| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: '89 911, '06 GTI, '13 BRZ
Spark plug removal? Changed your feelings for BRZ?
By now some of you have read the spark plug removal instructions in the service manual.
Yeow! Has this soured anyone on getting a BRZ/FR-S? It has caused me to rethink it a bit. Still waiting for my car to arrive and I'll need to see how I fit in it and give it a quick run down the road before making final decision to buy the car. But the spark plug issue will be in my mind.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV |
#2 |
Site Moderator
Drives: Stuff
Something cheap thats a PITA that you'll need to do in ~5-6 years makes you rethink buying a car?
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following 13 Users Say Thank You to Dave-ROR For This Useful Post: | blu_ (06-12-2012), BRZranger (06-12-2012), Chewie4299 (07-07-2012), Cross (02-10-2014), czar07 (09-05-2012), dookie11 (06-12-2012), Guff (06-13-2012), Jayde (06-12-2012), jimmillion (04-05-2015), Mad1723 (02-07-2015), nibor33 (06-13-2012), Spaceywilly (06-12-2012), _hollywood (06-13-2012) |
#4 |
Drives: 2013 Limited DGM BRZ
Took the words right out of my mouth.
BRZGrincherhood |
#5 |
Site Moderator
Drives: Stuff
It's a major pain you have to lift the engine, remove a bunch of parts, etc I've pulled motors just to clean them well, replace hoses, replace gaskets, etc before so I guess this doesn't bother me any. IMO it just looks like a good time to freshen up seals, gaskets, etc also.
I could see it being a problem for those who don't work on their own cars but still not enough of one to not buy the car. Heck it's not as bad as the hose from hell on a mr2 turbo
-Dave
#6 | |
Kind of reminds me of the Porsche 964 and 993 with their dual plugged heads. The lower set of plugs required the removal of the mufflers and many of them never have had their lower plugs changed.
2005 Honda XR650L
#7 | |
Site Moderator
Drives: Stuff
Another good excuse to "upgrade" the exhaust lolAnd I figured shock treatment would be the best reply.
-Dave
#8 |
ZC6A2B82KC7J
Drives: 2002 WRX
seriously? you're not going to buy this car because it's "hard" to change the spark plugs? wow... grow a pair dude, it's still something you can do yourself it will just take more time. And even if you want to pay someone, it will only be once every 6 years or so. This thread is ridiculous, nobody is seriously going to change their mind about the car over spark plugs. I'm guessing you were already having second thoughts and just looking for an easy excuse to get out. All I can say is that if you really change your mind over this you're missing out on an awesome car for a completely bullshit reason.
| The Following User Says Thank You to Spaceywilly For This Useful Post: | feedbag (06-12-2012) |
#9 |
Drives: 16 Impreza 5dr CWP
It's a boxer. Not inline, v, straight, etc. The plugs are always on the outside.
#10 | |
Praise Helix!
When I saw that it required lifting the engine, I thought, oh wow that'll be a pain. And then I thought:
| The Following 5 Users Say Thank You to n2oinferno For This Useful Post: | AlexTheGreek (03-24-2013), Astroboy (04-28-2014), Chewie4299 (07-07-2012), Jayde (06-12-2012), Starscream15 (06-12-2012) |
#11 | |
ZC6A2B82KC7J
Drives: 2002 WRX
#12 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
If its even remotely similiar to changing the plugs in the WRXs or STi I've owned.. It will be a cake job.
#13 |
*****istrator
Drives: 2013 Scion FR-S 10-Series M/T
changing spark plugs seems to be the only major PITA maintenance item. all else are relatively easy. the size of the engine relative to the engine bay also makes it easy to work on than most cars. so the way i look at it is that changing the spark plugs vs. all other replacement items sort of balance themselves out. but with all the advantages the FRS/BRZ has to offer, i wouldn't let the difficulty in spark plug replacement be an influential factor when buying a car since it doesn't get replaced often enough.
if you ARE going to replace your plugs, you might as well go with good ones. i recommend using denso iridium IK22's. not sure if you've got them over-the-counter but i had to get mine from a tuning shop. it's what the tuner recommended. also they are just rebadged TRD plugs
#14 |
Wish Nissan made one
Drives: '13 WRB BRZ Premium
I have mixed feelings about this topic. The difficulty of changing the spark plugs wouldn't dissuade me from buy the car new.. but it would certainly make me think twice about buying one used in a few years.
I've had a long string of Nissan 240sx's.. I can't tell you how many times I needed to pull spark plugs as part of diagnosis as you're working on the car. Being able to swap plugs to find a misfire, check the color of the tips to see if it's rich or lean, do compression tests, and other stuff makes a used car or a modified car easy to live with. Having to lift a motor to do any of these things will make this an unfriendly car to own and modify when it's a bit older. I'm not a big fan of this. |
| The Following User Says Thank You to eikond For This Useful Post: | hmong337 (08-08-2013) |
| Subaru or Toyota drain plug? | yayforaddison | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 05-06-2020 11:59 PM |
| Exhaust tip removal | Draco-REX | Cosmetic Modification (Interior/Exterior/Lighting) | 97 | 05-27-2017 06:50 PM |
| Scratch Removal? | feldy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 05-15-2014 11:12 PM |
| Spark plug type and heat | ft86-UAE | Engine, Exhaust, Transmission | 4 | 06-10-2012 11:21 AM |
| What do you wish was changed about the brz/frs? | GirlyScions | BRZ First-Gen (2012+) — General Topics | 16 | 06-04-2012 04:26 AM |
