#225 |
Mentat
Drives: 2013 Scion FRS 6MT
I bet ya they will do everything they can to blame it on the intake.
#226 |
Drives: tezla
#227 |
Drives: Brz premium
#228 |
Drives: '11 535i
#229 |
Drives: tezla
#230 | |
Drives: '11 535i
The firewall location is much harder to get to, so we chose to stop at the frame rail for ease of install. |
| The Following User Says Thank You to PERRIN_Mladen For This Useful Post: | JR007 (03-30-2014) |
#231 |
Drives: 2015 frs
Is it still possible to cap off at firewall if wanted to?
#233 |
Drives: 2015 frs
Okay, just asking. I just placed order for intake and inlet pipe.
#234 |
Turning is for Nerds
Drives: 35 characters is not enough
Cap it off from inside the car, Subaru even gives you a plug in your glove compartment.
| The Following User Says Thank You to Decay107 For This Useful Post: | Mr.Impreza (02-19-2016) |
#235 |
Drives: 2014 GT86
Indeed, no need to order separate soundtube plug, if for quick tests there is one on glove compartment cigarette lighter (which i use for powering usb devices anyway).
From what i experienced though, that if i plug sound tube, even if with quietening engine noise it quietens road noise too .. i miss engine noise too much (with stock exhaust) at daily driven low rpms and even while performance numbers should be same .. it felt subjectively lifeless/slower . Hence i'll probably go for complete sound tube delete only when also installing catback exhaust or non stock catless header, any of which should increase noise to compensate for that
#236 |
Drives: 2016 Scion FR-S
Hello,
I’m thinking of adding one of the Perrin intakes tubes to my 2016 FRS. I’m mostly trying to neatly eliminate the sound tube (save a little noise/weight), but also to help clean up the engine compartment a bit. I’m not really doing this with any hope of increasing power. As I understand, it’s miniscule at best without other modifications to the intake/exhaust. My question to those who have used it is: Do you just install it and drive away or, is there anything special that needs to be done with the computer. Do I need to disconnect the negative battery cable or anything, or will the computer adjust by itself to the slight change? There did not seem to be a consensus and this thread has not been active in a while. Thanks in advance for any feedback. |
#237 | |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
| The Following User Says Thank You to JohnJuan For This Useful Post: | Mr.Impreza (02-19-2016) |
#238 |
| Zeta Performance - Silicone Intake Pipings & Drop-in Replacement Air Filters | ZetaPerformance | Engine, Exhaust, Transmission | 95 | 11-05-2014 07:42 PM |
| Maxracing dynamic intake duct | Mars2 | Engine, Exhaust, Transmission | 123 | 09-23-2014 08:39 PM |
| AVO Silicone Intake and Sound Tube install and review | ESC POD | Engine, Exhaust, Transmission | 38 | 05-21-2013 07:18 AM |
| Zeta Performance - Silicone Intake Pipings & Drop-in Replacement Air Filters | ZetaPerformance | Engine, Exhaust, Bolt-Ons | 41 | 05-13-2013 02:00 PM |
| REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley | draggin_az | Engine, Exhaust, Transmission | 21 | 04-29-2013 04:58 PM |
