#225 |
Drives: Monogram FR-S
Thank you OP for this mod. 7/8 inch, 2 pack at Lowe's worked perfectly.
#226 |
Drives: 2013 Pearl White 6MT
I like the vroom, I'll keep it unplugged!
VROOOM! |
#227 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
I like driving!
#228 | |
That Guy
Drives: 2013 asphalt FRS MT
I took mine off to give me more room in the engine bay, but I've got really big hands so it was probably more important to me than a lot of other people. |
| The Following User Says Thank You to Calum For This Useful Post: | 86 South Africa (02-24-2016) |
#229 |
Drives: 2014 ssm BRZ Limited 6M
This is probably redundant and unnecessary, but I don't see a post referring to this: beginning with model year 2014, the power tap is in the center console storage bin, covered by a plastic cap which is secured by an integral strap. It seems silly to cut it off just to find the design has changed and it doesn't fit. So, I just rummaged around in the garage and used a couple compacted cotton balls to stuff the tube and then pressed a garden hose cap over the whole rubber tube surround. I'll see if it works, then go to Lowe's later if I have to. Thanks to you all for enabling this lazy bastard to lounge around longer reading your most excellent posts.
There are worse things to worry over.
#230 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
There's also a 12V socket and associated cap inside the glove box.
That one may be detachable. I haven't checked. But then you have an open socket in the glove box. Winning!
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | pfaffendorn (03-07-2016) |
#231 |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
If you read the OP it is the glove box plug that is suggested.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
| The Following User Says Thank You to nzer For This Useful Post: | pfaffendorn (03-07-2016) |
#232 |
Persona Non Grata
Drives: '15 BRZ (WRB)
The cap in the glove box of my '15 is removable and works perfectly. Using it does leave a live socket in the glove box and to me it's not worth the potential for a cock up. The Lowes caps work great and if that's too rich for you a small roll up foam ear plug works just as well. I used both.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | pfaffendorn (03-07-2016) |
#233 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | pfaffendorn (03-07-2016) |
#234 |
Thanks to all you gentlemen for continuing to steer me to the glove box. I have finally discovered the power tap there -- on the firewall behind and above the glove box, way where it is hard to see. That's my excuse, anyway. What an odd place for it, except I now have a place to charge my phone--in the glove box, and the charger seals the socket to eliminate the short hazard. I discovered that my garden hose end cap worked even better to seal the sound tube, and the car now purrs along beautifully. Can I send anyone my plastic cap as a thank you? Let me know.
#235 |
Student Driver
Drives: 2016 Subaru BRZ Limited
Me too. I did this mod with a $2 rubber plug from Orchard Hardware. Put the plug in at Orchard, drove around for a while, and took it out when I got home. To me, it sounds too much like a normal car with the sound tube blocked. YMMV.
#236 |
Drives: '15 BRZ RA
Buy a nice muffler and enjoy the car. The sound tube is ...
#237 |
Drives: Badass
I pulled the rubber grommet out, as well. If you do this, 881290 from Lowe's (in the hardware aisle with all the bolts) will make a snug fit into the hole. It's a 1" cap like these from Amazon:
https://smile.amazon.com/dp/B007Q94BMQ/ |
#238 | |
Drives: GTS 86 auto
GTS86 Auto (Australia)
| Tags |
| enouf is a damned genious, plug, sound tube, toyoburu kazoo banned. |
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 06:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Switching stereo from TC to "FR-S" mode | frsinpa | Electronics | Audio | NAV | Infotainment | 8 | 06-21-2012 11:48 PM |
| *NSFW* "Check Out My Subaru" on You Tube | Axel | Other Vehicles & General Automotive Discussions | 4 | 01-17-2010 06:56 PM |
