Old 03-03-2016, 09:07 PM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by jg7 View Post
Ha, answered my own question....
<http://www.ft86club.com/forums/showthread.php?t=57904>
I actually did weigh everything out it breaks down as follows
Stock Exhaust
Mid pipe: 11.5 lbs
Rear section: 28.5 lbs
TOTAL: 40 lbs
Dezod Exhaust
Mid section: 9.5 lbs
S-section: 3 lbs
Rear section: 16 lbs
TOTAL: 28.5 lbs
So there's a weight savings of about 11.5 lbs.
If you can contact @JRitt
That way he can update this thread:
http://www.ft86club.com/forums/showthread.php?t=7881
with the exhaust system weight it's good to know
Old 03-04-2016, 06:59 AM   #16
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Does anyone know how much the stock exhaust weighs? This would be from the cat back, or just the muffler section.
I'm thinking of changing/deleting the muffler for the weight savings and a slightly more aggressive sound (don't expect much performance change).
Thanks,
If you delete the muffler make sure you add something else, don't just leave it like it is. For example go with the Berk muffler delete.
I saw a dude at a car meet with a red FRS had his bumper off because it melted from deleting the muffler and not adding any more piping.
So he has a muffler delete and bumper delete lol
and the muffler delete by itself doesn't sound aggressive at all, just sounds slightly louder and the engine is most of the noise.
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 03-04-2016, 10:34 PM   #17
jg7
Drives: 2016 Scion FR-S
Good advice, don’t want to end up with a blob of plastic on the back (or fumes in the cabin).
I do like the smooth bends in the Dezoid cat back. I wonder if it has much reduction in back pressure and if that causes a mixture change.
jg7 is offline   Reply With Quote
Old 03-05-2016, 06:54 AM   #18
ShadowReaper
Indulgent Tormenter
It doesn't, it's awesome. I'd recommend it to any 86er
Old 03-05-2016, 01:49 PM   #19
Stock Exhaust
Mid pipe: 11.5 lbs
TOTAL: 40 lbs
Dezod Exhaust
S-section: 3 lbs
TOTAL: 28.5 lbs
*searches, answers own question, posts results*
Well done!
...and welcome to The Forum.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
Cole (03-05-2016), FRSBRZGT86FAN (03-05-2016), lukey86 (03-05-2016), ShadowReaper (03-05-2016), Tcoat (03-05-2016)
Old 03-05-2016, 08:14 PM   #20
jg7
Thanks Ultramaroon,
Great folks and lots of good info on these forums.
jg7
The Following User Says Thank You to jg7 For This Useful Post:
Ultramaroon (03-05-2016)
Old 03-05-2016, 09:22 PM   #21
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Actually, a muffler delete pipe (of any kind) would contribute to a small decrease in gas mileage at higher speeds.
The factory muffler location acts as an underbody filler. When you remove it, there's a gigantic void where drag can be created.
This is why complete rear diffusers improve gas mileage on our cars, because that is probably the most inefficient part of a car that is already pretty good.
-alex
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
cjd (03-05-2016), Clipdat (03-05-2016), ShadowReaper (03-07-2016), Ultramaroon (03-05-2016)
Old 07-04-2016, 01:45 PM   #22
Jnamrefiel
Drives: 2015 Subaru BRZ LIMITED
-alex
I want to say invidia sells a bolt on panel to correct that issue.
Sent from my 831C using Tapatalk
Jnamrefiel is offline   Reply With Quote
Old 07-04-2016, 02:54 PM   #23
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
again, when will people ever learn. buying an axel back is a waste of money, do yourself a favor and buy a catback. buy an axelback and GOODLUCK finding a mid pipe for it.
Dr. BRZ is offline   Reply With Quote
Old 07-04-2016, 03:00 PM   #24
Jnamrefiel
Theoretically any one should bolt up assuming the mid pipe was designed as a factory replacement. But there's always a possibility of minor fitment issues even then.
Old 07-04-2016, 03:29 PM   #25
Dr. BRZ
Dr. BRZ's Avatar
do all these people a favor and look for and post aftermarket midpipes. let's see how many you can find.
Old 07-04-2016, 03:42 PM   #26
Cole
Not a troll
Cole's Avatar
Why is the axleback a waste of money? I've had 3 different ones so far and they've all been excellent quality, install has been easy (not needing to mess around with a jack) and providing I ever do go through the OEM mid pipe, plenty of people sell their nearly new OEM ones.
Not many if any gains to be had by going with a catback anyhow
Cole is offline   Reply With Quote
Old 07-04-2016, 03:56 PM   #27
Jnamrefiel
http://www.frsparts.org/Works-Exhale...e-BRZ-FRS.html
http://www.modbargains.com/Borla-Mid...-BRZ-60541.htm
https://shop.namelessperformance.com/3-midpipe-brz-frs/
http://www.frsport.com/Exhaust-Mid-P...-_p_74485.html
http://www.phasteksport.com/2013-Sci...ipe-17284-.htm
http://m.enjukuracing.com/item/33333...38392d36323435
Old 07-04-2016, 04:08 PM   #28
swarb
@Dr. BRZ waste of money is relative. 600 bucks for 2-3hp? it is mostly for sound, looks, and weight.
@Jnamrefiel You have the front pipe and midpipe mixed up. He was talking about the midpipe. Please don't bump old posts if you don't have any real information to add.
Custom Muffler Delete vs Berk Dual Tip Muffler Delete eric2523 Engine, Exhaust, Transmission 7 07-27-2015 09:40 AM
Any muffler shop on Oahu for muffler delete? ALOHA_FR-S Hawaii 1 07-01-2015 10:49 PM
WTB: Berk Track Pipe Muffler Delete or Nameless Muffler Delete Hollwood_lives Canada Classifieds 5 04-12-2015 07:02 PM
WTB Berk Dual Exit Muffler Delete or Works AB Delete Admired Want-To-Buy Requests 2 09-10-2013 04:20 PM
Muffler Delete sound without deleting muffler sw20kosh Engine, Exhaust, Transmission 10 01-30-2013 05:09 PM
