Drives: 2016 BRZ
Brake Fade/Cooling?
I plan to do a few HPDE events every year, and will be upgrading to stainless lines, high temp fluid, and dedicated track pads.
How well do the OEM calipers/rotors hold up to fade? I haven't dug into things yet as I just picked up the car and it is winter here, but it doesn't look like there are OEM cooking ducts. I'm hard on brakes (I've melted DTC 60s on a heavier car without ventilated brakes). I would prefer not to have to run ducting for only doing a handful of events a year, but if others have had issues I'll bite the bullet since it will be cheaper than replacing glazed/warped rotors and cracked pads. I'll be running 17x8 Kosei wheels with 235 R Comps on the track. |
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#3 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
Stock calipers work well enough. Stock rotors are vented and work fine as well, until you chew them up with aggressive pads. Track pads and fluid on stock everything and 235 r compounds here and no issues after a year of tracking. New brake lines on this new of a vehicle is also unnecessary unless you're very picky with feel.
#4 | |
Ducting will help a little, but a BBK is the real solution. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Blizzard (02-02-2016) |
#5 |
I run dtc60, haven't had any issues other than slight abs activation. No fade or anything like that.
#6 |
Drives: 2016 BRZ
#7 |
Drives: 2023 BRZ
The Togue Factory brake duct kit will make a significant difference. I run DTC-60s with good fluid and the ducts. Is it as good as a BBK? No. But for me, it is the difference between having confidence my car will stop (mostly) consistently during a 20 minute session and going back in after a few laps.
Without the ducts I would have to bleed my brakes after every other session. With them I can go several days at least. Also, keeping operating temps down with a BBK keeps operating costs down. If you have a chunk of change to spend and know you'll be doing many days every year for at least a few years, go with a BBK. The TF duct kit is a nice middle ground that is a great value. |
| The Following User Says Thank You to Pat For This Useful Post: | CSG Mike (02-02-2016) |
#8 | |
No cooling, brake bias, or other mods. Car has suspension, exhaust, and is currently tuned on e85. |
#9 | |
Drives: Subaru BRZ / Toyota 86 Experts
| The Following User Says Thank You to CounterSpace Garage For This Useful Post: | wparsons (02-03-2016) |
#10 | |
Completely agree. The track I race the most has 2 very high speed straights in your sharper corners with minimal run off, sadly I've seen too many cars boil the fluid and play tag with walls.
#11 | |
| How to identify different types of brake fade? | jonnyozero3 | Tracking / Autocross / HPDE / Drifting | 8 | 01-14-2019 08:52 PM |
| Recognizing Brake Fade with Data Analysis | GSpeed | Tracking / Autocross / HPDE / Drifting | 25 | 07-06-2015 12:42 AM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
| Brake Fade | RAWR BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 09-27-2012 03:56 PM |
| Odd brake pedal feel, fade? | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 09-11-2012 12:29 PM |
