#15 | |
If this is happening, after a few miles on the freeway, if you pull over and feel (very carefully) the calipers, a sticking caliper (pad dragging) should cause that wheel to be warmer. humfrz |
#16 |
Drives: 2013 WRB BRZ 6MT
Your issue screams something to do with the differential to me and this comment sticks out. Compare the wear on the left and right rear tires and see if there is a difference. With a LSD, they need to have similar levels of wear or issues can occur. If they aren't similar, you might want to rotate your front and rear tires so you have similar wear rates on the rear and that might solve your problem. If they are similar, I'd have the car checked out.
| The Following User Says Thank You to Lynxis For This Useful Post: | MrFisty (02-15-2016) |
#17 | |
Drives: 2013 GBS BRZ
#18 |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Make sure the new tire is the exact same size and brand/model as the other tire back there. Even if it is the same tire, there could be enough of a difference in overall diameter between the worn tire and the new tire that it is upsetting things when you let off the gas. Like think of a chair with one short leg...it will "teeter" on 2 of the longer diagonally-opposed legs. Your car is effectively poorly corner-balanced.
Speaking of, do you have coilovers or stiff springs?
#19 | |
[insert cool phrase here]
Drives: BRZ Premium
The fix is to get another new one. Did the tire guy not tell you this would happen? That's why they want to sell you a pair instead of just one.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#20 | |
#21 |
#22 |
Yes, specifically if it's in the rear. That is where all of the forces from deceleration come from.
Is there a difference between the two tires? You never answered. Same brand/model/size? One worn way down? Are you running coilovers/springs/stiff suspension of any kind? That will make it worse.
#23 |
Drives: 2013 Satin White Pearl BRZ
With a limited slip differential it is important to keep two equally used tired in the back, to keep from tearing up the lsd. It's best if you have to replace just one tire to be sure the new one ends up in the front. This difference in size, no matter where it is on the vehicle will not cause a hard jerk on deceleration, it may cause the car to pull to one side but nothing severe
Sent from my SAMSUNG-SM-G900A using Tapatalk |
| The Following User Says Thank You to jbailey8748 For This Useful Post: | Mr.ac (02-04-2016) |
#24 | |
I can say that I ran 4/32 on one side and 3/32 on the other with no problem during an autocross event once but I imagine a situation if you're running much more than that like 5/32 one side and 9/32 the other can cause funny lock ups in the diff which is what I think might be happening to you. |
#25 |
Drives: BRZ Premium
Yes. As others said our lsd will kick in when they notice the slight difference.
This could also happen when one rear tire is low on air. So, it sucks you have to get another tire but that's the only way to fix it. Even if you rotate it to the front, it will pull to side the old tires on.
| Car jerks when shift from neutral to 1st | Vincent Nguyen | Engine, Exhaust, Transmission | 26 | 01-22-2016 08:05 AM |
| Engine/Drivetrain Squeak Upon Deceleration in Gear - 2013 M/T FR-S | Purdue FR-S | Issues | Warranty | Recalls / TSB | 7 | 07-15-2015 09:47 AM |
| Jerks | phobos512 | Mid-Atlantic | 18 | 05-17-2014 11:09 AM |
| BMW drivers really are jerks...lol | Lonewolf | Other Vehicles & General Automotive Discussions | 34 | 08-25-2013 12:12 PM |
| Odd noise on deceleration | Dipstik-sportech | Engine, Exhaust, Transmission | 7 | 08-18-2013 11:42 AM |
