Old 03-15-2016, 05:04 PM   #239
Gabeisonfire
Gabeisonfire's Avatar
Drives: 2016 Scion Fr-s
Originally Posted by Romanov View Post
I downshift as much as I can to a stop. Once at stop I'll put the clutch in and leave the car in first at a light. If I know I'm gonna be there for a while(long light or Alot of traffic) I'll put it in neutral and put the clutch out. But typically what I'm trying to say is that I always leave the car in gear in case of emergency. Coasting in neutral is a no-no for me.
Leaving the car in gear with the clutch pedal depressed at a stop eventually will wear out the fingers on your pressure plate and throwout bearing. Not any time soon but it does put unnecessary load on the components when there doesn't need to be any. I, personally, always take it out of gear at a stop.
2016 Halo FR-S. Sales associate at YearOne, Corner Marshal at Road Atlanta.
Gabeisonfire is offline   Reply With Quote
Old 03-15-2016, 05:24 PM   #240
My $0.02:
The only acceptable way to skip gears downshifting is to double-clutch into the target gear. Otherwise rake through each gear sequentially while holding in the clutch. Skipping gates puts a horrible strain on the syncros.
Similarly, don't go straight from 3rd to 6th. I still do it sometimes but I wait a good long time in neutral to let the input side spool down. If it doesn't immediately slip into gear with a light touch, you're not waiting long enough.
Or just don't skip gears, period.
_Kodiak (04-05-2020)
Old 03-15-2016, 05:39 PM   #241
Ashikabi
Ashikabi's Avatar
My $0.02:
Do you have a source on this? I skip gears on the highway all the time when I hammer on it then shift to 6th when I hit 60
Old 03-15-2016, 05:46 PM   #242
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
Yeah, I take it out of gear if I'm going to be there for a while, if it's less than 20 seconds then I'll leave the car in gear (I live in a small town so lights change quickly)
Romanov is offline   Reply With Quote
Old 03-15-2016, 06:15 PM   #243
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Originally Posted by xFury View Post
When you come to Vegas and have some free time, let me know please lol. I still need to work on some of the basics still, and would love some lesson from ya.
I been rolling in gear till I come to a complete stop, but sometimes it just auto pilot into neutral, but been trying to stay in gear most of the time, down to 3rd and sometimes 2nd gear. Seems like my upshift is still a bit rough, car jumps slightly sometimes v__v
Maybe you guys can hang out at the chicken ranch .... if it's still there.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
Old 03-15-2016, 06:23 PM   #244
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
My $0.02:
Hmmm. Interesting. For many years most performance machinery I drove has had sequential, constant mesh transmissions. And yes, my standard downshift technique was blip, shift, blip shift. The faster I was going and harder I was braking the more important that became. Getting the input shaft unloaded and at a speed similar to the output shaft makes life a lot easier on CM gearboxes and makes it much less likely engine braking will slide the back tire while you're hard on the binders (and sometimes turning/leaning).
In the Subarota I tend to go down the box sequentially as well. Mostly because I like to. Still getting the hang of "fat footing" the throttle. It's just a different set of muscles to train.
Edit: It seems to me that the strain on the synchros is/should be directly proportional to the difference in speeds of the input and output shafts. If you're slowing down and reach a road speed that's compatible with gear ratio/engine speed for the gear you're downshifting into I don't see what excessive stress that puts on the box.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 03-15-2016, 06:28 PM   #245
Riftur
Riftur's Avatar
Down shifting puts extra wear on the clutch and brakes are much cheaper to change than the clutch. I myself love downshifting but be prepared to go through clutches much faster.
Riftur is offline   Reply With Quote
Old 03-15-2016, 06:37 PM   #246
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
Hard driving, launching, riding the clutch etc will shorten the life of your clutch for sure, but sensible driving including downshifting and your clutch will last a lot longer than you'll own the car. Unless you own a wrx, never met a Rex owner who hasn't changed at least one clutch lol
lukey86 is offline   Reply With Quote
Old 03-15-2016, 06:41 PM   #247
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
I downshift because I drive an automatic.
The Twins make me smile
The Following 2 Users Say Thank You to soulreapersteve For This Useful Post:
dre208 (03-15-2016), Tcoat (03-15-2016)
Old 03-15-2016, 06:43 PM   #248
lukey86
Built Not Bought
lukey86's Avatar
How long does your clutch last?....
Old 03-15-2016, 06:43 PM   #249
imaguitar
imaguitar's Avatar
Drives: Scion FRS - Hot Lava
Are wrx clutches like a lot stronger than other cars out there?
imaguitar is offline   Reply With Quote
Old 03-15-2016, 06:49 PM   #250
My $0.02:
This^^^^! I personally never double clutch so I forget to tell people that.
The joys of trying to type how to drive.
Ultramaroon (03-15-2016)
Old 03-15-2016, 06:53 PM   #251
lukey86
Built Not Bought
lukey86's Avatar
A WRX clutch has to deliver power to twice the amount of wheels which means twice the strain on the clutch and the majority of WRX's out there are driven twice as hard as a normal car...Life as a WRX clutch tends to be short and violent lol
The Following 2 Users Say Thank You to lukey86 For This Useful Post:
imaguitar (03-15-2016), Tcoat (03-15-2016)
Old 03-15-2016, 06:53 PM   #252
soulreapersteve
Clutch?
You mean the word that doesn't exist in an auto owner's dictionary?
(being totally facetious here)
kr-s is colorblind
Show us your Custom Roll Cage or Roll Bar and Harness Setup Black Tire Tracking / Autocross / HPDE / Drifting 27 02-13-2015 10:59 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 07:54 PM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 07:55 PM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 06:44 PM
