Old 03-13-2016, 04:28 PM   #183
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Originally Posted by Luftwaffel View Post
Just ordered from their Amazon shop since I have Prime and it would get here faster. It was $300 with $14 overnight shipping to Hawaii. Wat.
Neither one of those links is working for me.
Yeah I don't know what happened with the links. I copied and pasted them from website. I found it on Amazon. Just don't understand why they have the same unit but one goes for 300 and one goes for 329 on Amazon.
Rican_D is offline   Reply With Quote
Old 03-14-2016, 10:04 AM   #184
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
The correct one is JY-TQ123.
Luftwaffel is offline   Reply With Quote
The Following User Says Thank You to Luftwaffel For This Useful Post:
Rican_D (03-14-2016)
Old 03-14-2016, 03:32 PM   #185
Rican_D
Rican_D's Avatar
Put in my order 👍
Old 03-16-2016, 02:15 AM   #186
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Welp.
As you can all tell, I'm pretty demanding of things. Especially when it comes to electronics, and even more so when it comes to devices like computers, phones, tablets, head units. My Joying came in from Amazon today, and I'm pretty blown away. As I said, it was only $300, plus $14 overnight shipping to Hawaii, of all places. To go along with it, I went on Amazon and picked up a [ame="http://www.amazon.com/BAFX-Products-34t5-Bluetooth-Android/dp/B005NLQAHS"]bluetooth OBD module[/ame] for $22, and a [ame="http://www.amazon.com/Diageng-Profile-Right-Extension-Ribbon/dp/B00EECXAY8/"]right angle OBD cable[/ame] for $8. Fully worth it, it sees every data point the ECU is providing and at high data rates. Latency is under half a second, maybe even under a quarter of a second. It's hard to eyeball, I'll put it that way.
The Joying unit is snappy. I'd even say outright fast, even when I opened a lot of random bullshit to see if I could slow it down. Running Sygic, Google Maps, Spotify, and a browser at the same time didn't bother it at all. The low screen resolution isn't noticeable, and probably helps a lot with the lower specs of the unit. I really like that they send you a plug and play harness, too. It isn't 100% with a 2016 BRZ unfortunately. I'm going to need to bridge the amp wire since Subaru moved it.
I have two complaints. The factory head unit brackets don't sit flush because of dimples that are built into the brackets that don't have corresponding holes on the head unit. Non-issue, just force it into place and bend the brackets ever so slightly to line it up. The other is that my volume knob is gritty. I don't know why.
Rican_D (03-16-2016)
Old 03-16-2016, 12:14 PM   #187
Rican_D
Rican_D's Avatar
Welp.
As you can all tell, I'm pretty demanding of things. Especially when it comes to electronics, and even more so when it comes to devices like computers, phones, tablets, head units. My Joying came in from Amazon today, and I'm pretty blown away. As I said, it was only $300, plus $14 overnight shipping to Hawaii, of all places. To go along with it, I went on Amazon and picked up a bluetooth OBD module for $22, and a right angle OBD cable for $8. Fully worth it, it sees every data point the ECU is providing and at high data rates. Latency is under half a second, maybe even under a quarter of a second. It's hard to eyeball, I'll put it that way.
Can't wait, mine should be in on Friday. Hopefully the USB and antenna cable come in at same time.
Old 03-16-2016, 12:36 PM   #188
Lord09
Drives: 2015 BRZ
Welp.
Thanks for the observations, I'm also very demanding of electronics and speed is one of the most import things to me.
Just one question, how's the boot up time? I haven't kept up with the Android head units, but something that always concerned me was the rather lengthy start up times.
Lord09 is offline   Reply With Quote
Old 03-16-2016, 01:31 PM   #189
Luftwaffel
Boost Creep
Luftwaffel's Avatar
The bootup time is acceptable but not amazing. It takes about 20-30 seconds. I suppose by Android standards this is pretty quick. I think my Nexus 6P takes longer. The nice thing is that while it's booting, your reverse camera still has priority and can take control of the screen immediately at power-on.
Old 03-16-2016, 06:09 PM   #190
Rican_D
Rican_D's Avatar
Damn I'm excited to get mine
Old 03-18-2016, 02:21 AM   #191
Spectral Venom
Drives: Brz
Pardon my ignorance on the subject, but just looking to get something cleared up. When the unit is getting the data for the apps does the phone have to be in hotspot? Just need to take it in consideration if it does, since have a limited amount of data.
Spectral Venom is offline   Reply With Quote
Old 03-18-2016, 02:24 AM   #192
Baymax86
Baymax86's Avatar
Drives: Whiteout Monogram
you could always use your WiFi from home in the driveway. I mostly do that. Rarely use the phone as hot spot anymore.
Sent from my Nexus 5X using Tapatalk
Shameless Instagram plug : @BaymaxGT86
Baymax86 is offline   Reply With Quote
Old 03-18-2016, 02:33 AM   #193
Spectral Venom
Drives: Brz
For apps like Google maps, Waze, and Spotify hotspot is required I'm assuming correct?
Old 03-18-2016, 02:45 AM   #194
Baymax86
Baymax86's Avatar
Yes and no. Streaming music of course you'd need internet. I moved over to sd cards and listen to music locally now to save on data. As for maps you could always download for offline use. Google maps allows you to download for offline. Not sure about Was was I don't use it. There's another app called Here Maps that is made for offline as well.
Down side to offline maps is just not having traffic data all the time If you need it.
Old 03-18-2016, 03:02 AM   #195
Spectral Venom
Drives: Brz
Thanks appreciate you taking the time to explain it to me
Old 03-18-2016, 04:21 PM   #196
Rican_D
Rican_D's Avatar
What's the size limit on SD cards? Is there anything I have to do to get video playback to work?
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
