#3571 |
Drives: Fr-s
On the cheap side I ran a Etx-9 all last year without issue. I was a bit skeptical that it would work, but since I had it laying around from my miata I figured I may as well give it a shot. Occasionally it wouldn't start the car if I left it off the tender for more than a week, so it would stay on the tender most of the time. I don't DD my car though.
#3572 | |
Drives: anything you let me
Never gave me a single problem and would do it again in a heartbeat. Saved 23lbs up high in the engine bay too. |
#3573 | |
Yes, you lose the ability to move the seat, but if 99% of the driving is done by you it doesn't matter.
#3574 | |
Do your seats use standard L brackets for mounting? If you go Buddy Club, re-weld their spot welds to ensure they don't break in a collision, or even long term use. |
#3575 | |
If you're set on a AGM battery instead of a LiFePO4, then get the Deka. Deka is the OE for Braille, similar to how Precision Instrument is the OE for SnapOn torque wrenches. PM to order the Shorai. |
#3576 |
Drives: 86
Another happy KC Machine + Shorai kit user here
#3577 | |
Drives: 2004 Toyota RAV-4 5M
![]() Could you send me links to the Bride and Nagisa rails? I couldn't seem to find them on your website. Would the circuit 2 fit in the nagisa rails? It is a wider seat and what I could find of the nagisa rails said that they don't fit wide seats. Also, would you feel comfortable doing wheel to wheel racing with the Nagisa or Bride rails? I definitely want to keep the car safe and although I would prefer to have the adjustability of sliders I am ok going with custom mounts for my seat position, like @Uplink suggested, if none of the sliders are good enough. Last edited by ja1217; 03-12-2016 at 10:05 AM. |
#3578 | |
#3579 |
#3580 |
Drives: Scion FR-S, Ultramarine
Mike,
Im planning my first track day at Streets of Willow, and I had a question about ride height. Im running buddy club racing spec coilovers right now, and my fender is 25.25 inches from the ground. My question is, how much should I raise my car to fully utilize the dampers? I believe Im 1.5-2 inches lower than stock. also, I recently started to get a clunk in the front of my car, and I believe its due to bad strut bearings :/ Will this negatively affect the handling on the track? |
#3581 | |
Strut bearings? Like the top hat? |
#3582 |
#3583 |
Drives: GT86-ACE-JRZ-RPF1-Essex
Did someone had the opportunity to test the TRD front and side splitters track efficiency ? The prices for TRD are much less stupid out there than other options.
I would much rather have a lightweight plastic aero kit than a bullshit heavy carbon fiber one. Edit with pictures : Would this be a good track solution ? (With proper static oversteer/understeer setup to balance the wing) Or is it just a marketing car ? That would help me a lot clearing speed bumps if it works. ![]() ![]() ![]()
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
#3584 | |
And yeah, in the top hat. I put my car up on stands and turned the wheel to replicate the clunking sound and I tracked it down to the top hats. I figured you would be the best person to ask. I plan on replacing them, but probably not before I hit the track. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
