Old 02-29-2016, 02:13 AM   #253
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Can't wait for some install pictures and some numbers!
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 03-01-2016, 07:47 PM   #254
zeal86
zeal86's Avatar
Drives:
YES!
I'll be busy polishing all the piping/intercooler the next several days!
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
The Following 3 Users Say Thank You to zeal86 For This Useful Post:
8R6 (03-04-2016), go_a_way1 (03-03-2016), new2subaru (03-01-2016)
Old 03-01-2016, 07:59 PM   #255
zeal86
zeal86's Avatar
Drives:
Originally Posted by new2subaru View Post
With detailed step by step pics?
I could do that!
Old 03-01-2016, 08:06 PM   #256
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by zeal86 View Post
I could do that!
I'm sure I'm not the only one that would appreciate it!
It never crossed my mind to polish an engine bay until I saw yours.
Do you use anything to coat the aluminum after polishing? Mine is starting to oxidize a bit. Not a ton but a bit.
Old 03-01-2016, 08:32 PM   #257
SDIAZ
Drives: 2004 350Z
I've been reading forum posts about changing the spark plugs... I think I'm going to change mine when my headers, over pipe, and front pipe are out... I'll do the drop the engine method instead of working in super tight spaces. Going with HKS M50HL spark plugs.
Any insight on changing the plugs would be appreciated...either method.
Hey man, was scrolling through your thread and I really gotta say nice job. I actually just did spark plugs a couple days ago. Took me about 3 1/2 hours, but that was me taking my time and with limited access to tools (not to mention the PITA of getting the headers back on). I was able to jack up the motor about 100mm and maneuver it slightly to allow more room for whatever side I was working on. It will definitely help if you remove your stut tower braces to get a bit more room to move the engine higher. Once I got it up, it wasn't that bad.
INSTALLATION_FA20 ENGINE CONTROL_ IGNITION COIL AND SPARK PLUG.pdf
REMOVAL_FA20 ENGINE CONTROL_ IGNITION COIL AND SPARK PLUG.pdf
SDIAZ is offline   Reply With Quote
Old 03-01-2016, 08:33 PM   #258
zeal86
zeal86's Avatar
Drives:
I don't protect the finish in any way... I just polish again... it doesn't require much effort after the initial polishing.
The final install will look great polished... I wished it would have come polished though... oh well... time to get to work!
The Following User Says Thank You to zeal86 For This Useful Post:
Old 03-01-2016, 09:18 PM   #259
zeal86
zeal86's Avatar
Drives:
Out of the box (most of the kit)
Also received this today...
Beatrush aluminum underpanel
8R6 (03-04-2016), new2subaru (03-01-2016), rookie (03-01-2016)
Old 03-01-2016, 10:46 PM   #260
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
So clean! Can't wait to see the new goodies installed and all polished up.
rookie is offline   Reply With Quote
The Following User Says Thank You to rookie For This Useful Post:
zeal86 (03-02-2016)
Old 03-02-2016, 08:25 PM   #261
zeal86
zeal86's Avatar
Drives:
Started polishing today... here are some pics of the process:
Almost done with one so far...There is still some pitting in the finish, especially at the bends, but I don't want to take off much more from the surface...100 times better than before though.
8R6 (03-04-2016), Koj (09-06-2016), new2subaru (03-02-2016)
Old 03-03-2016, 09:52 PM   #262
zeal86
zeal86's Avatar
Drives:
Accomplished a little more today...I removed a lot of the pitting and deeper marks in the aluminum. I followed up what I did yesterday with the following grits:
- 400 (dry) Its what I had with me.
- 600 (wet)
- 800 (wet)
- Blue Magic Metal Polish
Going to continue with the following grits:
- 1000 (wet)
- 1500 (wet)
Should be mirror like by the time I'm done!
Here are some process pics:
The Following 4 Users Say Thank You to zeal86 For This Useful Post:
8R6 (03-04-2016), go_a_way1 (03-03-2016), Koj (09-06-2016), new2subaru (03-04-2016)
Old 03-03-2016, 10:40 PM   #263
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So polishing it won't have any negative effects in terms of heat will it?
MS, CSCS, TSAC-F, CPT
Old 03-03-2016, 10:46 PM   #264
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
No if anything it might help reflect a tiny bit of radiant heat. Honestly if you are worried about heat wrap everything in exhaust wrap. Won't look good but it's functional. His is going to look like sex in the engine bay but could be more functional. But I highly doubt zeal will ever need that tiny extra bit of prefomance. I much rather see him with a sexy engine bay!!
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
new2subaru (03-04-2016), zeal86 (03-03-2016)
Old 03-03-2016, 11:07 PM   #265
zeal86
zeal86's Avatar
Drives:
I don't believe there will be any ill effects from polishing... well... maybe, the bling might occasionally blind me. lol
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
go_a_way1 (03-03-2016), new2subaru (03-04-2016)
Old 03-03-2016, 11:12 PM   #266
zeal86
zeal86's Avatar
Drives:
Btw, Blue Magic metal polish leaves a silicone film that helps protect the finish.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
