Old 03-10-2016, 09:31 AM   #15
Ashikabi
Ashikabi's Avatar
Originally Posted by DaJo View Post
And if you're curious, this is what underneath the garnish looks like: 6 clips and double sided tape to remove, if you plan on taking off the whole piece.
So what's that big slot on the fender for?
Old 03-10-2016, 02:51 PM   #16
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
To make space for that seam you see
Old 03-10-2016, 04:40 PM   #17
8R6
8R6's Avatar
Drives: FRS
if you do end up taking off the chrome trim, i'll buy it off of you. (granted that it's not broken lol)
8R6 is offline   Reply With Quote
Old 03-11-2016, 08:14 AM   #18
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I might just leave it on and plasti dip it, I don't know if it will last long tho
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 03-11-2016, 08:59 AM   #19
Irace86
Drives: BRZ + Ducati M796
I dont think it has been said but you might try using a hair dryer or heat gun to loosen the bond of the bouble sided tape. Just in case that is what is stopping you.
Irace86 is offline   Reply With Quote
Old 03-11-2016, 09:43 AM   #20
Ashikabi
Ashikabi's Avatar
Plastidip should last a couple years. Tape it off and spray. Worst case scenario you hafta take it off
The Following User Says Thank You to Ashikabi For This Useful Post:
ShadowReaper (03-11-2016)
Old 03-29-2016, 12:57 PM   #21
ShadowReaper
Indulgent Tormenter
Another brz around my area plasti dipped his, it doesn't look good at all. He said it was because it was windy but I'm not to into Operation Plasti Dip now
Old 03-29-2016, 12:58 PM   #22
Ashikabi
Ashikabi's Avatar
Autodip it? Vinyl wrap? Paint? Lots of options
Old 03-29-2016, 02:07 PM   #23
ShadowReaper
Indulgent Tormenter
Vinyl wrap? No, I'm probably going to order a black fender trim and put it on
Old 03-29-2016, 03:29 PM   #24
8R6
8R6's Avatar
Drives: FRS
so are you considering selling the chrome trim? i'd just buy one from a dealer if it wasnt so damn expensive for a small accent piece lol
Old 03-29-2016, 06:17 PM   #25
ShadowReaper
Indulgent Tormenter
I dont know. I will most likely buy the black fender trims for $59 and put them on. I will keep the chrome ones, until I succefully put the black ones on, maybe so after that.
Old 03-29-2016, 09:04 PM   #26
Autocon
Autocon's Avatar
Drives: 2014 Whiteout FRS
I dipped my emblems black and its been nearly 2 years now. Through tons of washes and never a touch up on the dip. They still look great as if I did it last weekend.
Don't dip them when its windy out. 4 coats of regular black and 2 coats of the clear coat plasti dip. Seals them up stronger and has a bit more shine than just the super matte look of straight plasti dip.
20 bucks and enough dip in the cans to do 4 coats on a wheel if I wanted. But hey if you got 60 bucks to throw away on some super small trim accent because dippin is too hard more power too you
Autocon is offline   Reply With Quote
Old 03-29-2016, 09:34 PM   #27
ShadowReaper
Indulgent Tormenter
lol too hard. That's just hilarious
Old 03-29-2016, 09:35 PM   #28
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Its a pretty simple piece to wrap in black o_O
If you're worried bout getting the edges perfect, then pull off the chrome piece first, wrap it, and have the edges of the vinyl wrap around the edges of the chrome piece. Then double stick it back on. Way cheaper this way.
Or just use actual high gloss spray paint and spray the chrome piece while its off the car.
EDIT: the hard part seems to be ripping the actual chrome piece off anyway. Making it black is easy. So up to you if you want to spend $60 on what could be a super cheap DIY.
DIY Silver Gauge Cluster trim removal Jake_86 DIY (Do-It-Yourself) Guides 4 08-15-2015 02:31 PM
B pillar trim removal lmabee Scion FR-S / Toyota 86 GT86 General Forum 4 03-22-2015 12:36 AM
Center air conditioner trim removal? Jake_86 Cosmetic Modification (Interior/Exterior/Lighting) 6 03-13-2015 06:17 PM
Trim removal DIY (Request) PrDarkKnight DIY (Do-It-Yourself) Guides 32 01-22-2013 09:21 PM
Silver interior trim removal for plasti-dipping ph0en1xtk Cosmetic Modification (Interior/Exterior/Lighting) 1 10-06-2012 10:54 AM
