#15 | ||
It should, the cheaper way is to buy a used one and then just load the tunes on yourself it's very easy if you need help just PM me or something when you get it or ask the forum for setup instructions or google it. Alternatively if you don't care about making power and bought the header just to make noise you could attempt the spacer O2 sensor trick
#16 |
Drives: 2014 scin frs
Pmed
It should, the cheaper way is to buy a used one and then just load the tunes on yourself it's very easy if you need help just PM me or something when you get it or ask the forum for setup instructions or google it. Alternatively if you don't care about making power and bought the header just to make noise you could attempt the spacer O2 sensor trick[/QUOTE] |
#17 |
Update: after not driving it for a week the check engine light is off but still waiting for the oft to tune will post when I receive it
| Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 12:27 PM |
| OFT Disable P0420 Cat Efficiencty | livingambition | Software Tuning | 2 | 06-18-2015 10:18 PM |
| P0420, stock exhaust with muffler delete | Kwaziekeller | Issues | Warranty | Recalls / TSB | 3 | 06-26-2014 03:59 AM |
| CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 02:27 AM |
| p0420 | brichard0625 | Issues | Warranty | Recalls / TSB | 11 | 08-04-2013 10:24 PM |
