Old 01-27-2016, 09:10 PM   #43
VitViper
Drives: '15 FRS
VitViper is offline   Reply With Quote
The Following 5 Users Say Thank You to VitViper For This Useful Post:
Bykov (01-28-2016), CSG Mike (01-28-2016), CxG (01-12-2017), Jmonty (01-28-2016), Phantobe (10-16-2016)
Old 01-27-2016, 09:30 PM   #44
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
High boost pulley with C38 looking pretty sexy, is there possibly no way to run that setup on a stock engine?
I probably know the answer but damn that just sounds like a dream lol
Alltezza is offline   Reply With Quote
Old 01-27-2016, 09:31 PM   #45
VitViper
Drives: '15 FRS
Easy, why not? We're doing it with just an upgraded port injector on 92 octane. lol
The Following User Says Thank You to VitViper For This Useful Post:
Jmonty (01-28-2016)
Old 01-27-2016, 09:32 PM   #46
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Might be possible to put in an electronic boost controller. Then you could run a low boost map for pump gas and a high boost map for E85?
Or an extra high boost pulley on the same set up above to get more useable low and mid range?
Just spit balling ideas here.
Freeman is offline   Reply With Quote
Old 01-27-2016, 09:36 PM   #47
Alltezza
Alltezza's Avatar
I didn't think it was possible to run a boost controller with an SC, especially since the boost is completely dependent on what RPM your motor is at.
Well damn lol if you're running it fine on 92, I feel pretty comfortable running it on 93 here then. My goal is 300-330whp, that would be amazing lol.
Old 01-27-2016, 09:44 PM   #48
Freeman
Freeman's Avatar
Well I know there is at least one KW C38 owner using that set up. Maybe it's not possible on a JR kit.
Anyways back to lurking
Old 01-27-2016, 09:53 PM   #49
johan
Drives: '14 981CS, '99 NB1
It absolutely is possible to run boost control on a supercharger. For a centri, you just connect a wastegate to a charge line and run a standard 4-port mac solenoid.
For a roots/twinscrew/standard blower on manifold style - it's even more simple / cheap, but I won't get into that here...
johan is offline   Reply With Quote
The Following 2 Users Say Thank You to johan For This Useful Post:
Old 01-27-2016, 10:09 PM   #50
VitViper
Drives: '15 FRS
Easy, but not necessary.
Freeman (01-27-2016)
Old 01-27-2016, 10:17 PM   #51
johan
^ this.
We're not talking rod shattering power here if tuned right.
Old 01-27-2016, 10:18 PM   #52
Alltezza
Alltezza's Avatar
Well from looking at the graph if you were to shift at redline 7400, you'd be at 14 PSI. But if you shift at 7000 you'd be at 11.5 PSI, that sounds a lot safer especially on 93 and E85.
And I'm sure since there's not much low end TQ the stock engine should be able to run it reliably.
Edit: So I messaged VitViper about why is boost irrelevant, because I didn't wanna look too much like a dumbass in front of all you guys and this is what he said. I also asked him how much he was making to the wheels. So I thought I'd share this to everyone that's interested in this thread.
"Boost is irrelevant because boost level doesn't break anything (aside from blowing poorly secured couplers off). Power (tq) breaks stuff. The power levels these S/C kits put out won't break anything, even at 14psi.
http://blog.vittuned.com/jackson-rac...ft-86-fr-sbrz/ "
Last edited by Alltezza; 01-27-2016 at 11:00 PM. Reason: Added the graph, since we're on another page
The Following 3 Users Say Thank You to Alltezza For This Useful Post:
ATL BRZ (01-28-2016), CxG (01-12-2017), PandaSPUR (01-28-2016)
Old 01-27-2016, 10:21 PM   #53
VitViper
Drives: '15 FRS
Boost is irrelevant.
Old 01-28-2016, 02:11 AM   #54
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Very interesting...
Anyone know if Prime Motoring has any experience with tuning JSRC setups? Or can recommend a tuner in the tri-state area for this application? Not getting FI any time soon (summer 2017 earliest), but I'd like to at least get in contact with tuners and ask their opinion.
The Following User Says Thank You to PandaSPUR For This Useful Post:
-Phil (01-28-2016)
Old 01-28-2016, 09:24 AM   #55
Yoda
Drives: Crystal Black BRZ(Sophia)
I am not sure about about that if the people selling the kit recommends you build you motor to run the HBP C38 charger. We are talking almost 400whp with this charger on e85. Something will give sooner than later.
Yoda is offline   Reply With Quote
Old 01-28-2016, 09:59 AM   #56
Calum
That Guy
Drives: 2013 asphalt FRS MT
To explain it a little further: Boost is irrelevant because it's only a measure of restriction to flow. If you put a freer flowing exhaust on a supercharged engine it'll likely make more power due to the lower restriction to flow, which will also result in less boost pressure.
The Following User Says Thank You to Calum For This Useful Post:
CxG (01-12-2017)
FS Bay Area: 2013 Subaru BRZ-L SWP 6MT - Jackson Racing Supercharger - 50 state legal spitz Cars for Sale/Trade 3 02-04-2016 11:59 PM
Jackson Racing CARB supercharger+oil cooler LA blahblah Engine, Exhaust, Bolt-Ons 9 12-30-2015 12:33 AM
(SOLD) 2014 Scion FRS (w/Jackson Racing SC - CARB Legal) - $25,000 - Irvine, CA *LongFella Cars for Sale/Trade 27 04-11-2015 12:35 PM
Best CARB legal SC kit? Jackson? Oem reliable block rebuild? Cayman killer? Yui-Chan Forced Induction 179 03-04-2015 07:50 PM
