Old 03-16-2016, 11:59 PM   #29
BRZnut
Drives: BRZ DGM Limited
How do you think pressing the brake is related to the noise?
I recently started noticing the same sound but much less often and much softer , but only in this situation-->drive the car until it is fully warmed up/ shut the car off/ then restart it within 3 min/ let the idle drop after the restart and as the idle settles down the sound will be heard.
Any ideas??
Old 03-17-2016, 12:13 AM   #30
dalli
dalli's Avatar
Drives: Toyota
Any ideas??
noise always goes away when i fully press the brake pedal to the floor. Not half way but fully.
how it might be related? i dont know...im no car expert but i can assume it is related to pressure created by pressing on brakes?( i have no clue what im saying lol)
if i turn on the car first thing in morning, no tap tap noise. happens when its warmed up. if you shut the car down after warming it up and restart it, noise will be there
dalli is offline   Reply With Quote
Old 03-17-2016, 02:31 AM   #31
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Why don't you try this. Engage the clutch when you hear the noise. See if the noise goes away.
Muaddib is offline   Reply With Quote
Old 03-17-2016, 09:22 AM   #32
dalli
dalli's Avatar
Drives: Toyota
Automatic
Old 03-17-2016, 11:05 AM   #33
Muaddib
Mentat
Muaddib's Avatar
Does it do it when you put it from neutral to drive?
Old 03-17-2016, 06:55 PM   #34
dalli
dalli's Avatar
Drives: Toyota
hmm if i put it from neutral to drive, car rpms raise and noise is no more.
the tap noise goes away when rpms rise
if hold brakes and put neutral to drive with brakes active. noise will be there
(holding brakes normally)
holding brakes 80% down will get rid of noise on its own(hold brakes down enough to physically hear whoooosh(air))
Old 03-17-2016, 07:02 PM   #35
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Mine has been doing it since day oce. It it totally random and comes and goes as it pleases. I find coasting down hill is a good way to get it to happen. I doubt you drive your car nearly as hard as me and I am 50k km's in and no issue yet.
Old 03-17-2016, 07:45 PM   #36
dalli
dalli's Avatar
Drives: Toyota
atm im averaging 500 miles a week. I did 150miles today.
other than the tapping noise, my car feels fine
this is new york city so..ill post 1 pic up tomorrow of what i mean this is new york city.
oh yeah I do notice a bit tapping noise coasting down hill..noticed it in New jersey
The Following User Says Thank You to dalli For This Useful Post:
go_a_way1 (03-18-2016)
Old 03-17-2016, 08:12 PM   #37
BRZnut
Sounds like we have the same thing but mine is ever so soft , expect once at a bank drive through where car was warm, I turned it off, and then turned it back on to move forward to the bank window.
I'll have to try pressing the brake hard next time and see if it goes away.
Old 03-17-2016, 08:21 PM   #38
dalli
dalli's Avatar
Drives: Toyota
is it an automatic?
Old 03-17-2016, 10:39 PM   #39
BRZnut
is it an automatic?
yes
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 09:09 PM
Knocking sound from AC? DCdesign2000 Issues | Warranty | Recalls / TSB 2 09-25-2015 10:09 PM
Knocking/Rattle on start up. jimbobrand Issues | Warranty | Recalls / TSB 18 01-13-2014 12:34 PM
Front KNocking Noie and Gear Lever rattle Naughty AFRICA 17 10-26-2013 03:56 PM
Popping sound when parked Antheezy Issues | Warranty | Recalls / TSB 18 10-02-2013 04:27 PM
