Old 02-22-2016, 01:17 PM   #3767
OMJM
OMJM's Avatar
Drives: Scion FRS
Originally Posted by AZbrz89 View Post
I went with the act xt street clutch lightweight. Look at my build if you want any ideas. My YouTube channel is AZBRZ520
Sent from my SM-G920V using Tapatalk
thanks bro i will!
OMJM is offline   Reply With Quote
Old 02-23-2016, 10:23 AM   #3768
x18999
Do you get any flywheel or gear chatter with that clutch/flywheel kit? Thanks.
x18999 is offline   Reply With Quote
Old 02-23-2016, 11:49 AM   #3769
AZbrz89
Drives: 14 BRZ Crystal Black Silica Limited
Not that I'm aware of.
AZbrz89 is offline   Reply With Quote
Old 03-04-2016, 11:41 PM   #3770
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Hey guys. Have any of you ever lost boost pressure on the top end? I was doing a 4th gear pull when around 7000rpm boost pressure dropped to 4psi. Afterwards, I tapped the throttle to check for boost and got nothing out of the bypass, but I did hear a very short squealing noise. I pulled over to check all the intercooler pipes and made sure the rotrex was still spinning. Nothing out of the ordinary. I drove the car for a moment while the SC continued to not make any boost pressure then suddenly boost pressure came back.
This made me think the bypass valve got stuck open, but iirc the pressure being built by the C38 is sufficient to hold the bypass valve closed during WOT. So I'm currently at a loss. Any ideas?
D-VO is offline   Reply With Quote
Old 03-07-2016, 08:27 PM   #3771
vgi
Drives: frs
nope, never had this. were you logging at the time, curious how your afr and mafv were?
pls update the thread if you find out what's happened.
vgi is offline   Reply With Quote
Old 03-07-2016, 10:04 PM   #3772
D-VO
I deleted the log already =( . It only happened that one time so far, but then again I don't really do 4th gear pulls often.
Old 03-11-2016, 12:58 AM   #3773
D-VO
Nevermind. Belt broke. There was a pretty big chunk of teeth missing, which is what I must have felt. It must have been holding on for dear life for the passed 6 days. So much for talking crap about how long my belt lasted.
Old 03-11-2016, 11:27 PM   #3774
CaptivaBlueTeg
Drives: WRB Brz
Add me the owners! Mine came in this week, installing next Friday.
I got the kit with ecutek,lic and tune. Anyone that got this, is this tune locked? I have a UEGO wideband in my second O2 port and want to be able to turn off the CEL. I'm going from OFT to ECUTEK so learning the UI. I noticed some of the documentation varies from the newest update causing slight learning curve.
CaptivaBlueTeg is offline   Reply With Quote
Old 03-11-2016, 11:45 PM   #3775
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Ecutek tunes are usually locked. You will need to get the original tuner to disable the DTC.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 03-12-2016, 10:43 AM   #3776
D-VO
Does anyone know why the Rotrex can't be turned counter(anti)clockwise other than it not compressing air? I searched for a while last night and really can't find any info other than "don't do it!" Why not Rotrex? You tell me not to take the blue pill but then you won't tell me what it does.
Old 03-12-2016, 04:21 PM   #3777
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
No idea but why are you wanting to? Have you tried contacting Rotrex about it? I assume you did but figured I'd ask that too.
Freeman is offline   Reply With Quote
Old 03-12-2016, 04:52 PM   #3778
Bykov
Drives: 2014 Monogram FR-S Whiteout
Well isn't the oil pump built into the unit? I have a feeling it has a lot to do with running a liquid pump backwards especially through a scavenge type system possibly oil starving the unit depending on what you are doing and for how long.
Bykov is offline   Reply With Quote
Old 03-12-2016, 06:36 PM   #3779
D-VO
I don't need to run it counter clockwise, I'm looking for more of an operational explanation. I guess I could just call them on Monday.
Old 03-12-2016, 06:37 PM   #3780
D-VO
That's what I was thinking too, but why make such a big fuss over turning it even a little bit when changing out the pulley?
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
