R-Z
B-R-Z's Avatar
That's what I think too, I had to wail on a wrench with a hammer to get it off. I'm going to order or buy a o2 sensor socket.
Old 03-27-2016, 10:53 AM   #32
B-R-Z
B-R-Z's Avatar
New Denso 234-9136 upstream (before cat) sensor
New vs old side by side comparison
New sensor installed
P0031 code gone!
The Following 2 Users Say Thank You to B-R-Z For This Useful Post:
JB86'd (03-27-2016), steve99 (03-27-2016)
Old 03-27-2016, 07:53 PM   #33
churchx
churchx's Avatar
Drives: 2014 GT86
Congrats on finding and fixing culprit
B-R-Z (03-27-2016)
Old 05-02-2016, 11:31 AM   #34
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
Hey so I recently installed the Vortech kit on my 2015 AT FR-S and have been having similar issues to yours. My tuner is Mike at Moto-East, and other than the supercharger I have the Openflash UEL header and Saikou Michi dual catch cans, both of which were on the car before the SC without any issues.
Shortly after starting the car up with the SC installed and the Ecutek reflash I threw a CEL and the car was idling rough and stalling at low rpms.
I've been getting the following codes in some combination ever since and have still not been able to fix the issue despite a couple tune revisions.
P2271 - O2 Sensor Signal Biased/Stuck Rich Bank 1 Sensor 2
P0171 - System Too Lean Bank 1
P0172 - System Too Rich Bank 1
P2196 - O2 Sensor Signal Biased/Stuck Rich Bank 1 Sensor 1
P117B - Direct Injector Fuel Performance Does not come on DTC
P1170 - Port Injector Fuel Performance Does not come on DTC
I've checked for vac leaks and have ruled them out by using soapy water. I also clamped all three evap hoses under the intake manifold.
I'm thinking it's an exhaust leak near the O2 sensor or a bad sensor.
avishenoy1 is offline   Reply With Quote
Old 05-02-2016, 07:17 PM   #35
B-R-Z
B-R-Z's Avatar
Could be, two of those codes contradict each other..too rich and too lean at the same time?
Old 05-02-2016, 07:45 PM   #36
steve99
Drives: FT86
getting all those codes at once it may be an electrical problem like missing or bad earths bad battery piunched shorted wiring due install
Old 05-03-2016, 11:57 AM   #37
avishenoy1
avishenoy1's Avatar
I checked the battery and the engine ground cables and everything seems to be fine electrically. The car is a MY2015 with around 8600 miles on it and I'm not having any other electrical issues. I did install a wideband O2 sensor and spliced it into the Rear O2 sensor signal wire but the car was having the exact same issues before when the stock Rear O2 sensor was still on after the SC install.
I took a log this morning and the short term fuel trims were all over the place, maxing out positive at idle and dipping as low as -20% momentarily right when I release the throttle. I've attached screenshots of the log, the last one is zoomed in.
The fact that the Wideband (Custom Map O) and the Stock AFR sensor readings match up perfectly rules out a bad O2 sensor, so I'm thinking there may be an exhaust leak at or near one of the sensor bungs since both sensor's are reading full lean at idle? It could also be a vacuum leak but like I said I've checked every hose and clamp about 10 times.
Mike at Moto-East has already reduced the MAF scaling by 15% from the original tune and altered the hybrid speed density tables but that hasn't fixed it. Also the fact that it jumps from +35% to -20% seems to indicate a leak rather than a scaling issue but I'm not an expert.
Any input would be much appreciated.
Edit: Btw i'm running stock Fuel Pump and injectors, Omni 3 bar MAP, Openflash Header (Which was installed months before the SC with no CEL's or rough idle NA on Openflash stage 2 tune), Saikou Michi Dual catch cans (95% sure there's no vac leak from these since I removed them and still had the same problems, also sprayed all connections with soapy water), Clamped all 3 EVAP hoses under manifold, Vortech V3 with 3.48" pulley and Maxflow BOV (Also checked BOV vac line and adjusted spring so that it's closed at idle).
Old 05-03-2016, 07:27 PM   #38
steve99
Drives: FT86
check all the plugs and bolts are fimly connected to tge Direct Injection computer under the bonnett, it gets it ground thruogh the mounting bolts and bracket.
avishenoy1 (05-04-2016)
Old 01-20-2018, 04:12 AM   #39
Dru670
Drives: 2016 Scion FR-S
Did you figure out what the problem was?
Dru670 is offline   Reply With Quote
Old 01-27-2018, 10:56 PM   #40
B-R-Z
B-R-Z's Avatar
Replaced flex tubes in header with straight pipes. When removing the header i also noticed the bolts are a little loose which was contributing to the leaking; i had all kinds of gunk on the side of my engine block from exhaust flowing up the side from the loose header. In the process of removing the o2 sensors from the header i broke one of them which gave me codes after replacing flex tubes.
So after everything.. Tube replacement, header tightened and replaced o2 sensor, I had no codes
Keep throwing P0463 codes on low gas l0aded Issues | Warranty | Recalls / TSB 44 08-19-2021 07:02 PM
P1170 P117B Direct Injection Issue? gonzo Issues | Warranty | Recalls / TSB 4 01-11-2017 03:23 PM
Oft Tune E85 Showing Codes P1170 P117B gonzo Software Tuning 30 09-05-2015 03:50 PM
P0171 and P1171 codes help! dejxx Issues | Warranty | Recalls / TSB 3 03-24-2015 12:36 PM
Crawford BPB CEL P0171 AZ_Racer_1 Issues | Warranty | Recalls / TSB 16 02-06-2015 07:37 PM
