02-22-2016, 08:01 PM | #309 |
Drives: 2013 Asphalt FRS
I have had this discussion with Pauter rods many times, According to Pauter A low hard pull lets say 2k up damages the rods because of the load. Even tho the engine has the power to overcome the load the force exerted on the rods is most at at full load and low rpm.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
The Following User Says Thank You to FRS Justin For This Useful Post: | raven1231 (02-22-2016) |
02-23-2016, 03:41 AM | #310 | |
Drives: UK GT86
.: Stealth 86 :.
The Following 2 Users Say Thank You to Kodename47 For This Useful Post: | FRS Justin (02-23-2016), Sportsguy83 (04-21-2016) |
02-23-2016, 10:32 AM | #311 |
^don't drive it like a v8. You get elitist dumb ass mofo's dissing automatics then they try and go up a hill or over take in high gears. Learn to change gears for once, friggin morons.
I haven't spent much time on this forum over the last year, not much has changed.
The Following 3 Users Say Thank You to s2d4 For This Useful Post: |
02-23-2016, 12:26 PM | #312 |
Drives: 86
Yeah, it isnt a diesel engine.
edit: btw I dont get it why ppl think about "low rpm" (<4000) torque at this engine. It is desinged to put out the most power at higher rpms. Throw the torque up at the rpm band and suprise yourself - its fcking fast and will last :P Last edited by denso; 02-23-2016 at 01:00 PM. |
The Following User Says Thank You to denso For This Useful Post: | FRS Justin (02-23-2016) |
02-23-2016, 02:27 PM | #313 |
Drives: White Frs AT
Are there forged after market connecting rods for the engine in case someone wanted to go F/I?
Edit: Actually never mind. Found them. They aren't even that expensive. I don't see why you wouldn't want to invest in them. |
02-23-2016, 04:47 PM | #314 |
Drives: 86
Yes thats right. Someone here in germany have build the block with skunk2 h-beam con rods and everything stock (internals, gaskets, studs) - 550ps.
02-23-2016, 05:09 PM | #315 |
Ridge Racerrrrrrrrr
Why does this thread get to have "Facts" in the title?
02-24-2016, 11:20 PM | #316 | |
Drives: Toyota 86
Did he do machining similar to this? http://www.ft86club.com/forums/showp...9&postcount=24 |
02-25-2016, 12:59 PM | #318 |
Drives: '14 FR-S
I will also be doing this. Getting a Pauter rod tapered to fit the stock piston.
There is no structural issue since the power stroke pushes the pin down on the small end where all the material is still intact. Only problem is that the rod can no longer be serviced. Only replaced if any small end issues arise. |
02-25-2016, 01:08 PM | #319 | |
Panda Trueno
Drives: No twin now.
Parts may be cheap. Labor and proper install wouldn't be. That's most likely the reason..... |
The Following 2 Users Say Thank You to Summerwolf For This Useful Post: | continuecrushing (02-25-2016), NyC Zn6 (02-25-2016) |
02-25-2016, 09:04 PM | #320 |
Drives: Late 2014 Subaru BRZ
I'm so happy my brz isn't my day car and I have a business car. Because when the engine comes out I would to think I can build my own. I have experience in installing rods, pistons and valve springs with retainers in my hayabusa and the pig still hasn't blown up.
Labor for a tech is high enough it's not affordable for 95% of the people of really want to build a motor for the FI setup.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
03-03-2016, 07:14 AM | #321 |
Drives: 2013 FRS / 2013 427 Vert
Add me to the list
It can happen to anyone which is not the same thing as saying it will happen to everyone. More track days, adding power, especially forced induction simply increases the likelihood that something will break and it will probably a rod.
Mine popped recently after about two weeks of forced induction. I went with the "safest" supercharger system, had it conservatively tuned to 20 degrees of advance and a 7K limiter, have the JR oil cooler and a full blown radiator but it still threw a rod accelerating onto a freeway which cut a trench across the top of the block. Moral of the story is that blame is not an issue, understanding the potential risk and how modifications will change the odds is. You can not bet your motor that having a good tune and cooling provides any guarantee, they just change the odds a little more in your favor. I will be starting a new thread soon focused on the choices to be made when replacing a blown motor, Thankfully I have the resources to do what I want and I really expected to eventually have a built motor or a V8. BTW there are 4 other cars with blown motors at the same shop in Orlando as I write this so yes there is an issue.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
The Following User Says Thank You to Deep Six For This Useful Post: | FRS Justin (03-03-2016) |
03-03-2016, 08:55 AM | #322 |
Drives: Crystal Black BRZ(Sophia)
Aww man that really sucks. Hope it was not your DD.
Tags |
kill brain cells, not facts |
Similar Threads | ||||
FlexFuel and Facts | Shiv@Openflash | Software Tuning | 69 | 10-16-2019 01:08 PM |
Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 05:22 PM |
How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 03:29 PM |
Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 09:14 PM |
Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 03:05 PM |
