Old 06-12-2012, 07:36 PM   #43
GirlyScions
Drives: Mazda3
Something cheap thats a PITA that you'll need to do in ~5-6 years makes you rethink buying a car?
Sock plugs last 5-6 years? Ive been changing mine every two and I always see a return investment in MPG.
GirlyScions is offline   Reply With Quote
Old 06-12-2012, 07:37 PM   #44
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Spec for most platinum tipped plugs in most cars is 100k. I replace mine every 60k or so but have never noticed an obvious difference.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-12-2012, 07:58 PM   #45
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Yep. I replaced mine at about 80K and that was with lots of methanol being injected into the chamber for about 25K miles. So 100K is doable, but figure 60K to 75K as a conservative estimate.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 06-12-2012, 09:29 PM   #46
dirk_diggler
Drives: 2011 BMW 328i Coupe M-Sport 6MT
Denso ZXE27HBR8 is an Iridium plug. On my prev Camry the change interval on the Iridium plugs was 120k miles. When I pulled them at 110k I saw no difference between what I pulled and the new ones. The gap on the used ones was 0.032 instead of new at 0.031. I put the new ones in since I got the old ones out, but it made no difference whatsoever. Biggest waste of time ever, especially since the bank closest to the firewall was a PITA to remove.
Anyone have ideas why Toyota/Subaru wants us to replace these Iridium plugs at 60k?
Come to think of it, looking at the first section of the shop manual posted in another thread, the service intervals for all services seems compressed. Are they figuring everyone will drive the piss out of these cars?
dirk_diggler is offline   Reply With Quote
Old 06-12-2012, 10:34 PM   #47
immortal_suby
Drives: 2015 BRZ Limited 6MT
I bet it is still easier than the plugs on an svx.
immortal_suby is offline   Reply With Quote
Old 06-12-2012, 11:41 PM   #48
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I miss my SVX!
I haven't looked at the intervals yet but my guess is the usual Subaru intervals, 30k and 60k get gear, brake and engine fluids, 100k gets coolant, 60k gets plugs. Oil changes every 7500.
-mike
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 06-13-2012, 12:05 AM   #49
ahausheer
Re-member
Drives: Toyota camry
Originally Posted by Spaceywilly View Post
Cool story. Taking the wheel off is not what annoys me. What annoys me is that a job that should be simple and take 5 minutes now takes 30 minutes for no reason other than bad engineering.
Perhaps a bad design decision but not bad engineering. They knew early on in the development of the motor about this. You likely wont have to lift the engine, you'll just have to get creative with sockets, extensions and curse words. Now changing the starter motor looks a bit harder, hope that never fails.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-13-2012, 12:18 AM   #50
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Really? That didn't look terribly hard to me, it's sitting right on top of the bell housing right near the firewall, next to the slave cylinder. Looked like there was plenty of room to get it out.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 06-13-2012, 01:11 AM   #51
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
I was talking about the civic si
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 06-13-2012, 02:51 AM   #52
bucket
Drives: 4 wheels
Originally Posted by eikond View Post
I have mixed feelings about this topic. The difficulty of changing the spark plugs wouldn't dissuade me from buy the car new.. but it would certainly make me think twice about buying one used in a few years.
I've had a long string of Nissan 240sx's.. I can't tell you how many times I needed to pull spark plugs as part of diagnosis as you're working on the car. Being able to swap plugs to find a misfire, check the color of the tips to see if it's rich or lean, do compression tests, and other stuff makes a used car or a modified car easy to live with. Having to lift a motor to do any of these things will make this an unfriendly car to own and modify when it's a bit older. I'm not a big fan of this.
All I can think about whenever somebody mentions that changing plugs is something you do once every five years is when I was driving around with a slightly bad MAF plug on my 240. I was changing out or at least inspecting the spark plugs monthly...sometimes they would show rich, sometimes lean, occasionally not bad.
Then I remind myself that this is a new warrantied car that I'm not going to F with to the same extent as the 240.
bucket is offline   Reply With Quote
Old 06-13-2012, 03:28 AM   #53
OrbitalEllipses
Drives: Attitude
*DING! DING! DING!* WINNER!
Everybody I know with one of those or who ever owned one was fucking with them constantly. There's a difference between a 10-20 year old rice rocket and new one.
Actually, one dumb SOB friend of mine is selling is S14 to buy an older S13...that makes sense.
Old 06-13-2012, 06:59 AM   #54
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
So, if the plugs have to be changed at 60K and a lot of people here are saying they are not concerned with it then I guess in 4-5 years there are going to be a lot of these available on the used car market. Let the next owner worry about it.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 06-13-2012, 07:36 AM   #55
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Mavrik View Post
Having worked/rebuilt several subaru engines in my past, both turbo duel overhead cam and single n/a engines... the spark plug placement doesn't bother me a bit. Its no different in placement then any of their other engines. Seems to have more room than an STi infact.
I agree that there seems to be more room than in the STi. Most times people think you have to drop, pull the motor to do the plugs on Subarus, but I could do all four in my STi with just a flex head ratchet and an extension. Pull a few things out of the way and all 4 can be swapped in under 30 minutes. It isn't as bad as it seems and a Subaru mechanic worth his weight shouldn't have too much trouble and then the price should be reasonable. Or get a DIY and do it in the Autozone parking lot since it doesn't take so long. Lol
Old 06-13-2012, 09:27 PM   #56
OrbitalEllipses
Drives: Attitude
What's all this about a Subaru mechanic worth their weight? As a shade tree mechanic, I did plugs on my WRX for the first time ever in about 2 hours, with no previous experience on a Subaru, or any car ever for that matter. It was kind of a bitch, but I certainly didn't get the engine out of the car. You had to first remove the stock intake snorkel and airbox for the passenger side (maybe move the power steering reservoir too); the driver's side required removing the windshield washer reservoir (larger on my wagon than on the sedans). That's it. Flex head + extension, done.
Subaru or Toyota drain plug? yayforaddison Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-06-2020 11:59 PM
Exhaust tip removal Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 97 05-27-2017 06:50 PM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 11:12 PM
Spark plug type and heat ft86-UAE Engine, Exhaust, Transmission 4 06-10-2012 11:21 AM
What do you wish was changed about the brz/frs? GirlyScions BRZ First-Gen (2012+) — General Topics 16 06-04-2012 04:26 AM
