#15 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Good idea or you could post it on the for sale section here since it may be more... applicable haha
#16 |
Drives: 2016 Cosworth 2.2 BRZ
Yaaay! Rally Sport Direct gave me a tracking number. My thermostat should be here by Thursday. Maybe I can finally pull this car off the ramps and drive it again.
At least in the down time I did get an OEM oil cooler installed. I figured that since I had the cooling system drained anyway for the thermostat, it would be easy to install the oil cooler, and it was. So in the time that I've been waiting on the Cosworth thermostat, I ordered an oil cooler with all the hoses and fittings and completed the installation. Last edited by sly; 03-16-2016 at 08:50 PM. |
#17 |
Got my replacement from RSD today. It showed up early. First thing I did was put it in hot water to verify when it opens. This one started opening at 165F instead of 120F. Much better. This one also had no markings on it. Anyway, I got it in and now the engine heats up properly. Mileage has gone up from 32 to 37.5mpg. Techstream indicates that the car is running around 175F.
#18 |
Drives: blue - Cosworth SC stage 3.0
thats exactly where its supposed to run
hopefully it will all be bit more plain sailing from here on in |
| The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post: | FRSBRZGT86FAN (03-31-2016), sly (03-16-2016) |
#19 |
Drives: 2005 Toyota Camry
Running an aftermarket performance thermostat on a street car really doesn't do much, especially on newer cars.
I used to change out thermostats in Nissans, but that was because the cars were 10-15 years old and parts needed to be changed. -alex |
#20 | |
Either way the car is now running in closed loop mode. All the race rom features seem to be working reliably. I know my bank account will regret it but I'm already itching for the 1.1 and 1.2 exhaust and tune. This time around, though, I won't take apart my car while waiting on parts.
#21 | |
Let's say at the track you are running the car hard. Your coolant temps are around 100C. What does a cooler thermostat (in reality, all it does is open sooner) have anything to do with temperature spikes or engine knock? 100C is full open, stock or aftermarket thermostats. Edit: I understand what you are trying to describe is hunting, however this has nothing to do with opening sooner. It is an improvement in flow control. Aftermarket companies can easily make a stock-type thermostat w/ superior flow control vs stock, yet because this would have the same range as stock there is no marketing benefit to it. -alex Last edited by mav1178; 03-16-2016 at 09:39 PM. |
#22 | |
I may not fully understand the thermodynamics to a full degree (but am learning all the time), but have noticed a definite improvement in engine efficiency. Drove home from work tonight and averaged 38.5mpg. I have never gotten this kind of efficiency. I ran the stage 1.0 tune for almost a month with the OEM thermostat and was getting around 36mpg. Maybe it's just the warmer weather we are getting now, I don't know. Last edited by sly; 03-17-2016 at 12:50 AM. |
#23 |
All apologies to Cosworth. It seems that they have done a bit of restructuring in regards to their authorized dealer network. I originally ordered the stage 1.0 system from Speedzone Performance and it was they who sent me the wrong thermostat. I contacted them to make it right and they just passed the buck off to Cosworth rather than attempt to fix the situation. Cosworth doesn't really seem to deal directly with the consumer but recommends dealing with the distributor instead. I think they were caught in the middle on this one. I still have never received a replacement thermostat from Cosworth (even though I did buy the correct one from RSD since then). So I saved $100 by buying from Speedzone Performance but ended up spending it in buying a replacement thermostat from RSD. So for me, I will not be dealing with Speedzone Performance any more. They were unwilling to remedy the situation and sold me the wrong part. As for RSD, I have had nothing but good experiences and will be sticking with them.
So Matt@Cosworth, what would you recommend in this situation? Is there any way I can get reimbursed for having to rebuy the thermostat from RSD? Speedzone Performance sent me the wrong part and doesn't seem to want to do anything about it. Last edited by sly; 03-17-2016 at 12:52 AM. |
#24 |
#25 | |
I would say the simplest route is that as James ( Cosworth sales admin) has already sent you a thermostat, once that finally clears customs ( I'll try and sort you out a tracking number) send it back to RSD to get your cash back? and our reasons for going to a low temp stat were all about performance a cooler cylinder head increases volumetric efficiency and also reduces knock sensitivity our dyno testing showed a small but measurable advantage by lowering the coolant by 10° so it was wrapped up into the kit |
#26 |
Drives: GT86 Cosworth
Regarding coolant temps.
The coolant system is very good on the FA20 and does not reach full capacity even on the track. Stock I used to see ~93C coolant temp on the track. OEM thermostat is fully open at 95C. I fitted the cossy thermostat at the same time as fitting the Cosworth SC kit and even with ~250WHP, coolant temps are rock solid 83C. Its fully open at 90C so not at full capacity. |
#27 |
Drives: 2014 GT86
It's not the same for oil temps though. Even more so on track.
#28 |
This is true but when the thermostat is coupled with the OEM water/oil cooler setup like OP it will make a difference because a slightly lower coolant temp will probably scale to the oil temp.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | ajc209 (03-31-2016) |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 08:21 PM |
| Cosworth SC build... | Ernie L | Member's Car Journals | 184 | 09-10-2015 04:25 PM |
| FS: AEM oil pressure oil/coolant temperature 52mm digital gauges and more | Ch0taku | Interior Parts (Incl. Lighting) | 1 | 04-03-2015 05:35 PM |
| Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install | The Sentinel | Engine, Exhaust, Transmission | 92 | 03-09-2015 05:20 PM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 05:56 PM |
