Old 02-27-2016, 08:49 PM   #1
Flat_4_Life
Flat_4_Life's Avatar
Drives: 2015 SBD Turbo Halo FRS
Talking SBD Turbo numbers?
Alright so I'm installing my SBD kit on good Friday. The plan for tuning is going with my OFT then possibly a few weeks after getting a dyno tune with EcuTek. I want to see some dyno numbers people are getting with this kit and if you could post what you're tuning it with that would be awesome!
Flat_4_Life is offline   Reply With Quote
The Following User Says Thank You to Flat_4_Life For This Useful Post:
D_Thissen (02-27-2016)
Old 02-27-2016, 08:53 PM   #2
D_Thissen
D_Thissen's Avatar
Not sure if you're a member of their FB group or not, but I have seen numbers from 275whp and going up from there.
Old 02-27-2016, 09:08 PM   #3
raven1231
280-300 area on pro tune. Base tune is about 250ish
Old 02-29-2016, 04:49 AM   #4
scarfo
Drives: gts 86
be careful you dont flash over your open flash tune with ecutek. you wont be able to unmarry your OFT if you do
scarfo is offline   Reply With Quote
Old 02-29-2016, 06:45 AM   #5
Northwest86
Drives: Velocity Orange 86 GT
Depends on the dyno calibration and how much the tuner is willing to fudge the numbers. I've seen cars locally that have claimed 220kw at 7PSI and the quality tuner locally usually gets about 160-170 for kits like the stuff like SME and Full blown and 170-180 for the better options. The so called 220kw car then gets absolutely smashed by cars doing 50-60kw less. You can only compare numbers across one dyno and tuner because the car world is full of people making wild claims to people who don't know better.
Northwest86 is offline   Reply With Quote
Old 02-29-2016, 09:43 AM   #6
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Talking about dynojet numbers, around 280whp at 10psi for OFT(which all the kits are now at, unless you have been storing your kit for 5-6 months).
It's good to note that OFT no longer supplies a base tune that is good to beat on the car with. So unless you are just using the OFT tune to drive easy/drive it to the tuner, you will want/need to get a custom tune from Shiv.
A custom dyno tune will yield a bit more power, but you don't want to go too much further on pump gas with the kit. E85 is the way go for good/safe numbers
FWIW I made 217whp on 7psi with a superflow, which pretty much matched the 250whp Dynojet numbers the kit was rated for at 7psi.
Old 03-03-2016, 08:50 PM   #7
Flat_4_Life
Thanks for the answers! The local tuner uses a Dynapack DP4. I plan on running a OFT tune for about a week and then getting a dyno tune
D_Thissen (03-03-2016)
Old 03-03-2016, 09:07 PM   #8
D_Thissen
D_Thissen's Avatar
Sasha?
Sent from my Nexus 6P using Tapatalk
Old 03-03-2016, 09:24 PM   #9
Flat_4_Life
Originally Posted by D_Thissen View Post
Sasha?
Yup
Old 03-03-2016, 09:27 PM   #10
D_Thissen
D_Thissen's Avatar
Are you going to be using an ecutek tune? I don't think he will use any open source software ? Sorry just picking your brain.
Old 03-03-2016, 09:31 PM   #11
Flat_4_Life
Ya it'll be ECUTEK
Old 03-03-2016, 11:38 PM   #12
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i just finished the custom tune by shiv. i need some dyno time
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Efficiency Numbers Toyota86.ir Forced Induction 0 02-15-2016 11:44 AM
OEM part numbers nikitopo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-29-2014 12:59 PM
Plasti-dip Numbers kurbkilla Cosmetic Modification (Interior/Exterior/Lighting) 1 12-05-2013 07:34 PM
Production numbers smiley6570 Scion FR-S / Toyota 86 GT86 General Forum 5 06-09-2012 08:50 AM
