Old 06-13-2012, 09:35 PM   #57
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
What's all this about a Subaru mechanic worth their weight? As a shade tree mechanic, I did plugs on my WRX for the first time ever in about 2 hours, with no previous experience on a Subaru, or any car ever for that matter. It was kind of a bitch, but I certainly didn't get the engine out of the car. You had to first remove the stock intake snorkel and airbox for the passenger side (maybe move the power steering reservoir too); the driver's side required removing the windshield washer reservoir (larger on my wagon than on the sedans). That's it. Flex head + extension, done.
On the bugeyes there are no air pumps so they are quicker than the newer ones. It takes about 2hrs with cool down etc to do em on just about any subie.
-mike
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 06-13-2012, 11:07 PM   #58
Sleeperz
Drives: 1982 Toyota Corolla Coupe SR5
What type of seal is used on the sparkplug? Taper seal or washer gasket?
Also a problem of leaving a sparkplug along time in an aluminum head is the threads in the head may strip out when removing. Does anyone put antiseize on the sparkplug threads before putting them back on?
Sleeperz is offline   Reply With Quote
Old 06-14-2012, 12:23 AM   #59
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Every human being on the planet should know to do this.
Old 06-14-2012, 02:12 AM   #60
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I specified a Subaru mechanic because then the time would be around 30 minutes to swap plugs. Any mechanic can do it, but someone familiar with boxer motors could do it much quicker the first time. Obviously each time you would get faster if it was indeed your first time. It took me a bit over an hour the first time I did it, but I did it on my car 3 times and on other Subaru, making the task easier each time. I wasn't trying to insult others, just saying how easy and quick and can be if you have experience with them.
Old 06-14-2012, 03:11 AM   #61
OrbitalEllipses
Drives: Attitude
I do. I know people who don't. It's worth it so the threads don't strip out or heads crack, which is common. Just watch out how much you use, they might back out if you're not careful.
Ahhh, forgot about the air pumps on newer models.
Old 06-14-2012, 03:47 AM   #62
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
For aluminum heads, I always use anti-seize. Also make sure to torque to the proper values with a torque wrench. Most people end up over-tightening the spark plugs, which can be a bad thing on aluminum heads.
FrX is offline   Reply With Quote
Old 06-14-2012, 04:18 AM   #63
OrbitalEllipses
Drives: Attitude
Getting a torque wrench in there is a bitch and using a (flex) extension only insures whatever torque you're reading isn't the torque you're torquing. Unless you have a small in-lb torque wrench, I guess.
Old 06-14-2012, 08:41 AM   #64
Archer1.8
Drives: 2005 Subaru Legacy GT Stage 1
Welcome to the world of Subaru engines. It always sucked to watch EVO guys change their cams in a couple of hours...a subaru takes a couple of days
Archer1.8 is offline   Reply With Quote
Old 06-15-2012, 11:09 PM   #65
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Originally Posted by BMWDavid View Post
By now some of you have read the spark plug removal instructions in the service manual.
Yeow! Has this soured anyone on getting a BRZ/FR-S? It has caused me to rethink it a bit. Still waiting for my car to arrive and I'll need to see how I fit in it and give it a quick run down the road before making final decision to buy the car.
But the spark plug issue will be in my mind.
Well I bought the car. Realized that the spark plugs won't need changed for 60,000 miles possibly longer. Might not even have the car then.
Having a blast with it!
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 07-06-2012, 11:02 PM   #66
Dustin@Dynosty
We can confirm removal of number 1 (with just overpipe removed) and number 2 plug can be done with out anything else removed, the frame is wider at the front, the rear gets a little tighter so those are questionable, if I get time I will investigate further. The coils are very flexible at least with only 2,000 miles on them. It is a very tight squeeze, recommend small hands.
Dustin@Dynosty is offline   Reply With Quote
The Following User Says Thank You to Dustin@Dynosty For This Useful Post:
MRZ415 (07-07-2012)
Old 07-06-2012, 11:33 PM   #67
ahausheer
Re-member
Drives: Toyota camry
FYI- If you are using anti-seize the torque measurement will be wrong because the threads are essentially lubricated. Less friction, less torque. The bolt will be over-tightened but ''read'' that it is properly torqued. Most spark plugs tell you to hand tighten, then tighten either 1/8th or 1/16 turn tighter.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-07-2012, 01:26 AM   #68
SFTiofoso
Drives: '10 Civic Si Coupe
Seriously though, 90% of this so called "headache" will be the second owner's problem. Plugs are designed to last 100K miles.
SFTiofoso is offline   Reply With Quote
The Following 5 Users Say Thank You to SFTiofoso For This Useful Post:
@Art_Mighty (09-16-2012), Astroboy (04-28-2014), Bristecom (11-30-2012), chanomatik (02-06-2015), Laika (07-07-2012)
Old 07-07-2012, 01:30 AM   #69
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
60K change per the car's schedule maintenance book.
Old 07-07-2012, 03:17 AM   #70
MRZ415
Drives: 2015 Subaru WRX
I vaguely remember reading somewhere that the Spark Plugs on the new FA
engine on the BRZ only requires removal of both front wheels and wheel wells to
gain access.
(( I am probably totally wrong on this and that is probably why I am ONLY going
to attempt basic oil changes on my own and leaving spark plug change to PROS))
MRZ415 is offline   Reply With Quote
Subaru or Toyota drain plug? yayforaddison Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-06-2020 11:59 PM
Exhaust tip removal Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 97 05-27-2017 06:50 PM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 11:12 PM
Spark plug type and heat ft86-UAE Engine, Exhaust, Transmission 4 06-10-2012 11:21 AM
What do you wish was changed about the brz/frs? GirlyScions BRZ First-Gen (2012+) — General Topics 16 06-04-2012 04:26 AM
