#15 | |
Drives: 2013 Sterling Silver BRZ Limited
Can you perhaps describe what each burning smell differs by? I'm at 16,000 miles, I'm 75% sure we have the exact same problem ... Hopefully we iron this one out! |
#16 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Are you both sure its not just your clutch :\
#17 |
Drives: 2005 Toyota Camry
Things that can burn or smell:
Clutch Engine oil Brakes Coolant Transmission oil Differential oil External sources not directly related to car You need to figure out what it is by trying to replicate the conditions that create the smell... |
#18 |
Does clutch burn smell linger after you're done driving and parked? I've smelled burning clutch before - but for the most part i smell them right away (after i slip too long or something) and then they disappear briefly.
So from my experience, it wouldn't be the clutch because i'm able to smell something burning/burned after i've parked (i usually neutral into my lot so I wouldn't even have touched the clutch) for 5 minutes. |
#19 | |
gasoline - smells like the vapors that come off your lawnmower after you overfill it. oil - smells like a BBQ after you have sprayed Pam on it when grill is hot. clutch disk - smells like nothing else ..... sort of like a hot/baked/oven mitt, you left in the oven. brake pads - smells like a burning, hot, stinking piece of wet wood. antifreeze - smells sort of sweet and alcoholic caliper - (actually the pad would be burning) ............and then we have electrical insulation, rubber, hot belts I suggest you ask your co-pilot where they think the smell is coming from and what it smells like ..... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Trust86 (03-14-2016) |
#20 |
Drives: 2016 Halo FRS
Maybe your accidentally pushing the nitrous purge button?
#21 | |
Drives: '13 Ultramarine
The stench of burning clutch can stick around for a while, and the smell of overheated brakes is very similar to my nose (though that can vary a bit with different pad compounds). I had a sticky caliper that would intermittently give me some issues (and smell). I found the issue one day with a small spray of water. Pick up a cheap spray bottle, and fill it with water. The next time you encounter that smell, pull over, and give each rotor a squirt or 2. They will likely all sizzle a bit, but if one is really hot it will steam and sizzle more noticeably than the others...that one will be your problem.
| The Following User Says Thank You to roddy For This Useful Post: | humfrz (03-15-2016) |
#22 |
Drives: Full race 4cyl boxer
Based on that video I posted above, the dealer is removing my engine as I type.
I took it in for a headlight replacement and said "Have a look under the timing cover". They said "Yup! your timing chain cover and upper oil pan seals are leaking" They said engine out and two days to complete the repair. Car has 35k miles. |
| Burning smell PLease help! | Chase1996 | Issues | Warranty | Recalls / TSB | 62 | 11-02-2015 02:11 PM |
| Burning alternator smell | btsokolas | Issues | Warranty | Recalls / TSB | 1 | 09-22-2015 12:15 PM |
| Anyone smell burning outside the car? | DarrenDriven | Scion FR-S / Toyota 86 GT86 General Forum | 115 | 01-13-2015 02:31 AM |
| burning smell when in reverse | fito68 | Southern California | 8 | 12-30-2014 07:21 PM |
| Burning smell | Boofneenee | Issues | Warranty | Recalls / TSB | 6 | 09-30-2013 07:28 PM |
