Old 02-12-2016, 08:31 PM   #15
shern
Drives: 2015 fr-s
Heres a video after I installed the new oem gasket is this the right noise ??? [ame]http://youtu.be/Wf25VgsLjRY[/ame]
shern is offline   Reply With Quote
Old 02-12-2016, 08:47 PM   #16
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Are you tuned? If so, tuners often adjust the VVT angle, which can result in this noise (This is done to help with the torque dip). Normal.
As others have noted, aftermarket headers are not as thick, so some noises will come through.
I wouldnt panic. My tune VVT adjustment sounds like that - I think you're fine.
SpectreRT is offline   Reply With Quote
Old 02-12-2016, 08:49 PM   #17
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
However, I state again - Tsudo is an off-brand knockoff. Not something I would run on my car as a "connected to the motor" item.
After a few days, get under the car and look for black marks (soot) where the header meets the motor and at the OP connections. If no leaks exist - you're good.
Old 02-12-2016, 08:49 PM   #18
shern
Drives: 2015 fr-s
Yeah im not tune yet but i will in a moth or two! Thank you so much for the help, So this noise is normal
Old 02-12-2016, 08:50 PM   #19
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Oh, and research the Borla V1 rattle issue. This sounds more like that than anything. This rattle was coming from the flex pipes. More than likely that could also be what is going on.
In which, would be normal, just annoying.
Old 02-12-2016, 08:51 PM   #20
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Yeah I wouldnt worry about anything at this point. Enjoy the car and check for soot/exhaust leaks later.
Old 02-12-2016, 09:02 PM   #21
shern
Drives: 2015 fr-s
Awesome man thank you! will buy a high flow front pipe fix the issue?
Old 02-12-2016, 09:30 PM   #22
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Nope, its not necessarily an issue per say.
The Following User Says Thank You to SpectreRT For This Useful Post:
shern (02-13-2016)
Old 02-13-2016, 01:58 AM   #23
shern
Drives: 2015 fr-s
Oft a good tune?
Old 02-13-2016, 01:24 PM   #24
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Oft a good tune?
OFT is a device to download and implement tunes. I personally prefer live dyno tunes by certified (or experienced) tuners at reputable shops.
However, thousands of people use OFT with no issue. So either option would be fine really. Depends on what your goals are.
shern (02-13-2016)
Old 02-14-2016, 03:42 AM   #25
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Oft a good tune?
OFT is quite good if you don't have the money or access to a tuner, I was in both scenarios when purchasing OFT. Also if push comes to shove you can get an openflash etune.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
shern (02-14-2016)
Old 02-14-2016, 06:09 AM   #26
shern
Drives: 2015 fr-s
the fluttering noise came back it happens at around 3k-4k rpm (((
Old 02-14-2016, 07:30 PM   #27
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Being 100% honest, its probably the Tsudo header. It's a low-cost low quality knockoff brand header.
- I mean, brand new at ~ $350 shipped is very questionable.
- There is a reason why quality headers start at ~$600 bucks (Tomei, MXP, Borla) for this platform, while the premium ones (ACE, Nameless, JDL) are a little higher.
I'm willing to bet either the flanges are not straight at all, or the flex-joints/welds are like absolute crap.
If the noise went away for a bit with the replacement gasket + sealant - odds are it was the flanges.
Old 02-15-2016, 04:44 AM   #28
shern
Drives: 2015 fr-s
had an exhaust shop look at it and its the flanges where the overpipe meets the collector! he put a thick gasket in between and now there is no more flutttering noise and as of the welds well i had one of there reputable welders take a look at it and he told me that the welds are done right and i probably go a lucky one
Raspy header and weird noise Scalzo Engine, Exhaust, Transmission 39 08-24-2020 08:40 PM
Weird Crinkling noise coming from center console fitcious Scion FR-S / Toyota 86 GT86 General Forum 14 03-20-2016 05:56 PM
Weird rattling noise in cabin coming from front left Webster10 Scion FR-S / Toyota 86 GT86 General Forum 36 03-01-2016 05:44 PM
weird noise from clutch pedal area... mongiamc10 Issues | Warranty | Recalls / TSB 5 08-08-2014 07:04 PM
Weird Noise??? caradd Issues | Warranty | Recalls / TSB 3 11-02-2013 12:42 AM
