Old 03-14-2016, 12:54 PM   #43
Rameus
Drives: 2015 FR-S
Originally Posted by surfdontswim View Post
Anyone know the size of the Torx socket in galley plug oil pressure port?
If I remember correctly, mine was a number 8 hex bit (not a Torx, assuming you're talking about the galley plug on the top of block).
Rameus is offline   Reply With Quote
The Following User Says Thank You to Rameus For This Useful Post:
whataboutbob (04-25-2017)
Old 03-14-2016, 02:10 PM   #44
surfdontswim
surfdontswim's Avatar
Drives: 2013 Scion FR-S Firestorm
Yeah I was referring to the galley plug on the top of the block. I didn't look at it that closely yet but I thought I read somewhere, at one point, that it was a Torx drive. Thanks for replying back and your help!
surfdontswim is offline   Reply With Quote
Old 04-17-2017, 12:06 PM   #45
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
Figured I'd share.
I was running 0w20 since I got the car and installed my pressure gauge around 50k miles. Then I switched to 5w30 (51k miles) just this weekend. I have some few data I can share.
Mobile 1 0w20
No Oil Cooler and Stock
Perrin Oil Pressure Sensor is located at the oil galley plug between the AC and Intake
Temp is monitored through my OFT which is reading from OEM Temp Sensor
Located in Michigan
132psi (PEAK) - Cold Start - Average of 30F-45F
35 psi - 180F
30 psi - 190F
7 psi - 200F
2-5 psi - 210F
After Warmed Up - Average of 205F Oil Temp
20 psi - 1k RPM
25-30 psi - 2k RPM
30-35 psi - 3k RPM
35-40 psi - 4k RPM
40-45 psi - 5k RPM
45-50 psi - 6k RPM
50-60 psi - 7k RPM
Typically runs 5-10 psi lower than the rpm instead of +10psi/1000rpm.
Here is my data after switching to 5w30
Mobile 1 5w30
Located in Michigan
135psi (PEAK) - Cold Start - Average of 45F-50F (warmer days)
40 psi - 180F
35 psi - 190F
10 psi - 200F
5-10 psi - 210F
25 psi - 1k RPM
35-40 psi - 2k RPM
40-45 psi - 3k RPM
50-55 psi - 4k RPM
55-60 psi - 5k RPM
65-70 psi - 6k RPM
70-80 psi - 7k RPM
Pressure to RPM ratio is a lot better. I did few pulls with them close to 220F and at 7k it peaked at 82PSI which is I am happy with.
Oil temp seem to reach higher (up to 220) at normal driving with 5w30 but I think its because it is getting warmer and not because of the oil. 0w20 tops 215F normal driving with few pulls.
I will be installing a PERRIN Oil Cooler before Gridlife Event in Gingerman in June. Will be hotter ambient temps and will see if I can get someone to make note of the pressures after few sessions.
Kayysonie is offline   Reply With Quote
The Following 5 Users Say Thank You to Kayysonie For This Useful Post:
504 (06-01-2017), 7 skulls (05-01-2017), lamawithonel (06-02-2017), pgranberg11 (04-17-2017), Rosticles (04-17-2017)
Old 04-17-2017, 12:20 PM   #46
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I'll see ya on the track!
pgranberg11 is offline   Reply With Quote
Old 04-17-2017, 03:27 PM   #47
Kayysonie
Badass Member
Sure thing. There will be a couple of Michigan86 members there tracking and car show.
Looking at your build, I hope my friend and I can finish his KSwapped FRS hehe.
Old 05-01-2017, 03:27 PM   #48
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
So nobody has had issues removing the stock oil pressure switch?
If so, i'll just use that one for my gauge's pressure switch, and the top galley plug for the temp.
Anyone use a hose to relocate the pressure switch? Innovate told me it was a good idea to it doesn't put stress on the joints bouncing around.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 06-01-2017, 02:52 AM   #49
Brz_racer
Drives: Subaru BRZ
I'll be installing an oil pressure and oil temp gauge from the stock locations under the oil filter, just going to remove the stock sensor units and install the new sending units that come with the gauges. Like someone said earlier the stock oil pressure is 1/8 BSPT, I imagine the oil temp threading is the same. I got 2 1/8 BSPT male to 1/8 NPT female for the new sending units. As soon as I am done I will report back and try and post pictures. It's possible a CEL may come on from removing the oil temp plug as I think it's 4 wires not just the 1 like the pressure sensor. If i get a light I'll just tap temp from the plug on top of the block
Brz_racer is offline   Reply With Quote
Old 06-01-2017, 11:33 AM   #50
Kayysonie
Badass Member
So I after posting my oil pressures daily driving the car with 5w30 I had the chance to run a TNIA event back in May at Gingerman. Kind of a shakedown and practice for Gridlife. The post is here http://www.ft86club.com/forums/showp...2&postcount=45
I closely monitored my oil pressure and oil temp at the track after running 3 20 minute session
The ambient temp outside was between 60 to 65 and it was raining.
Still no oil cooler installed.
I cannot go to detail as I was focusing on the driving but I had my oil pressure and oil temp set to go off at a certain threshold.
<35psi and >230F
The worst temp I got was 250F and my Oil pressure stayed around 35 to 40psi up to 7K
Obviously that is not ideal as you want +10 psi per 1000 RPM. So 7k shouldve been 80psi. It wont get there ever even at 220F
40 PSI is still okay IMO but you really need an oil cooler to drop those temp down. I had to cool down every other two laps.
The Following User Says Thank You to Kayysonie For This Useful Post:
endless_pain (05-27-2020)
Old 06-01-2017, 06:34 PM   #51
Gopherboy6956
Ugh i just have to get this done - Been putting off, have a track day in about 2 weeks... I really don't want to but i Might just buy one of the sandwich plates that work with my innovative gauge so i don't have to remove the stock sensor.
Old 06-02-2017, 05:28 AM   #52
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
If I remember normal pressure is 70PSI at 7000 in the mechanical book.
Envoyé de mon T6pro en utilisant Tapatalk
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 06-03-2017, 12:55 AM   #53
Kayysonie
Badass Member
Why not Use the galley plug next to the AC condenser?
Old 06-03-2017, 12:41 PM   #54
Gopherboy6956
I agree, but that only really solves the temp sensor spot - Still have to find a spot for the pressure sensor.
Old 06-05-2017, 11:04 AM   #55
Gopherboy6956
This post is super helpful, btw
http://www.ft86club.com/forums/showthread.php?t=89666
Old 06-05-2017, 11:20 AM   #56
Kayysonie
Badass Member
You have a Innovate Oil Temp/Pressure sensor right? The oil temp sensor will not fit on the oil Galley Plug. The sensor tip is too big. You have to find an adaptor with the big hole for it which I have tried and hard to find.
The Temp Sensor should go to an oil sandwich plate.
The oil pressure sender is too big to fit in the galley plug. You can use the stock switch. I recommend to get a Braided Pressure guage line like this link:
http://www.speedwaymotors.com/Braide...-Kit,4147.html
Just make sure you have the right fittings.
I sold my Innovate Guage and got a Perrin. I dont need the temp as I read it from my OFT using OBDII.
Chuckable (07-22-2019)
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
Aftermarket gauge placement CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 22 08-18-2012 02:01 AM
Self-diagnostic busses? Specifically oil pressure? Nezz Electronics | Audio | NAV | Infotainment 6 08-13-2012 09:34 AM
phantom tire pressure warning eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-04-2012 10:04 AM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 12:39 PM
