#295 | |
Yup that's the one I bought, some may need trimming though like the one in another thread I heard.
#296 |
GOT IT WORKING!!! THANKS GUYS!!!!
It works great!!! I'll test it out fully far from home tomorrow! Interesting enough it does that toyota and scion logo at startup I'd like it to do just the toyota one honestly
#297 | ||
Also the entune app for me I used the VIN of the car I got the module out of and it works flawlessly. Although it does have a slight bit of input lag for things.
#298 | |
Apostle
Drives: JesusMobile
Traffic used to have an overlay onto the map (green/yellow/red) indicating traffic conditions. It could also reroute based on traffic and offer detours if you were caught in something. It was no Waze, but it was better than driving blind. All the other data features work as far as I can tell, however I only use voice nav, voice search, and Pandora. |
#299 | |
#300 | |
Apostle
Drives: JesusMobile
Toyota ended their relationship with Microsoft/Bing, so my voice search and traffic stopped working. I think the other apps still worked. That's why the 5.0 upgrade is posted on their webpage and was emailed out to owners. |
#301 | |
That makes sense so even if you were to downgrade it wouldn't make a bit of difference
#302 |
Drives: Red Mr2
Special thanks to this thread! I just installed a factory nav unit in my MR2 Spyder by using a 2015 yaris head unit (pt546-52150) and a 2012 prius extension box (pt296-47120). I am curious if any iPhone users can wirelessly connect data to the radio without using the usb. I suspect that since this an older extension box that I have to use the usb. Are there any of using pt296-47130 or pt296-47141 and an iPhone?
| The Following User Says Thank You to Rustysw20 For This Useful Post: | FRSBRZGT86FAN (03-31-2016) |
#303 | |
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | trueno86power (04-04-2016) |
#304 |
Apostle
Drives: JesusMobile
#305 |
Drives: 2013 FR-S 10 series [755]
Does the GPS antenna fit on my 2013 10 series radio???
#306 |
The GPS antenna in the first post will fit, you're not actually connecting it to the head unit, you're connecting it to the entune module. It snapped right in for me and didn't require any cutting as he mentioned. The head unit in your car is the standard one that is in mine btw. This is what you'll need: http://www.ebay.com/itm/TOYOTA-CAR-N.../320819856679? This prius v navigation unit contains the module you will remove: http://www.ebay.com/itm/15-Toyota-Ca...lXCAWj&vxp=mtr that's actually what I did, I bought a cheap prius V head unit for around $150-$200 and pulled the module out You'll also need this: [ame="http://www.amazon.com/Genuine-Toyota-Accessories-PT296-47120-AB-Harness/dp/B00DWVNAT2/ref=pd_sim_sbs_263_14?ie=UTF8&dpID=31WwBXzITjL&dpS rc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1PZ1Z5 HZM4CNQBPFNS0Q"]Amazon.com: Genuine Toyota Accessories PT296-47120-AB Wire Harness: Automotive[/ame] It interfaces the navigation module to the head unit Also the brackets described in the first post are honestly optional, I used 3M VHB double sided tape to hold them both together
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | FR-Sky (04-27-2016) |
#307 |
I am still confused lol. The head unit in the first post,,he is using exactly the same as my radio head unit..i understand i need the GPS antenna,,but i dont understand the module and the wire harness.. can you explain little bit more ....i wish i can give you 1000 thanks
P.s Prius V head unit looks bigger than my oem radio head unit...how can it fits? |
#308 | |
Dude you're not listening or comprehending at all, you take that MODULE in the bottom and the gps antenna plugs into that and the wiring harness connects that module to the OEM head unit read the first post slowly.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | FR-Sky (04-28-2016) |
| New Scion Standard Radio for 2014 | NedVargar | Electronics | Audio | NAV | Infotainment | 45 | 06-13-2013 10:00 PM |
| WTB: Pioneer Premium Audio radio/head unit | tech4pdx | Canada Classifieds | 2 | 04-14-2013 08:31 PM |
| Sirus Radio on Stock head Unit | wtout86 | Electronics | Audio | NAV | Infotainment | 3 | 11-20-2012 03:22 PM |
| Fitting the radio plug into aftermarket head unit | GC GTS Aero Kit | Electronics | Audio | NAV | Infotainment | 1 | 10-29-2012 06:41 AM |
| head unit in GTA | excited86 | Electronics | Audio | NAV | Infotainment | 1 | 06-18-2012 08:42 PM |
