Old 06-13-2012, 11:58 PM   #1
robo_robb
robo_robb's Avatar
Drives: Whiteout FR-S
Is this idle noise normal? Cricket sound
I'm not familiar with boxer engines; I hear they can be quite noisy, but I'm not sure if this is normal. Here is a video I took of the noise. It is only audible during idle and seems to be coming from what I think is the crankshaft pulley.
Also, this can be unrelated, but there is a pulley that is shaking in the video. I marked it with a caption.
Anyone with boxer experience have any insight?
[ame="http://www.youtube.com/watch?v=csYmda3dGVY"]FR-S Engine Noise - YouTube[/ame]
Update:
I took the car into the Toyota Dealer today (6/15), I asked for a mechanic to come and listen. About 7 people show up, about 3 or 4 of which are mechanics. Even the Foreman was there. One of them has a WRX so he was familiar with how noisy boxers can be. He was positive the cricket noise was coming from the Direct Injection system (primarily from the drivers side). He said the tension pulley was behaving normally; the shaking was normal.
Both he and the Foreman suggested I hold off on leaving it at the shop until they do some research with their corporate contact, primarily because they have no other FR-S or BRZ to compare it to. They said they would contact me next week.
Update 2:
The Foreman from the Toyota dealer just called me. He did some research and is 95% sure the noise we are hearing is the DI system, which switches modes depending on temperature and other factors.
Last edited by robo_robb; 06-22-2012 at 03:36 PM. Reason: Video embedded, Thread title modified for better search results
robo_robb is offline   Reply With Quote
The Following User Says Thank You to robo_robb For This Useful Post:
blu_ (06-14-2012)
Old 06-14-2012, 12:19 AM   #2
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
You've got a warranty still, have the dealer inspect it. Mine doesn't squeak like that. I only have the injector noise, but I only have 200 miles on mine.
denkigrve is offline   Reply With Quote
Old 06-14-2012, 12:28 AM   #3
ahausheer
Re-member
Drives: Toyota camry
Some of those sounds are normal but the chirping/squealing is not. Get it to a dealer to be safe and if there is something wrong you can also help others by relaying your experience here. Thanks
Good luck.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-14-2012, 12:31 AM   #4
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
definitely sounds like a slipping serpentine belt to me.
spiller is offline   Reply With Quote
Old 06-14-2012, 12:49 AM   #5
fenton
I notice mine chips a bit too. rev it up just a bit and it stops but at idle you can hear it.
fenton is offline   Reply With Quote
Old 06-14-2012, 12:54 AM   #6
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Mine does it and there is a thread, or at least comments in a thread, about it on the forum somewhere.
Video is good representation of the "issue".
I have never heard this on my other subarus and have kind of shrugged it off for now as something to do with the DI.
blu_ is offline   Reply With Quote
Old 06-14-2012, 12:54 AM   #7
fenton
Actually just went and checked mine again and no chirping but i have heard it multiple times before when it idles.
Old 06-14-2012, 02:27 AM   #8
Jayde
Jayde's Avatar
Mine just started to chirp too. Quite odd. I noticed it at a friends house but when I got home it was much less noisy. I'll check again tomorrow and see what happens. Also, that pulley shouldn't be moving like that. I'm going to check that too and see if mine is doing that as well. (Well, that could be an idler/tensioner pulley, but I doubt they are spring tensioned.)
That's what I was thinking too.
Jayde is offline   Reply With Quote
Old 06-14-2012, 06:05 AM   #9
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Thats a spring tensioned idler, doing exactly what it is meant to do. Chirping can happen if the tension spring is too soft for the job it is supposed to do. Normally they dont move quite that much on a factory stock motor ......
Tradewind is offline   Reply With Quote
Old 06-14-2012, 07:40 AM   #10
Don@Accelerated
Don@Accelerated's Avatar
I don't believe I hear a belt chirping. Not alteast in the video. All I can hear is the high pressure direct injection pump and nozzles.
-Don
Don@Accelerated is offline   Reply With Quote
Old 06-14-2012, 07:49 AM   #11
MANDALAY
Drives: MR2
The noise is just injectors but the belt pulley Tensioner does seam a bit weak. A bit to much bounce.
Saw the new BMW's on a dyno day and 3 of them had the belts fly off
MANDALAY is offline   Reply With Quote
Old 06-14-2012, 09:10 AM   #12
Jayde
Jayde's Avatar
When I got to work this morning it wasn't chirping. All I heard was the usual tick at an idle. I did check that pulley that the OP was stating seemed loose, and mine does the same thing. The pulley moves back and forth a small amount, along with the bolt, so yes, it is spring tensioned, as others have said.
Old 06-14-2012, 11:01 AM   #13
robo_robb
robo_robb's Avatar
Thanks for the input guys. I'll have the dealer look at it.
I'll keep you guys posted.
Old 06-14-2012, 11:08 AM   #14
ahausheer
Re-member
Keep in mind most belts that slip a little will make noise but this should not happen on a new car. Once the belt is heated up and or has dried any condensation on the pulleys the noise goes away. That pulley should not be moving like that at idle. Maybe at high load/rpm but at idle? Whats going to happen when you rev it hard, that thing is going to shake it self apart.
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 10:57 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
What function can it be used for, the idle button place yuli8466 Cosmetic Modification (Interior/Exterior/Lighting) 50 01-29-2013 04:17 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 11:16 AM
